What is the magnitude of the runner's total displacement?
The discussion centers on calculating the total displacement of a football player who runs 35 m straight down the field and then 15 m at a 25-degree angle to the right. The initial calculation of 38.08 m was incorrect, prompting a breakdown of the vectors involved. Participants suggest using vector components to find the resultant displacement, with one contributor indicating the correct magnitude of displacement is 49 m. The importance of recognizing displacement as a vector quantity rather than just a numerical value is emphasized.
thschica
A football player runs directly down the field for 35 m before turning to the right at an angle of 25 degrees from his original direction and running an additional 15 m before getting tackled. What is the magnitude of the runner's total displacement?
I got 38.08 but it is not right can someone tell me how to do it?
One vector pointing straight north has magnitude 35m, then another vector pointing 25 degrees to the right of north (65 north of east) has magnitude 15m, find the vector sum.
Is the vector sum 50 meters?How do you get it?
Perhaps drawing the situation might help.
Then find the over all change in position that occurred as if he ran in a straight line the entire distance.
You might want to break down components, your vectors looks like this
\vec{x_1} = <35,0>
\vec{x_2} = <15\cos(25), 15\sin(25)>
Thank you I just got the answer right (49)
That can't be the correct answer, as you phrased the problem. "Displacement" is a vector, not a number so no number could be the correct answer. 49 m (not just "49") might well be the magnitude of the displacement.
