What is the purpose of calculus and how can it be applied?
  • Thread starter Thread starter mitch bass
    Calculus
Calculus was developed to address fundamental problems in physics, particularly relating to motion and gravity, as exemplified by Newton's theories. It provides tools to calculate instantaneous rates of change, such as speed and acceleration, which cannot be determined from a single observation. The concept of differentiation allows for the determination of the slope of a curve at a point, while integration enables the calculation of areas under curves, essential for understanding varying forces. These mathematical methods are crucial for solving real-world problems where forces and motions are not constant. Overall, calculus serves as a foundational tool in both theoretical and applied physics.
mitch bass
Did Newton invent calculus to help him work out his theories on gravity? What is calculus used for? What does it do? Excuse my utter ignorance on the subject please, but I would very much like to know the purpose of calculus and what it has the potential to do.
Mathematics news on Phys.org
It's much more general than that but, in part, Newton developed the calculus to deal with gravity. Newton, along with many other people, recognized that, if one assumed that the force of gravity depended on the distance, then the motion of the planets could be explained by the same laws as objects falling on earth. However, there was a "conceptual" problem with that.
Do this "thought" experiment: Imagine yourself in a rocket ship high above the ecliptic. Take a photograph that includes both the Earth and the moon at a specific instant. You could use that photograph to measure the distance from the moon to the earth. You could NOT, of course, determine the speed or acceleration of the moon relative to the Earth from the photograh: the photograph is at a specific instant. You can't measure motion at a specific instant.
(A common high school physics experiment: use strobe lights to get a picture of a ball at several points in its trajectory- use that to measure the speed and acceleration of the ball. Of course, that won't work if you only have ONE picture of the ball.)
That's the conceptual problem: If the gravitational force depends on distance, then it would be theoretically possible to measure the distance between two bodies AT A GIVEN INSTANT, calculate the gravitational force and then use "F= ma" to calculate the acceleration AT THAT INSTANT. Yet the very concept of acceleration (or speed) AT A SINGLE INSTANT doesn't make sense. That was part of "Zeno's paradox".
Calculus was developed to make sense of the concept of "speed" and "acceleration" at a given instant.
Have you ever drawn a curved graph? Suppose you pick two points on the graph curve, P1 and P2, and draw a line between them. Now, you move P2 along the curved steadily towards P1, until you get to the point where P1 is infinitely close to P2. Of cause, you never get there but by mathematical methods you can work out what this value tends to, and this gives you the instantaneous derivative, or rate of change at that point. It gives you the gradient of the tangent, so to speak. Suppose you have an equation for the speed of an object using time. Differentiation can tell you the rate of change of speed, it's acceleration at any given moment.
Integration does the opposite. By taking the integral of a curve, you effectively split the graph's are into an infinite number of trapeziums, each with 0 width. By mathematical method, you take the sum of them, and hence get a perfect value for the area under the curve. With the previous equation, you can work out the total distance traveled at each moment.
Newton applied calculus for his work in physics but Liebniz's work was more theoretical.
One example of integration is work. In a non-Calculus based Physics course, work is defined as force times displacement (W = fs)
That's great for the ideal world but in the real world the force is not going to be constant, so what do we do? Here's where Calculus comes into place. First we take a very small distance and find the work performed there. We do this over the interval and then add up each individual work. This should give us the work performed on the interval where a variable force is involved.
Mainly, calculus was found to solve three problems :
1-The instaneous speed problem.
That is the problem that HallsofIvy exaplained, in fewer words, it is the problem of finding the velocity at a certain instant knowning the graph of displacemet versus time.
2-The tangent line problem.
This problem is very well connected to problem1, it is problem of finding a tangent line of a graph on a certain point.
3-The area under graph problem.
The part of calculus that solves this problem is called integration. The idea of integration (mainly) is to find the area between a graph and the X-axis (normally), this can turn very usefull in problems like the one described by Sting (also -for example- in finding equations of gravitational potential energy between objects in space)
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
