What is the necessary and sufficient condition?
  • Thread starter Thread starter Helly123
    Algebra Condition
34 replies · 4K views
Helly123
|x-2| < a is a necessary condition for x^2 -3x -10 < 10 . What is the range value of a?
|x-2| < a is a sufficient condition for x^2 -3x -10 < 10. What is the range value of a?[/B]
The options are
a>= 4
a>=3
0<a<=2
0<a<=3
0<a<=5
Range of x for x^2 -3x -10 < 0
2<x<5
And
|x-2| < a
Range of a is 0 < a < 3
Necessary = 0<a<=3
What is the necessary and sufficient conditions?
The options are
a>= 4
a>=3
0<a<=2
0<a<=3
Range of x for x^2 -3x -10 < 10
2<x<5
And
|x-2| < a
Necessary = 0<a<=3
Your x-range is incorrect: the range of x for ##x^2 - 3x - 10 < 10## is not ##2 < x < 5##.
Are you sure you copied the problem correctly?
Sorry. I have corrected it
Ray Vickson said:
So, where is the correction? All I see is the original problem, not corrected.
Sorry. I forgot to correct the up side of question. The equation is x^2 - 3x -10 < 0
It is certainly possible to give ##|x-2| < a## as a sufficient condition, and there are many values of ##a## that will work; however, there is no value of ##a## that will have ##|x-2| < a## as a necessary condition.
You have not solved this correctly.
In the OP, when you make statement about "Range" I assume that you mean "solution".
Helly123 said:
Range of x for x2 -3x -10 < 0
2<x<5
The solution to ##\ x^2 -3x -10 < 0\ ## is not ##\ 2<x<5\ ##.
For example x = 1 is also a solution to ##\ x^2 -3x -10 < 0\ ##.
By the way, one of the given choices does give a necessary condition.
If ##P\implies Q ##, then we say ##P ## is a sufficient condition for ## Q## and ##Q## is a necessary condition for ## P##
The first problem is to find ##a ## such that
[tex] x^2 -3x-10<0\implies \lvert x-2\rvert <a[/tex]
One may note that ##x^2 - 3x -10 = (x-5)(x+2)<0 ##, which is true for every ##x ## satisfying ##-2<x<5 ##.
Now examine a condition ##\lvert x-2\rvert <a ## which is the same as
[tex] -a < x-2 < a \iff 2-a <x<2+a[/tex]
Now, for which largest possible ##a ## do you not exceed the bounds? (NOT a necessary condition, however!)
Conversely, consider the reversed implication
[tex] \lvert x-2\rvert <a \implies x^2 -3x-10<0[/tex]
Only now, your premise is the given condition ##2-a<x<2+a ##. You must guarantee ##(x+2)(x-5)<0 ##. Which values of ##a## guarantee that?There is a problem with terminology, though. You can only find sufficient conditions of the form ##2-a<x<2+a ##. There are no necessary conditions.
To quickly illustrate what I mean. If ##Q ## is a necessary condition for ## P##, then ##\neg Q## is a sufficient condition for ## \neg P##. In other words, if we did, indeed have a necessary condition ##2-a<x<2+a ## for some ##a##, then ##x\leq 2-a\lor x\geq 2+a ## must be a sufficient condition for ##(x+2)(x-5)\geq 0 ##, but that is not true of any ## a##, therefore a necessary condition of the given form cannot exist.
Not only is there a sufficient condition given, but there is also a necessary condition given.
It's rather futile to discuss either without the OP giving the correct solution to the given quadratic inequality.
\ x^2 -3x -10 < 0\ ##​
NO. If you look at the correct interval ##\alpha < x < \beta## for ##x^2 - 3x - 10 < 0## it just cannot be written as ##|x - 2 | < a## for some ##a##. Basically, ##2## is not the mid-point of the interval ##(\alpha, \beta)##.
It doesn't need to be centered on any particular point..
I think it best to wait for OP to correctly solve the given quadratic inequality before further discussing this point.
I agree. Certainly a sufficient condition can be written as ##|x-2| < a##---and that for lots of different values of ##a##. And, of course, if we let ##a = +\infty## we can write a necessary condition ##x \in \mathbb{R}## as ##|x-2| < a.## I don't think that is what the questioner meant, although I could be wrong.
Sorry again.. the value of x for x^2 -3x -10<0 is -2<x<5
When -2<x<2
a value is 0<a<4
When 2<=x<5
0<=a<3
But i cannot decide what is the sufficient and necessary conditions
My answer now, sufficient 0<=a<3
Helly123 said:
Sorry again.. the value for x is −2 < x < 5
The above is the correct solution to the given quadratic inequality.
The following makes little to no sense.
For −2<x<2
0<a<4
If a = 2, then |x − 2| < a is equivalent to 0 < x < 4.
For 2<=x<5
0<=a<3
I have corrected it
That's basically saying if ##f(x)< 0##, then ## x\in\mathbb R##, a vacuously true statement. That said, I doubt they operate in ##\bar{\mathbb R} ##
Well, of course it is vacuous---that is exactly the point! Anyway, ##\bar{\mathbb{R}}## is not involved, just ##\mathbb{R}##.
nuuskur said:
##a=+\infty ## is meaningless in that instance, if one insists on being overly pedantic :biggrin:
No: it is just notation. Saying that ##|x-2| < \infty## is just saying that ##|x-2|## can be any real number. Personally, I would never voluntarily say it that way, but it would certainly be a way to put the statement in the format requested by the problem.
When -2<x<2
a value is 0<a<4
When 2<=x<5
0<=a<3
Yes.
For | x − 2 | < a to be a sufficient condition so that x2 − 3x − 10 < 0, the range for a is 0 < a ≤ 3.
You have not been very clear in showing that this is the case.
This does not give all of the values of x which satisfy the given quadratic inequality. Rather any x fulfilling | x − 2 | < a will satisfy the quadratic inequality.for the specified range of a values. So being in that interval is a sufficient condition for x to satisfy the quadratic inequality..
SammyS said:
Yes.
I don't get it why is 0 < a ≤ 3? Why including 3?
You beat me to that question.
For one thing, if you look at the problem statement you gave, that choice includes the 3.
Helly123 said:
The options are
a>= 4
a>=3
0<a<=2
0<a<=3
0<a<=5
As a teacher I would be inclined to ask you , "Why does that include the 3?"
Plug a = 3 into the inequality |x−2| < a and solve for x.
What do you get?
Then we can tackle the "necessary" condition.
What do you get?
If i plug a = 3. I get x = 5. But, the range for x^2-3x-10<0 is x less than 5. Not including 5
SammyS said:
Really?
You shouldn't.
| x − 2 | < 3
gives
−3 < x − 2 < 3 .
Right?
Hm yes. Then, i am confused how to get 0 < a<= 3 itself..
How i get it is when x=-2, a must be 4
When x = 5, a must be 3
When x = 2, a must be 0
The range for a must be between 0 and 4
You seem to be working this backwards.
If a = 4, then | x − 2 | < a gives −4 < x − 2 < 4, which includes values of x which do not satisfy the quadratic inequality.
Also, for a ≤ 0: There is no value of x for which | x − 2 | ≤ 0 . So we must have a > 0 .
Helly123 said:
Hm yes. Then, I am confused how to get 0 < a<= 3 itself.
@nuuskur outlined some of this in post #8.
If a ≤ 3 and | x − 2 | < a , then | x − 2 | < 3 .
You need to do some thoughtful work on these issues. We can't do it all for you.
Also, for a ≤ 0: There is no value of x for which | x − 2 | ≤ 0 . So we must have a > 0 .@nuuskur outlined some of this in post #8.
Ok i will try. Thank you
Is the necessary condition a>=4 or 0<a<=4 ?
Both is possible, i think
I must apologise for #8, it contains some false statements at the end.
A necessary condition is something that simply has to be true given some assumptions. In this case, we assume ##(x+2)(x-5)<0 ##
It does not imply that ##-1<x<5 ##, for instance, but it does imply ##-2<x<6 ##.
A quick way to check this, as I mentioned, is making use of the logical equivalence of two statements
[tex] P\implies Q\iff \neg Q\implies \neg P[/tex]
In this example, as ## P## we consider ##(x+2)(x-5)<0 ## and as ##Q ## we consider ##\lvert x-2 \rvert <a ##.
If we want ##Q ## to be a necessary condition, we can also pick ## a## such that ##\neg Q = \lvert x-2\rvert \geq a ## is a sufficient condition for ##\neg P = (x+2)(x-5)\geq 0 ##.
It suffices to pick ##x\leq -2\lor x\geq 6 ##, then it's guaranteed that ##(x+2)(x-5)\geq 0 ##. Reverse the order now, if ##(x+2)(x-5)<0 ##, then it is necessarely true that ##-2<x<6 ## (i.e you are correct about ## a\geq 4##)
However, ##0<a<4 ## will not yield a necessary condition. If you pick, say, ## a=1##, then the implication
[tex] (x+2)(x-5)<0 \implies -1<x<3[/tex]
is false. We can pick ##x = -1.5##, it still stands that ##(x+2)(x-5)<0 ##, but at the same time ##x\leq -1##.
I think I got confused by an earlier post, but I am certain now that this is correct.
Where the -2<x<6 comes from?
