What is the tension in the coupling
  • Thread starter Thread starter 8parks11
    Coupling Tension
The discussion revolves around calculating the tension in the coupling between the third and fourth cars of a train, which consists of 14 cars each weighing 53,000 kg, while the train accelerates at 0.26 m/s². The initial approach to find tension using the formula F=ma was questioned, particularly regarding the relevance of the specific cars mentioned. Participants also introduced a separate problem involving the hoisting of a rock, which requires understanding the relationship between force, mass, and acceleration. The calculations for both scenarios highlight the complexities of applying physics principles to real-world problems. Ultimately, the conversation emphasizes the need for clarity in problem setup and the correct application of formulas to derive accurate results.
8parks11
An inter city Express locomotive pulls 14 cars, each with a mass of 53,000 kg. What is the tension in the coupling between the thrid and fourth cars when the acceleration of the train is 0.26m/s.
ok so I am looking for T.
F=ma
53000(0.26) = T?
i don't think this is correct because they mentioned 3,4 cars
or was that just random?
I don't know at all.
Added:
a) What is the minimum time in which one can hoist a 1.00-kg rock height of 10.0m if the string used to pull the rock up has a breaking strength of 10.8 N? Assume the rock to be initially at rest.
b) If the string is replaced by one that is 50% stronger, by what percentage will the minimum time for the hoist be reduced.
alright a) i just used a= 2(x-xo)/t^2 and then i got 2(10)/t^2 = 10.8/1
so i got 10.8=20/t^2 and so t would be root 10.8 but the answer is 4.5s... why??
b) i need to get a) to solve this...
Don't you have an idea about the whole system?
Your whole system is 14 cars, being pulled by a train with an acceleration of 0.26 m/s^2. Think about the problem of the 3 blocks (between each block there's a string) being pulled by a force F.
so there is T1 T2 and T3 and i have to find T3.
isnt T3
F=ma
F= (m1+m2+m3).26
so it would be 3(53000)(0.26) = T?
