What is the probability that a subgraph of a connected graph is also connected?
  • Thread starter Thread starter samirg
    Graphs
The discussion revolves around determining the probability that a subgraph of a connected graph remains connected. The initial query lacks specifics about the original graph, making it challenging to provide a definitive answer. A "star graph" example illustrates that certain structures guarantee subgraph connectivity, while others do not. The problem is further refined to a random graph G(n,p), focusing on subgraphs defined by distance from a fixed node. The conversation emphasizes the need for clarity regarding graph properties to accurately assess connectivity probabilities.
samirg
Hi Guys
I need some help on graph connectivity problem.
Given a graph is connected with probability p, what is the probablity that its subgraph is also connected?
In other words, we have to find the probablity that a subgraph of a connected graph is connected?
I hope i have made my question clear. Any help in this matter is really appreciated.
Thanks
Samir
Mathematics news on Phys.org
It is impossible to answer the question without you saying more about the original graph. Given a "star graph" ie one central node and all vertices rays from it, then any subgraph must be connected, given another graph this will almost certainly fail to be true.
connectivity of graph(problem redefinition)
Hi matt
The problem can be stated as
Given a random graph G(n,p) where n is number of nodes in the graph and p is the probability that an edge exits between two nodes, (when p=0 graph does not have any edges and when p = 1 graph is fully connected.) then if i take a subgraph of this random graph based on criteria that all the nodes of this subgraph are at a particular distance from one fixed node, then what is the probability that this subgraph is connected? I want to know whether this probability will be less than p, and if yes how much less?
I hope this makes question a bit clearer.
Thanks again
Samir
Double and triple posting is generally frowned upon.
Now you've introduced the word distance. the usual distance on graph is the length of the shortest path between nodes, which when defined explicitly tells you the subgraph you've picked must be connected (assuming the fixed node is in the subgraph).
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
