What is the relationship between heat, temperature, and measurements in joules?
The discussion centers around the relationship between heat, temperature, and measurements in joules, particularly in the context of an experimental investigation for a Junior Certificate in Ireland. Participants explore the concepts of heat as energy and temperature as a measurement of that energy, while also addressing the application of Joule's Law and specific heat capacity in an experimental setup involving water heating.
  • Homework-related
  • Tom expresses uncertainty about the relationship between heat and temperature, specifically how to relate Celsius measurements to joules.
  • Tom describes an experimental setup involving measuring the heating effect of a circuit on water, noting variability in temperature readings due to external factors.
  • Another participant suggests using the formula Q=mc(dT) to calculate heat in joules, where Q is heat, m is mass, c is specific heat capacity, and dT is the temperature difference.
  • Tom attempts to apply the formula and calculates a value of 6.279J based on his measurements, expressing uncertainty about his calculations.
  • A later reply confirms that Tom's approach to the calculation is correct.
Participants generally agree on the formula to use for calculating heat in joules, but there is no consensus on the accuracy of Tom's specific calculations or the implications of the variability in his experimental results.
Tom's results are noted as "a little weird," indicating potential issues with consistency or accuracy in the experimental setup, but no specific limitations or corrections are provided.
Students conducting experiments related to heat and temperature, educators teaching concepts of thermodynamics, and individuals interested in practical applications of Joule's Law and specific heat capacity.
tomMccune
Hi everyone,
I have an investigation to carry out for my Junior Certificate in Ireland. What I'm not sure about is the link between heat and temperature. I know that heat is energy, and temperature is the measurement of this energy, but I'm not sure what the link between celsius and joules is.
1. Measure the relation between the current of a circuit and the heating effect produced by that circuit2. Joule's Law - W = (I^2)(R)(t) (I'm sure this comes into it somewhere, my teacher has brought it up.
3. The way that my partner and I have carried out the experiment is:
We would measure 50ml of water and pour it into a polystyrene cup. We would then use a digital thermometer to get a reading of the temperature of the water as a control. This varied each time we got new water and measured it, probably due to weather, humidity etc. We would connect a battery to a rheostat (variable resistor), then to an ammeter, then to a wire coil, which would be submerged in the water in the polystyrene cup, then back to the other battery terminal. So, we have been waiting 8 minutes for the water to heat up, each time with a different current, then measuring the temperature of the water and the increase from the control. How would this be relavent to a measurement in joules (What formula would I use to convert my readings in celsius to Joules?)? I don't get it at all.
Here are our results (A little weird, but we can... edit them, I know they're supposed to be directly related).
Thanks for any help, I hope I've been clear enough.
Tom.
use Q=mc(dT)
Where is the mass of water
c is the specific heat capacity of water
dT is th temperature difference.
Thanks. To see if I've got it right:
Q (heat in joules) = m (mass of water, 50ml/cc) x c (heat capacity of water, 4.186j/cm2) x dT (Difference from control, 0.03'C)
= 6.279J
Sorry if I got that completely wrong, I've never done anything like that before.
yep, that would be the correct way to calculate it.
  • · Replies 28 ·
10K
