What is the range of optical frequecy?
The discussion revolves around the definition and scope of "optical frequency" within the electromagnetic spectrum. Participants explore whether this term encompasses only the visible part of the spectrum or if it includes a broader range of frequencies.
  • Some participants suggest that "optical frequency" may refer to the entire electromagnetic spectrum, while others argue it is limited to the visible spectrum.
  • One participant notes that frequency applies to all waves, including electromagnetic radiation, but questions whether "optical" should be restricted to visible light.
  • Another participant explains that "optical" generally refers to frequencies suitable for conventional optical elements, indicating a range from infrared to ultraviolet, while acknowledging the limitations of this definition.
  • There is mention of a crossover region in the far infrared where quasi-optical elements can be used, suggesting complexity in defining the boundaries of "optical frequency."
Participants do not reach a consensus on the definition of "optical frequency," with multiple competing views remaining regarding its scope.
The discussion highlights the ambiguity in the term "optical" and its dependence on the context in which it is used, as well as the practical limitations of optical elements at various frequencies.
faryafada
I see the term o"ptical frequency" in some articles. From Wikipedia I read that it means the whole EM spectrum. But something says to me it may be only the visible part of the spectrum. Now, which definition is correct?
Thanks
Frequency is a term that applies to all waves. Electromagnetic radiation, including visible light and all the rest of the spectrum, is waves, so the whole spectrum has frequency, but "OPTICAL" frequency would seem to me to be limited to the visible spectrum but perhaps not.
The term "light" is often used as a stand-in term meaning all electromagnetic radiation, so maybe this is the same kind of loose usage.
There is no exact definition of "optical", but it generally refers to frequencies where you can use conventional optical elements (mirrors, optical fibers etc) to guide the light. From a practical point of view this means infrared to UV.
At frequencies lower than that you need to start using antennas etc (although there is a cross-over region in the far infrared where one can use quasi-optical elements), and at higher frequencies it is very difficult to make lenses etc.
Thanks. Quite useful! :)
  • · Replies 21 ·
  • · Replies 29 ·
  • · Replies 29 ·
