What is the magnitude if the total force exerted by the four charges
The discussion revolves around calculating the total force exerted by four charges of magnitude +q positioned at the corners of a square with side length d on a charge Q located at a distance b above the center of the square. Participants are examining the correct expression for this force and questioning the validity of certain terms in their calculations.
  • Mathematical reasoning, Assumption checking
  • Participants present various expressions for the force and question the correctness of terms like d^2/2 in the denominator. Some suggest alternative formulations and seek clarification on the distance from the charges to the observation point.
The discussion is active with participants exploring different interpretations of the force calculations. Some express uncertainty about specific terms, while others provide insights into the geometric setup of the problem. There is no explicit consensus, but several participants are collaboratively refining their understanding of the problem.
Participants are working under the constraints of homework rules, which may limit the information they can share or the depth of their explanations. The discussion includes questioning the assumptions made about distances and the configuration of the charges.
pr_angeleyes
Four charges of magnitude +q are placed at the corners of a square whose sides have a length d. What is the magnitude if the total force exerted by the four charges on a charge Q located a distance b along a line perpendicular to the plane of the square and equidistant from the four charges?
The result of my attempt was:
F= 4kqQb/((d^2/2)+b^2)^3/2
but I don't know if is
F= kqQb/(b^2+l^2/2)^(3/2)
The above is almost right. Look again at the term d^2/2. Is it correct?
Perhaps you could explain your reasoning.
What is the l as in l^2/2?
It appears to me that F= 4kqQb/((d^2/2)+b^2)^3/2 is incorrect. Check the d^2/2 term in the denominator. What is the distance of a charge from the centre of the square?
AM
This is what i was thinking:
F because of one charge=kqQ/(b^2+l^2/2) * cos(theta)
=kqQ/(b^2+l^2/2) *b/sqrt(b^2+l^2/2)
=kqQb/(b^2+l^2/2)^(3/2) (along the perpendicular )
as in plane parallel to the square net F=0
explanation
AM
explanation
this is what i was thinking
That looks right to me, but I see I'm outvoted by AM and rude man :confused:. Maybe I'm missing something.
How about d^2/2 → (d/2)^2 = d^2/4 ?
No, why? As I read the OP, the point Q is distance b from the centre of the square.
I tend to agree with haruspex :-)
Curses, haruspex and barryj, you are right. :blushing:
@Andrew Mason:
Locate the four charges at (d/2,d/2,0), (-d/2,d/2,0), -d/2,-d/2,0) and (d/2,-d/2,0) and the observation point at (0,0,b).
Then the distance from any charge is
sqrt[(d/2-0)^2 + (d/2-0)^2 + (0-b)^2] = sqrt{d^2/2 + b^2}.
My excuse: spatial relations was never my strong suit!
@Andrew Mason:
You are right. I was using the distance as √2d/2 and it got me a bit confused. Squared it is d^2/2. So I agree the OP's first answer was right. Sorry for any confusion!
AM
  • · Replies 18 ·
17K
