What is the method for finding the eigenvector for A-0I?
5 replies · 2K views · last reply
ganondorf29
A = [2,1,2;2,1,2;2,1,2]
Find the Eigenvectors of A
First I found the eigenvalues of A
[tex] det(A - \lambda I) = 0[/tex]
[tex] \lambda = 0,5[/tex]
__________________________________________
A-5I
[-3,1,2;2,-4,2;2,1,-3] --(rref)--> [1,0,-1;0,1,1;0,0,0]
x1 = x3
x2 = -x3
v1 = [1;-1;1]
Is this the right eigenvector for A-5I?
_______________________________________________
A-0I
[2,1,2;2,1,2;2,1,2] --(rref)--> [1,1/2,1;0,0,0;0,0,0]
x1 + x2/2 + x3 = 0
I'm not sure what to do in order to find the eigenvector for A-0I
the characteristic equation gives you a bit more help than that
[tex]A = \begin{pmatrix} <br /> 2 & 1 & 2 \\<br /> 2 & 1 & 2 \\<br /> 2 & 1 & 2 <br /> \end{pmatrix}[/tex]
[tex]A - \lambda I = \begin{pmatrix} <br /> 2- \lambda & 1 & 2 \\<br /> 2 & 1- \lambda & 2 \\<br /> 2 & 1 & 2- \lambda <br /> \end{pmatrix}[/tex]
taking the determinant simplifies to
[tex]\lambda^2(5 -\lambda)[/tex]
giving eigenvalues:
5 with algebraic multiplicity of 1
0 with algebraic multiplicity of 2
the goemtric multiplicity (number of linearly independent eignevectors) is always less than or equal to the algebraic multiplicity
this means there will be one eignevector corresponding to [itex]\lambda = 5 [\itex] and upto 2 corresponding to [itex]\lambda = 0 [\itex][/itex][/itex]
ganondorf29 said:
A-5I
x1 = x3
x2 = -x3
v1 = [1;-1;1]
to check if its right try multiplying the vector by the matrix
[tex]A.v_1 = <br /> \begin{pmatrix} 2 & 1 & 2 \\2 & 1 & 2 \\2 & 1 & 2 \end{pmatrix}<br /> \begin{pmatrix} 1 \\-1 \\1 \end{pmatrix}<br /> = \begin{pmatrix}3 \\3 \\3 \end{pmatrix}<br /> \neq 5 v_1[/tex]
so this is not correct
For A-5I
x1 = x3
x2 = x3
so [1;1;1] is the eigenvector for [tex]\lambda = 5[/tex]
[2,1,2;2,1,2;2,1,2] * [1;1;1] = [5;5;5]
But I'm still not sure how to find the eigenvectors for A-0I
You have x1 + x2/2 + x3 = 0. You can solve for anyone of the variables in terms of the other two, so you have two degrees of freedom. So let x2=s and x3=t. Express the solutions in the form (x1, x2, x3) = s(some vector) + t(some vector). Those two vectors will be the eigenvectors.
ollowing on from Vela
x1 + x2/2 + x3 = 0
is the equaton of a plane through the origin, which can be spanned by any two linearly independent vectors lying in that plane, solving for x2 in term so of x1 & x3, gives
x2 = -2(x1 + x3)
note vela suggested solving for x1 first, which is fine, but i like the symmetry soving for x2
then let x1=s, x3=t and follow on, note this is equivalent to solving the 2 cases below
a) x1=1, x3=0
b) x1=0, x3=1
whih may be easier to see first time round
