What Is the Radius of Curvature of Space on Earth's Surface Due to Its Mass?
  • Context: Undergrad
  • Thread starter Thread starter Jaime Rudas
    Curvature Earth Radius
The discussion revolves around the concept of the radius of curvature of space on the Earth's surface due to its mass, exploring the implications of spacetime curvature and its relationship to gravitational effects. Participants examine theoretical aspects, mathematical formulations, and conceptual clarifications related to curvature in the context of general relativity.
  • Some participants assert that spacetime is what is curved, not just space, raising questions about the implications of this curvature on spatial geometry.
  • There is a distinction made between extrinsic curvature, quantified by the radius of curvature, and intrinsic curvature, which is more relevant in the context of spacetime.
  • One participant proposes that if spacetime is curved, it could imply that space is also curved, prompting further exploration of this idea.
  • Another participant mentions the weak-field approximation and suggests that the quantity ##R=c^2/g## can be considered as a measure of spacetime curvature, leading to a numerical estimate of approximately ##9.2 \cdot 10^{15}## meters.
  • Discussions arise about the nature of spatial curvature in relation to uniform mass density spheres and the transition of scalar curvature at the surface of such spheres.
  • There are references to the challenges of deriving formulas related to curvature and the importance of understanding the underlying principles of spacetime geometry.
  • Some participants express uncertainty about the implications of curvature for observers at rest on the Earth's surface and the smoothness of curvature despite potential discontinuities in stress-energy tensors.
  • The concept of sectional curvature is introduced as a way to visualize curvature in higher dimensions, emphasizing the complexity of characterizing curvature in different directions.
Participants exhibit a range of views, with no consensus on the implications of spacetime curvature for spatial curvature. Some agree on the mathematical formulations presented, while others challenge the interpretations and relevance of these concepts.
Limitations in understanding arise from the complexity of curvature definitions, the dependence on specific approximations, and the unresolved nature of certain mathematical steps in deriving curvature measures.
Jaime Rudas
"Matter tells spacetime how to curve, and curved spacetime tells matter how to move"
Taking the above into account, the space on the Earth's surface is slightly curved. What is the radius of curvature of space on the Earth's surface due to its mass?
1) It's spacetime that is curved, not space.
2) Radius of curvature quantifies extrinsic curvature, but spacetime curvature is intrinsic.
3) Note that the spacetime curvature is related to tidal forces or gradient of the gravitational field strength, not to the field strength (gravitational acceleration) itself.
Yes, matter curves spacetime, but if spacetime is curved couldn't it imply that space also curves?
I understand that space can also have intrinsic curvature and, if this is homogeneous, its radius can be determined. Am I wrong?
Not exactly, although the concept is of relatively little usefulness.
If we're working in the weak-field approximation (appropriate in the vicinity of the earth) we can consider the quantity ##R=c^2/g## to be the curvature of spacetime. This being an I-level thread, you might want to try deriving this formula for yourself: consider a ball thrown straight up into the air and falling back to earth on a geodesic trajectory, look for the radius of a circle that intersects the three events ball thrown, ball reaches maximum height, ball back on earth again.
##R=c^2/g≈9.2\cdot 10^{15}## m
Could it then be said that the radius of curvature of space on the surface of the Earth is approximately ##9.2\cdot 10^{15}## meters?
It's the curvature of spacetime, but yes, that's about the right order of magnitude. It's more or less one light-year.
No one can make someone else exercise, but that's never stopped anyone from handing out advice to do so: trying to derive that formula would be a good exercise that will tell more than any number of questions here.
Yes, I understand that it is the curvature of spacetime, but doesn't that imply that space is also curved?
Yes, I'm trying to derive the formula, but I'm afraid I don't have enough knowledge.
Jaime Rudas said:
Yes, I understand that it is the curvature of spacetime, doesn't that imply that space is also curved?
Kinda sorta, yes. But spacetime can be split into time and space in multiple more or less arbitrary ways, leading to different values for the "curvature of space".
The spatial curvature for a uniform mass density sphere, in the rest frame of the sphere, is described here:
https://en.wikipedia.org/wiki/Interior_Schwarzschild_metric#Visualization
At the surface of the sphere the spatial scalar curvature goes from positive (sphere interior) to negative (sphere exterior), so it is zero.
A radius of curvature describes the extrinsic curvature of 1-dimensional object (a curve). With higher dimensional objects you don't have a single extrinsic radius of curvature, but several of them. You can combine them, for example buy multiplying, and relate that to intrinsic curvature measures:
https://en.wikipedia.org/wiki/Gaussian_curvature
Oh, is it smooth even with the discontinuity of the stress energy tensor?
Of course, this is assuming that you are defining space as orthogonal to the timelike Killing vector field.
You have three points (in spacetime not space!). For any three points there will be only one circle that passes through all three. What is the radius of that circle?
I see, but for an observer at rest on the surface of the Earth, what would be the curvature of space?
Good point. Not sure about that.
Kinda sorta. One can't exactly say this kind of hand-waving argument is wrong, since even Misner, Thorne, & Wheeler give it in an early chapter of their classic GR textbook, but it's still a hand-waving argument that doesn't really get where it needs to go. It is best viewed as a vague heuristic that can be used to motivate a more detailed investigation.
As was already said, spacetime curvature is tidal gravity. The tidal gravity near the surface of the Earth is approximately ##M / R^3## in geometric units, or ##GM / c^2 R^3## in conventional units. We can of course use ##g = GM / R^2## to rewrite this as ##g / c^2 R##, and then we can wave our hands and say that ##c^2 / g## is sort of like a radius of curvature, but there's still that other factor of ##R## there which is the radius of the Earth. (And there's also a factor of ##2## that appears if you're talking about radial tidal gravity as opposed to tangential.)
Yes. A proper model will make use of the appropriate junction conditions at the boundary that enforce the smoothness.
The key point is that "space curvature" doesn't predict anything. Spacetime curvature is what makes physical predictions.
A geometry of two dimensions, like the surface of a sphere or an egg, has a single number that characterizes it's intrinsic curvature at each point. The "radius of curvature" is defined as the inverse of the square root of the curvature. In three or higher dimensions, to characterize the curvature in different directions you need more numbers.
One intuitive way to visualize this is in terms of what are called "sectional curvatures". To define a sectional curvature at a point, you choose a 2d tangent plane localized at that point, and shoot out geodesics in all directions emanating from that point and tangent to that plane. This generates a 2d surface in the higher dimensional space or spacetime.
That 2d surface has an intrinsic metric, inherited (i.e. induced) from the metric of the ambient space, and the curvature of that surface at the origin point is the sectional curvature associated with that plane. The collection of sectional curvatures associated with all the 2d planes at a point determines all the information contained in the Riemann curvature tensor at that point.
Now, we can interpret your question as asking what are the sectional curvatures at a point on the surface of the Earth. It we choose, as you suggest, a frame at rest with respect to the surface of the Earth, we could consider for example the sectional curvature associated with a plane tangent to the surface of the Earth, or a vertical plane.
The latter is -2 times the former, and the former is GM/r^3c^2 = g/(c^2r), where r is the radius of the Earth, so the vertical-horizontal sectional curvature is positive, and its curvature radius is√c^2r/g ~ 2 x 10^11 meters, while the horizontal-horizontal sectional curvature is negative, and its curvature radius is 4 x 10^11 meters. [If you add two orthogonal vertical-horizonal curvatures to the horizontal-horizontal one you get zero. This means that the curvature scalar of the spatial geometry in the rest frame of the Earth is zero at the surface, which is correct since the stress tensor vanishes outside the matter of the Earth.]
I would not be that harsh to spatial curvature. Hypothetically, if somebody wanted to build some giant structure around and/or inside a massive object, he would have to factor the non-Euclidean geometry of space into the design.
This implicitly defines "space" the way @Dale did in post #10--but that definition is not frame-dependent because the timelike Killing vector field, in spacetimes that have one, is an invariant geometric property of the spacetime. So the "space" defined this way does actually have a frame-independent geometric meaning. "Space" in general in GR does not.
I objected to the statement that spatial curvature doesn't predict anything. Now we are already talking about frame-dependent vs. frame-independent predictions.
Also, I would say that definitions which imply a reference frame, are actually frame-independent.
Like in: "velocity" is frame-dependent, but "velocity relative to ..." is frame-independent.
In this case, the amount of building material needed to build a structure near/inside a given massive object is a frame-independent prediction.
Yes, to be more precise I should have added a qualifier that the "space" whose curvature is being evaluated is not picked out by any invariant geometric property of the spacetime.
To be more precise, we are talking about predictions that can be grounded in invariant geometric properties of the spacetime, vs. predictions that can't.
Yes, because the structure itself, as well as the massive object, are static--which means their worldlines are orbits of a timelike Killing vector field that is hypersurface orthogonal. That is the invariant geometric property of the spacetime that makes the prediction invariant.
It doesn't. A counterexample is Robertson-Walker metric with ##k=0##.
Just to add one more thing. There is no such thing as "the space". Given a spacetime there are many ways to pick a space and a time (excluding those where you cannot at all). So a question about the curvature of the space is meaningless without additional information. And one more, there are different notions of curvature and in general it is not just a number, so any question about "the curvature" is also meaningless without more information.
"Space, the coordinate-dependent frontier..."
Yes, but I am referring to the particular case of space on the surface of the Earth.
And what do you mean by that?
As @Dale said, the "space" we are talking about consists of "pieces of local spacelike planes" orthogonal at each point to the timelike Killing vector field (assuming it exists for the given spacetime). However such "local spacelike planes" in general will not combine/match up giving rise to spacelike hypersurfaces.
It still depends on how you pick "space". In Painleve coordinates on Schwarzschild spacetime, for example, "space" is flat (Euclidean 3-space) even though spacetime is curved. In other words, just saying "space on the surface of the Earth" still does not pick out a unique "space".
If we take ##x## , ##y## , as the horizontal directions, and ##z## as the vertical one, then the horizontal-horizontal sectional curvature should be ##R_{xyxy} ## (up to notation convention; I take it from do-Carmo's book on Riemannian geometry, English translation). The vertical-horizontal sectional curvatures are ##R_{xzxz} ## and ##R_{yzyz}## . How does the vanishing1 of the stress tensor infer the vanishing of ##R_{xyxy} +R_{xzxz}+R_{yzyz}## ?
1 The Earth has an atmosphere, but who cares?
  • · Replies 29 ·
  • · Replies 29 ·
