Does pressure change along a vertical path with pressurized fluid at 70psi?
  • Thread starter Thread starter Kaly
    Pressure Value
The discussion centers on the behavior of pressurized fluid in a closed-loop system at 70 psi, specifically regarding pressure changes along a vertical path. It is established that fluid pressure increases with depth due to the weight of the fluid column, similar to underwater pressure dynamics. The configuration involves a pump that raises fluid two stories high, followed by horizontal movement and a return to the pump. The pressure at ground level will indeed be affected by the vertical height of the fluid column, regardless of the system being closed or open.
  • Understanding of fluid mechanics principles
  • Knowledge of pressure dynamics in closed systems
  • Familiarity with hydraulic systems and pumps
  • Basic concepts of fluid statics and dynamics
  • Research the principles of fluid statics and how pressure varies with depth
  • Study the effects of closed-loop hydraulic systems on pressure distribution
  • Learn about the Bernoulli equation and its applications in fluid mechanics
  • Examine case studies of similar pressurized fluid systems in engineering
Engineers, fluid mechanics students, and professionals involved in designing hydraulic systems or analyzing fluid behavior in pressurized environments will benefit from this discussion.
Kaly
Hello, I am willing to know if the value of pressurized fluid along a rectangular path placed normal to ground (let's say 2 stories high) would show any change in pressure along the lines normal to ground. I am not worried where fluid would move horizontal to ground but what would happen when it rises or falls? would pressure change? or remain same if it is pumped at 70psi pressure let's say.
Welcome to the PF.
Could you please post a sketch of the configuration of the tank and pump? Fluid pressure increases as you go deeper in the vertical direction, just as you experience a greater pressure as you dive deeper underwater. Is that what you are asking about?
Thank you for the comment. Path is rectangular in shape. but it is closed loop so not really exposed to atmosphere. The pump sits on ground. It first pushes liquid 2 stories high. At the top fluid then it follows horizontal path then the fluid falls by 2 story height and again it flows though horizontal path, reaches the pump and is pumped again 2 story high. I am not sure if not being exposed to atmosphere keeps the value of pressure same through out the path? or no matter the system being closed or open the vertical height of water column would add to pressure at ground level.
How much formal Fluid Mechanics training have you had? If you had a course, what was covered?
Kaly, Is this a real system or just a problem someone has given to you?
  • · Replies 30 ·
  • · Replies 31 ·
  • · Replies 24 ·
