What is the speed of the string? (wave problem)
  • Thread starter Thread starter bored2death97
    Speed String
The speed of a wave traveling along a spring is determined by the equation v = √(T/μ), where T is tension and μ is mass per unit length. When the radius of the string is doubled, the mass does not simply double; instead, it increases by a factor of four due to the area of the cross-section being proportional to the square of the radius. Consequently, the new speed of the wave becomes v0/2, as confirmed by the discussion participants. The misunderstanding arose from incorrectly assuming that doubling the radius would double the mass.
  • Understanding of wave mechanics and wave speed equations
  • Familiarity with the concepts of tension and mass per unit length (μ)
  • Basic knowledge of geometry related to circles and areas
  • Ability to manipulate algebraic equations
  • Study the relationship between radius and mass in circular cross-sections
  • Learn about wave propagation in different materials and conditions
  • Explore the effects of tension on wave speed in various mediums
  • Investigate the implications of mass density on wave behavior
Students studying physics, particularly those focusing on wave mechanics, as well as educators seeking to clarify concepts related to wave speed and material properties.
bored2death97
A wave travels along a spring at speed v0. What will be the speed if the string is replaced by one made of the same material and under the same tension but having twice the radius.
Answer in book says (v0/2)
v=√(T/μ)
speed= square root of (tension divided by mu)
μ=m/L
mu= mass/length
With the first equation I filled in the equation for mu. Assuming twice the radius would mean twice the mass, I multiplied mass by 2.
v=√[T/(2m/L)]
v=√(TL/2m)
Then if I were to take the value of 2 out of the square root, I would get v=0.707[√(TL/m)]
Rearrange and get v/0.707
So where did I go wrong??
v=√(T/μ)
μ=m/L
mu= mass/length
v=√[T/(2m/L)]
v=√(TL/2m)
Twice the radius doesn't mean twice the mass. If you double the radius of a circle by what factor does the area increase?
It increases by a factor of 4. Thank you.
  • · Replies 29 ·
