What is the physical significance of Bell's math?
199 replies · 19K views
N88 said:
DrChinese, stevendaryl and his comment to rubi, quoted by me immediately above, leaves me wondering: Why are there not a lot more standing with me?
Because you have adopted definitions at odds with EPR. Naturally your conclusions might differ in that case, and in fact they have. The EPR realism definition is compelling to the typical reader, which is why the EPR paper is so important.
N88 said:
As I wrote above: it would never occur to me to make such an assumption under EPRB! So I am inclined to say that this statement should be known as the 'strawman-realist' assumption.
Well, it's a coherent notion of realism, and if it's a strawman, I've never seen a non-strawman concept of realism.
For I am a realist under this article by d'Espagnat (which Bell endorsed): http://www.scientificamerican.com/media/pdf/197911_0158.pdf
2: On p.158 we see these principles of local realism: (i) realism -- regularities in observed phenomena are caused by some physical reality whose existence is independent of human observers; (ii) locality -- no influence of any kind can propagate superluminally; (iii) induction -- legitimate conclusions can be drawn from consistent observations.​
Well, Bell's "strawman" notion of realism is an attempt to make sense of those properties. If you can come up with a model that is realistic in that sense but not in Bell's, I'd like to hear it.
N88 said:
Note: This then leaves me wondering why the general claim associated with Bell's theorem is that "local-realism" is refuted? I can accept that local strawman-realism is refuted. But realism under Bohr's insight (that a measurement may perturb the measured system) is not refuted.
I would call that Heisenberg's insight. But Bell's theorem rules out such a notion of realism, as well.
You might think that a more general notion of realism is this:
Instead of saying that the measurement results are determined ahead of time, you can allow that the act of measurement is a nondeterministic process, so the outcome of the measurement depends on
  1. Facts about the particle being measured.
  2. Facts about the device doing the measurement.
  3. Randomness in the measuring process.
However, the only way using realism to get perfect anti-correlations in EPR is if the randomness plays no role. If in the EPR experiment using spin-1/2 particles, Alice measures spin up along axis [itex]\vec{a}[/itex], then she knows with 100% certainty that Bob will measure spin down along axis [itex]\vec{a}[/itex]. There is no randomness in Bob's result.
So if you want to try to use the idea that Alice's measurement disturbs the system, then you would have to allow for Alice's actions to disturb Bob's particle, which would imply faster-than-light influences.
So no, Bell's assumptions is not just a "straw man".
stevendaryl said:
... Instead of saying that the measurement results are determined ahead of time, you can allow that the act of measurement is a nondeterministic process, so the outcome of the measurement depends on
However, the only way using realism to get perfect anti-correlations in EPR is if the randomness plays no role...
Well said, easy to understand. Can you get this published in a peer reviewed journal so we can quote it?
Jilang said:
Are we able to assume that realistic properties do exist independent of measurement, but that the act of measurement changes their distribution?
I would say that this is possible under condition that randomness in measurement process is restricted by non-local conservation of phase.
I see not difference between (i) and stevendaryl post #171.
Are you saying that (i) should not be called realism but strawman-realism ?
Because any local phenomenon would require magic influence over observers, not FLT influence, but unrealistic influence which dependent only on what Bob and Alice are(not ?) doing locally.
stevendaryl said:
We're talking in the context of Bell's inequality, which was derived under the assumption that we had a local realistic theory. With such a theory, the variables [itex]a_n, a_n', b_n, b_n'[/itex] exist independently of whether anybody measures them, and so it makes sense to talk about averages of them.
You can certainly reject that assumption, which means rejecting the assumption that Bell proved false, anyway.
Well, I thought it was N88's point that the BI can't be proved without this additional assumption, so I pointed it out, but after his latest comments, I'm not so sure anymore, what his point is.
The word "realism" in the context of Bell's inequality refers to a well-defined technical assumption in the proof of Bell's inequality. It has nothing to do with the fuzzy concept of realism in philosophy. Of course, QM describes reality, because it is consistent with experiments. The violation of Bell's inequality just implies that reality is much more peculiar than classical physicists imagined it to be. In particular, this means that experimental results aren't pre-determined by hidden variables (if you are a Bohmian, you will expoloit the non-locality loophole instead). There are much more adequate ways to phrase the conclusion of Bell's theorem, such as: "No local hidden variable theory / no local classical theory / no local counterfactually definite theory can reproduce the predictions of QM." It is then absolutely clear that one is talking about a sharp mathematical criterion rather than some ill-defined philosophical concept. But of course, terminology in science is not fixed and thus you will still find the term "realism" in many publications. Nevertheless, what we can take away is that reality can't work as one would naively imagine, so Bell's theorem does indeed impact our conception of reality.
Generally accepted science does not require references. If someone posts without references and makes statements that go against standard physical theory, they are subject to challenge. So it is best to stick to the mainstream, and clearly identify areas in which your opinion does not clearly reflect that.
Would this destroy realism?
1. Facts about what is being measured
2. Facts about the measuring equipment
3. Randomness of the orientation of what is being measured relative the measuring equipment.
rubi said:
Well, I thought it was N88's point that the BI can't be proved without this additional assumption, so I pointed it out, but after his latest comments, I'm not so sure anymore, what his point is. Emphasis added.
This was my point. This remains my point. I appreciated that you appeared to be making the same point so clearly in your earlier posts.
I cannot see where my later comments depart from this point. For me, the well-defined "realism" in the context of Bell's theorem is most clearly evident when Bell (1964) moves from his (14a) to his (14b). If the lambdas are appropriately paired, (14a) is a testable and readily validated formulation under EPRB. But (14b) is false under EPRB because it equates to his (15) which is known to be false under EPRB.
This falsity must therefore arise from the "realist" assumption that Bell used in moving from valid (14a) to invalid (14b): by my analysis, that assumption is (as given in the OP with added details there re consequences).
[A(b,λ)]2 = 1. (X)
Now, in that it has never occurred to me to make such an assumption (me knowing it to be false via QM,* without reference to any of Bell's work), this is "straw-man realism" for me; a false argument advanced and refuted.
However, no matter the terminology, Bell and I agree: (15) is false under EPRB. But nowhere do I see Bell's recognition that (X) above is false. (See Bell's (1990) dilemmas re AAD and locality
and this next.)
Now, in that (X) may not be a straw-man argument for others, I refer them to d'Espagnat's (1979) article (endorsed by Bell). There, in my opinion, they have defined "naive realism" in that (as I see it): they inferred the measured output was the same as the measurement input. A+ output leads to their inference "A+ is a particle property."
Thus, to me, (X) is licensed by them under "naive-realism" (or, for me, under "straw-man realism") both of which are false under EPRB.
I therefore maintain my conclusion that (using some of your terms): "BI cannot be proved without assumption (X)" which is a well-defined technical assumption in the derivation of Bell's inequality.
rubi said:
The word "realism" in the context of Bell's inequality refers to a well-defined technical assumption in the proof of Bell's inequality. It has nothing to do with the fuzzy concept of realism in philosophy. Of course, QM describes reality, because it is consistent with experiments. The violation of Bell's inequality just implies that reality is much more peculiar than classical physicists imagined it to be. In particular, this means that experimental results aren't pre-determined by hidden variables (if you are a Bohmian, you will exploit the non-locality loophole instead). There are much more adequate ways to phrase the conclusion of Bell's theorem, such as: "No local hidden variable theory / no local classical theory / no local counterfactually definite theory can reproduce the predictions of QM." It is then absolutely clear that one is talking about a sharp mathematical criterion rather than some ill-defined philosophical concept. But of course, terminology in science is not fixed and thus you will still find the term "realism" in many publications. Nevertheless, what we can take away is that reality can't work as one would naively imagine, so Bell's theorem does indeed impact our conception of reality.
In my terms (which, it seems to me, can also be yours): We can take away from Bell's work that "naive realism" does not work (as naive persons might naively imagine), so Bell's Theorem does indeed impact naive conceptions of reality. * (All in line with prior work by Heisenberg, Bohr, etc. And now you, rubi : QM describes reality, because it is consistent with experiments. The violation of Bell's inequality just implies that reality is [somewhat] more peculiar than classical physicists imagined it to be.
Finally you are saying something that makes sense. Of course, that is still saying that classical realism is untenable. Which is in fact what Bell's Theorem says is incompatible with the predictions of QM.
Thanks DrC, with due acknowledgment to RUBI.
Thanks for seeking clarification. No, I am not saying that at all. I readily and happily accept d'Espagnat's Bell-endorsed principles (i)-(iii).
Re other matters, please see my more detailed reply to rubi above.
Well, to call it "naive realism" or "strawman realism" suggests that there is some "non-naive" notion realism under which QM might be a local realistic theory. But what is that?
The claim that the "measured output was the same as the measurement input"---I'm not exactly sure what you mean by that, but you mean the fact that claim that the measurement reveals a pre-existing hidden variable. If that's what you mean, that is not an assumption, that is a conclusion from the fact that QM predicts perfect correlations/anti-correlations in EPR-type experiments.
Local realism to me (I'm not sure if this is naive local realism, or not, but if it is, I would like to see what is non-naive realism) says that the result of a measurement depends on what the local situation is. To me (not everyone agrees with this), nondeterminism is compatible with local realism, so the outcome of a measurement in a local realistic theory could potentially be nondeterministic. But in a locally realistic theory, if the outcomes are probabilistic, then the probabilities of various outcomes can only depend on local facts.
So potentially, you could, for the anti-correlated EPR experiment have a locally realistic theory that would say:
  • The probability that Alice measures spin-up for her particle is some function [itex]P_A(\alpha, \lambda, O_A, T_A)[/itex], where [itex]\alpha[/itex] is the setting of Alice's detector, [itex]\lambda[/itex] is a variable describing the production of the twin pair, [itex]O_A[/itex] is a variable describing other miscellaneous properties of Alice, her detector, the measurement process, etc., and [itex]T_A[/itex] is a variable describing Alice's particle's travels from the point of creation to the point of detection.
  • Similarly, the probability that Bob measures spin-up for his particle is some function [itex]P_B(\alpha, \lambda, O_B, T_B)[/itex]
So you don't have to assume that the measurement results are set in stone from the beginning; they might potentially depend on all sorts of things. However, the perfect anti-correlation implies that if Alice measures spin-up at detector setting [itex]\alpha[/itex], then Bob certainly will not measure spin-up at that setting, and vice-versa. This implies that for a fixed [itex]\alpha[/itex] and [itex]\lambda[/itex],
  • [itex]P_A(\alpha, \lambda, O_A, T_A) P_B(\alpha, \lambda, O_B, T_B) = 0[/itex]
One or the other probability must be zero, since they never both happen. Also, it never happens that they both measure spin-down at the same detector setting, either. Since empirically, you either get spin-up or spin-down, the probability of spin-down is 1 - the probability of spin-up. So we have:
  • [itex](1 - P_A(\alpha, \lambda, O_A, T_A))(1 - P_B(\alpha, \lambda, O_B, T_B)) = 0[/itex]
Those two facts about probability tell us that for any [itex]\alpha[/itex] and [itex]\lambda[/itex]:
  • Either [itex]P_A(\alpha, \lambda, O_A, T_A) = 0[/itex] or [itex]P_A(\alpha, \lambda, O_A, T_A) = 1[/itex]
  • Either [itex]P_B(\alpha, \lambda, O_B, T_B) = 0[/itex] or [itex]P_B(\alpha, \lambda, O_B, T_B) = 1[/itex]
So even though we allowed the results to be probabilistic, the perfect anti-correlations imply that the result must be deterministic. For some values of [itex]\alpha[/itex] and [itex]\lambda[/itex], it is certain that Alice will get spin-up and that Bob will get spin-down. For other values, it is certain that Bob will get spin-up and Alice will get spin-down.
So the conclusion that the result is deterministic follows from the assumption of perfect anti-correlation and the assumption that whatever probabilities are involved depend only on local variables.
That is incorrect. By the definition of realism that you've finally agreed with (and everybody does because there is no other definition), a very naive person, helps by Occam's razor, will conclude that locality do not work. An that is trivial to realistically implement, as already shown.
Now, if you have another/better operational definition of realism, I would also appreciate that you explain it ... precisely.
Summarising my current position:
1. In post #190 [ https://www.physicsforums.com/threa...nce-of-bells-math.904029/page-10#post-5710931 ] I have summarised my understanding of the answer to the OP: "What is the physical significance of Bell's math?"
2. I thank all who have helped me arrive at that position. (I now realize that my starting point -- "having rejected Bell's thesis from day-one" -- has contributed to many crossed and frustrating exchanges.) I look forward to further comments that might clarify, correct or improve that summary; etc.
3. As to unfinished business that goes beyond the OP, I think it best if new specifically-titled threads are opened.
4. I plan to reply here (soon) to some open matters. I need to be careful about non-mainstream ideas.
With my thanks again,
N88
A very relevant and easy to read paper by Guy Blaylock, "The EPR paradox, Bell’s inequality, and the question of locality" addresses a number questions that have come up in this thread.
stevendaryl said:
What's hard for me to understand is what would count as a non-realistic theory.
Blaylock's answer is MWI
stevendaryl said:
I hate it when people talk about counterfactual definiteness, because to me that sends people off onto a philosophical and meaningless discussion about whether counterfactual definiteness is a desirable property, or what it means, and whether nondeterministic theories are counterfactually definite. It's a mess that doesn't make any difference. It's a red herring.
stevendaryl said:
It's just that I don't think it clarifies anything. A local, nondeterministic theory violates CFD, so violating CFD is not a big deal, it seems to me, and it doesn't do anything to understand the difference between a quantum theory and a classical theory.
Blaylock makes the opposite case.
stevendaryl said:
I'm just saying that I think you're wrong. If nonlocality is defined in Bell's terms, then QM is either nonlocal, or one of the weird acausal interpretations (superdeterminism, back-in-time causality) must be true.
Again Blaylock would say MWI is local.
stevendaryl said:
I would say no. I don't consider FTL and nonlocality to be synonymous.
You may be right, but what about Blaylock's page 6?
What about BM? Or is that not classical?
There are a couple places in Blaylock's paper I found flawed. For example, the way he deals with the uncertainty principle and says p13, "Thus, a definite momentum measurement forces the physical system into an indefinite superposition of distinct position eigenstates."
But for the most part I liked the paper.
Blaylock's answer is MWIBlaylock makes the opposite case.
Well, I stand by what I said earlier. I don't think that CFD is an important element, and I don't think that lacking CFD is a very useful way to talk about MWI. To me, MWI is not a realistic model, in the sense that questions along the lines of: "Will Bob measure spin-up along axis [itex]\vec{a}[/itex]?" don't have answers. EPR, in talking about "elements of reality" were making the assumption that Alice, by measuring spin-up along axis [itex]\vec{a}[/itex] was learning something definite about Bob far away--that he will definitely measure spin-down along that axis. MWI abandons the assumption that Alice learns anything at all about Bob. There is no "fact of the matter" about what result Bob will get. It's not just failure of CFD, which as I said, is a feature of most stochastic models. It's not just that what Bob would have gotten if he had performed a different measurement is undefined---in MWI what he ACTUALLY got was undefined. He got spin-up and he got spin-down.
So I don't agree with Blaylock's way of putting it.
The other point of disagreement is that I don't consider MWI local. In MWI, the state of the universe is the wave function, and the wave function is not a local model. The wave function is a function on configuration, not on physical space, while a local model in the sense of Bell is one where there is a state of the universe that "factors" into states of local neighborhoods of the universe. That isn't the case with MWI.
MWI does not have FTL influences, but it isn't a local model in the sense of Bell.
And for Blaylock that implies nonCFD.
OK, to each his own.
There is interesting statement toward the end of the paper:
Blaylock said:
The many-worlds interpretation is not only counterfactually indefinite, it is factually indefinite as well.
So we might ask if according to author it is counterfactual definiteness that is questioned or is it rather factual definiteness that should be given up to keep locality.
