- 14,601
- 7,195
In your opinion, what is the most difficult written text (e.g. a book or a paper) on mathematics?
My candidate: Principia Mathematica by Whitehead and Russell
At least I understand the notation in it (which cannot be said for PM).jedishrfu said:What about the notebooks of Ramanujan?
why?Demystifier said:In your opinion, what is the most difficult written text (e.g. a book or a paper) on mathematics?
Have you tried to read it?lavinia said:why?
Difficult math or difficult writing?Demystifier said:Have you tried to read it?
In the case of PM, it is definitely difficult writing.Greg Bernhardt said:Difficult math or difficult writing?
Demystifier said:In the case of PM, it is definitely difficult writing.
First, they use a rather unfamiliar notation (at least to modern mathematicians, including logicians).
Second, while other books on logic have a human friendly combination of formal and informal talk, PM is almost entirely formal.
Third, it's really big, probably much bigger than necessary to explain all what really needs to be explained.
lavinia said:The things that make math hard - other than bad writing - are non-intuitive arguments,formalism, and high levels of abstraction. Every area has some of this.
The type theory may me complicated when studied in all details, but the idea of type theory (which I read about from other books, not directly from PM) is quite intuitive to me.micromass said:And fourth, the kind of logic they are using makes things much more complicated than using a more modern logic. The entire endaveour was to eliminate Russel's paradox by introducing type theory. This goes on to make an extremely complicated kind of mathematics. The more "modern" elimination of Russel's paradox (by the ZFC axioms) is much easier and intuitive.
While I can't follow the details, I have always found Perelman's papers to seem well written. There is plenty of description of the idea to be established, how it fits with other idea, and how it will be used. On the other hand, experts in the field are pretty unanimous that the logical 'step size' is way above average. This is the aspect that made it so hard, and meant every verification of it was 10 times the size of the original. On the other hand, my first point about a clear game plan led, in my recollection, to experts 'believing the program' way before they completed detailed verification.wabbit said:I don't know if it's the most difficult, but http://arxiv.org/abs/math/0211159 isn't easy : )
I think the original question overlooks what may be a valid distinction: some thing may be difficult and yet well-written.PAllen said:While I can't follow the details, I have always found Perelman's papers to seem well written.
Schwinger is a special case. For example, S. Schweber in his book "QED and the Men who Made It" said the following:MathematicalPhysicist said:For me alongside this there's also Schwinger's monograph in Particles, Fields and Sources volume I which is hard to read and follow, but that's a physics book, and physics books are notoriously hard to follow.
micromass said:. For example, Newton's Principia or ancient Greek texts are difficult to read because they wanted to do everything geometrically (again: to eliminate certain paradoxes that we have solved much more adequately).
How about numerical/computational mathematics? Is there a Bourbaki-style text on numerical/computational mathematics? And if there is, do you find it easier than more common texts on this branch of mathematics which are, as a rule, written in a physics/engineer style?martinbn said:The ones that I find hard to read are those written by physicists or physics minded mathematicians. Those that I find easier are the Bourbaki or Bourbaki style.
rollingstein said:Interesting! Which paradoxes are these that forced the older texts to stick to Geometric proofs.
But ##\sqrt{2}## appears geometrically in the digonal of a unit square which is a valid geometric shape, they just closed their eyes?micromass said:I recommend to read Kline's: https://www.amazon.com/dp/0195061357/?tag=pfamazon01-20
Basically, the ancient Greeks did not trust algebra because ##\sqrt{2}## was not rational. They had a very hard time accepting this fact. They thought that integers (and thus rational numbers) were intuitive, but irrational numbers were not. This is why they forced their proofs to be geometrical, since these "paradoxes" do not show up in geometry. Hence everything they did was geometric. For example, Euclid's Elements contains a lot of number theory, but it is all stated in a (rather awkward) geometric language.
The Greeks had such an influence on the rest of the history of mathematics, that their example was followed. Hence Newton's famous Principia was geometric too since he wanted to imitate Euclid's Elements. On the other hand, irrational numbers were so convenient that they started being used in mathematics anyway. But nobody knew what they were or why they worked. This (together with the use of infintesimals in calculus) started an era where a lot of math was done nonrigorously. It was only 150 years ago that the concept of an irrational number was clarified (although not everybody agrees with this clarification) and that math was starting to be rigorous again. Whether this is a good thing is a matter of opinion.
In any case, geometry had a very big influence on mathematics. So much that old mathematicians in the 17th and 18th century were often called "geometers". Geometry lost this influence mainly because of the discory of non-Euclidean geometry, which showed that Euclidean geometry was not really the only system that could describe our world. Since that discovery, algebra has been dominant in most mathematics and it still is.
MathematicalPhysicist said:But ##\sqrt{2}## appears geometrically in the digonal of a unit square which is a valid geometric shape, they just closed their eyes?
The limitations of Greek mathematical thought almost automatically imply the problems the Greeks left to later generations. Thc failure to accept the irrational as a number certainly left open thcequestion of whether number could be assigned to incommensurable ratios so that these could be treated arithmetically. With the irrational number, algebra could also be extended. Instead of turning to geometry to solve quadratic and other equations that might have irrational roots, these problems could be treated in terms of number, and algebra could develop from the stage where the Egyptians and Babylonians or where Diophantus, who refused to consider irrationals, left it. Even for whole numbers and ratios of whole numbers, the Greeks gave no logical foundation; they supplied only some rather vague definitions, which Euclid states in Books VII to IX of the Elements. The need for a logical foundation of the number system was aggravated by the Alexandrians' free use of numbers, including irrationals; in this respect they merely continued the empirical traditions of the Egyptians and Babylonians. Thus the Greeks bequeathed two sharply different, unequally developed branches of mathematics. On the one hand, there was the rigorous, deductive, systematic geometry and on the other, the heuristic, empirical arithmetic and its extension to algebra. The failure to build a deductive algebra meant that rigorous mathematics was confined to geometry; indeed, this continued to be the case as
late as the seventeenth and eighteenth centuries, when algebra and the calculus had already become extensive. Even then rigorous mathematics still meant geometry.
Fredrik said:The most difficult math (or mathematical physics) book I own is "Geometry of quantum theory" by Varadarajan.
I guess physicists find Varadarajan difficult precisely because it is not written in a physicist style, despite the fact that it is related to physics. To test this hypothesis, it would be interesting to see what martinbn has to say about this book; is it Bourbaki enough?martinbn said:The ones that I find hard to read are those written by physicists or physics minded mathematicians. Those that I find easier are the Bourbaki or Bourbaki style.
Demystifier said:How about numerical/computational mathematics? Is there a Bourbaki-style text on numerical/computational mathematics? And if there is, do you find it easier than more common texts on this branch of mathematics which are, as a rule, written in a physics/engineer style?
I have only looked in the book and have not read it, but my first impression was that, yes, it would be a book that I would enjoy. I do like his other books, so the style is bourbakish enough for me.Demystifier said:I guess physicists find Varadarajan difficult precisely because it is not written in a physicist style, despite the fact that it is related to physics. To test this hypothesis, it would be interesting to see what martinbn has to say about this book; is it Bourbaki enough?
fourier jr said:algebraic geometry by hartshorne has a reputation for being extremely hard but I haven't seen much of it. it's supposedly a shorter version of EGA.
Demystifier said:Martinbn, is there a book for which even you would say that it is too much rigorous, too much abstract, too much Bourbaki for your taste? If there is (which I doubt), then that would be a really really difficult book by standards of most of us.
I knew you will say that.martinbn said:There isn't anything that is too rigorous or too abstract, the more the better.
Yes, that's what I want here. Please, can you give some examples?martinbn said:But there are texts that are too difficult for me even if I like the style.
I don't know, I am not one of them.martinbn said:I am curious now how do physicist (and anyone else) like text like these http://www.ams.org/bookstore-getitem/item=qft-1-2-s
Which topics in pure mathematics do you not like?martinbn said:That's not to say I like anything that is abstract and rigorous, it depends on the topic.
You're right ... some mathematicians do call it "abstract nonsense" ...Demystifier said:I am curious how do you feel about category theory, which some mathematicians call "abstract nonsense"?
Demystifier said:I knew you will say that.
But how about this one?
https://www.amazon.com/dp/0387968903/?tag=pfamazon01-20
I suspect that this could be one of rare books respected by both mathematicians and physicists.
Demystifier said:Which topics in pure mathematics do you not like?
"It is almost impossible for me to read contemporary mathematicians who, instead of saying, ‘Petya washed his hands’, write ‘There is a t1 < 0 such that the image of t1 under the natural mapping t1 -> Petya(t1) belongs to the set of dirty hands, and a t2, t1 < t2≤0, such that the image of t2 under the above-mentioned mappings belongs to the complement of the set defined in the preceding sentence."martinbn said:Bourbaki (which Arnold critisies a lot)
Did you know (see http://en.wikipedia.org/wiki/Robert_Langlands ) that Langlands occupies Albert Einstein's office at the Institute for Advanced Studies in Princeton? As Einstein was a physicist, it is not surprising that you find Langlands difficult.martinbn said:The style is not Bourbaki, but everything that Harish-Chandra and Langlands write I find extremely difficult.
Really, anything?phion said:I find anything written in mathematics difficult.
Don't be obtuse. I'm sure if I wasn't already familiar with the basic rules of arithmetic or algebra, then it would be rather confusing.Demystifier said:Really, anything?
How about 1+1=2?
Or to be less trivial, solving for x in 7-x=4?
Ah, I think I also have some similar mathematical experiences. For example, adding natural numbers in basis 10 is easy for me, but adding them in any other basis is not so easy. (For instance, I must think a little before seeing that 1+1=10 in the binary basis.) Despite the fact that, objectively, no basis is really easier than any other.phion said:I'm sure if I wasn't already familiar with the basic rules of arithmetic or algebra, then it would be rather confusing.
Demystifier said:Did you know (see http://en.wikipedia.org/wiki/Robert_Langlands ) that Langlands occupies Albert Einstein's office at the Institute for Advanced Studies in Princeton? As Einstein was a physicist, it is not surprising that you find Langlands difficult.
Harish-Chandra (http://en.wikipedia.org/wiki/Harish-Chandra) was both mathematician and physicist, and his doctoral adviser was the physicist Paul Dirac. No further comment is needed.
Abstract algebra throws me for a loop at the moment. Also, I "enjoy" reading about real analysis currently.Demystifier said:Ah, I think I also have some similar mathematical experiences. For example, adding natural numbers in basis 10 is easy for me, but adding them in any other basis is not so easy. (For instance, I must think a little before seeing that 1+1=10 in the binary basis.) Despite the fact that, objectively, no basis is really easier than any other.
That's good news, there is still some hope for you to become a mathematical physicist.martinbn said:by the way I find Einstein pleasant to read
