What is the rate of motion in Right Ascension for the asteroid?
The discussion focuses on calculating the rate of motion in Right Ascension for an asteroid using two different methods: Right Ascension values and Time Index values. The Right Ascension values provided are 23:03:53.99 and 23:03:49.17, resulting in a distance of 4.82 seconds. The Time Index values are 12:16:58 UTC and 4:39:04 UTC, yielding a time difference of 17,762 seconds. The calculations yield rates of motion of 0.32133 seconds/degree using Right Ascension and 1184.13 seconds/degree using Time Index, highlighting the importance of using the correct units for the final rate in seconds of arc/hour.
  • Understanding of Right Ascension and its measurement in astronomy
  • Basic knowledge of time conversion and units (seconds to hours)
  • Familiarity with astrometric calculations and rate of motion
  • Ability to perform arithmetic operations with time and angular measurements
  • Learn about astrometric calculations in astronomy
  • Study the conversion of angular measurements from degrees to seconds of arc
  • Research the significance of Right Ascension in celestial navigation
  • Explore the use of time indices in astronomical observations
Astronomy students, astrophysics researchers, and anyone involved in astrometric measurements and calculations related to celestial objects.
Haseo Antares
1. Homework Statement
This is an Astrometry problem. I am not sure or how exactly to proceed:
Data:
First off, I am unsure which data points to use. Should I use the values from right ascension or the values from the time index.
1 hour = 15 degrees
24 hours = 360 degrees
Image 01 Right Ascension: 23:03:53.99
Image 02 Right Ascension: 23:03:49.17
Image 01 RA - Image 02 RA = 23:03:53.99 -23:03:49.17 = 00:00:04.82
Image 01 Time Index: 12:16:58 UTC
Image 02 Time Index: 4:39:04 UTC
Image 01 Time Index - Image 02 Time Index = 4 hours 56 minutes 2 seconds = 17,762 seconds
Question:
Calculate the rates of motion in Right Ascension (seconds/hour) of the asteroid:
Rate = Distance/Time
With values from Right Ascension[/B]
4.82 sec/ 15 degrees = 0.32133 (3 repeats) sec/deg
OR
With values from Time Index
17,762 sec/ 15 degrees = 1184.13 (3 repeats) sec/deg
You're supposed to calculate the rates in sec of arc/hour, which is not the same units as sec (of time) / deg.
Thank you for the response SteamKing.
I'm not sure I understand. Can you expand on that? I'm also confused on which value I am supposed to use - the Right Ascension value or the rime index value?
  • · Replies 22 ·
