gbfmgbfm
- 28
The 4-velocity of a photon is undefined, so does that mean the velocity of a photon is undefined?
What is the velocity of a photon?
PAllen said:The OP was a little vague on context. In flat spacetime (SR), it is c. In GR, it is c for a 'local measurement' - small distance. Otherwise, it will not necessarily be c, and will depend not only on the geometry, but also on how you intend to measure it (in particular, there isn't a unique definition of large distances; therefore there cannot be a unique definition of any speed as non-local measurement). Mathematically this manifests as 3-velocity of null geodesics in GR is coordinate dependent; there is no way to pick unique preferred coordinates; and no way to pick coordinates such that 3-velocity is c for all null geodesics.
gbfmgbfm said:You write, "Otherwise, it will not necessarily be c, and will depend not only on the geometry, but also on how you intend to measure it."
So, you are saying that sometimes the velocity of light is not c in a vacuum? Who has experimentally proven this?
Naty1 said:no.
locally, the speed of light is always c.
PAllen said:The Shapiro time delay is normally interpreted as such a measurement: http://www.astro.ucla.edu/~wright/deflection-delay.html
gbfmgbfm said:So as you state that the velocity of light is not c in some cases (violating Einstein's second postulate), are you saying that Einstein's relativity is violated in these cases?
1. First postulate (principle of relativity)
The laws by which the states of physical systems undergo change are not affected, whether these changes of state be referred to the one or the other of two systems of coordinates in uniform translatory motion.
2. Second postulate (invariance of c)
As measured in any inertial frame of reference, light is always propagated in empty space with a definite velocity c that is independent of the state of motion of the emitting body.
Indeed.PAllen said:These are postulates of special relativity. For general relativity, they remain true locally, but are not even well defined globally.
gbfmgbfm said:So locally, the velocity of a photon is always c. Then why is the four-velocity of a photon undefined?
gbfmgbfm said:The 4-velocity of a photon is undefined, so does that mean the velocity of a photon is undefined?
PAllen said:Because 4 velocity is derivative with respect to proper time along a world line. Light follows a null world line, which means proper time is 0 between any two points on it, so said derivative cannot be defined.
As has already been said, 3-velocity is readily defined (derivative of spacelike coordinates by timelike coordinate), and is c for any inertial frame in SR (using reasonable coordinates). For GR, re-read what I've already said.
robphy said:To add to Meir Achuz's reply...
the spatial velocity of any particle, according to inertial observer Bob,
can be defined by taking the 4-momentum vector of that particle and
breaking it into temporal- and spatial-components (according to Bob),
then forming the ratio of the [vector] spatial-compenent to the [scalar] temporal-component.
The result is the spatial-velocity [sometimes called 3-velocity] of the particle according to Bob.
This works whether the particle is timelike or lightlike.
The 4-velocity, however, can be defined as the 4-momentum divided by its magnitude (the square-root of the square-norm)... i.e. it's a unit-vector. This is fine for a timelike particle. However, it doesn't work for a lightlike particle since the square-norm of its 4-momentum is zero. Thus, the 4-velocity cannot be defined for a lightlike particle.
In equations...
Let [itex]\vec p[/itex] be the particle's 4-momentum.
If it's not lightlike, then we can define its 4-velocity [tex]\hat v = \frac{\vec p}{\sqrt{\vec p \cdot \vec p} }.[/tex](You could call it [itex]\hat p[/itex], if you wish.)
Let [itex]\hat t[/itex] be Bob's 4-velocity
so that the particle's 4-momentum (whether timelike or lightlike) can be written as
[itex]\vec p= \vec p_{\| \hat t} + \vec p_{\perp \hat t}= E \hat t + \vec P = E(\hat t + \vec V)[/itex].
(If it were timelike, then [itex]\hat v=\gamma \hat t + \vec S = \gamma (\hat t + \vec V)[/itex].)
The spatial-velocity of the particle according to Bob is the spatial vector (i.e. [itex]\vec V \cdot \hat t=0)[/itex]:
[tex]\vec V=\frac{ \vec p_{\perp \hat t} } { \sqrt{\vec p_{\| \hat t}\cdot \vec p_{\| \hat t} } }= \frac{\vec P}{ E}[/tex]
A photon has no quantity called its 4-velocity.gbfmgbfm said:So if the 4-velocity cannot be defined for a photon, can we say that the photon has no 4-velocity, but only a 3-velocity?
robphy said:A photon has no quantity called its 4-velocity.
According to an inertial observer, a photon has a 3-velocity whose magnitude is c.
gbfmgbfm said:How does a photon move relative to the fourth dimension?
robphy said:It traces a line in spacetime [as it would on an ordinary (3D-)position-vs-time graph].
gbfmgbfm said:What is the photon's velocity relative to the fourth dimension?
robphy said:That doesn't make any physical sense. Relative-velocities are defined between particles... in the simplest case, between two inertial worldlines that cross at an event.
Sure. That is a 3-velocity, not a 4-velocity.gbfmgbfm said:But can we not define the velocity of a photon relative to a point x1=0, x2=0, x3=0, where it starts from?
Do we not say that the photon's velocity is c relative to this point?
DaleSpam said:Sure. That is a 3-velocity, not a 4-velocity.
Note, this does not contradict what robphy said. The point x1=0, x2=0, x3=0 can represent a particle, specifically a particle which is at rest at the origin. It may be hypothetical, i.e. there need not be an actual particle at rest there. The point is more that relative velocity is defined between two worldlines. Are you familiar with the term "worldline"?
gbfmgbfm said:Dear Dale,
Suppose we define a point (x1=0, x2=0, x3=0, x4=0). What is a photon's velocity relative to that point?
PAllen said:That's not meaningful as stated. It can be made meaningful, as follows: what is speed of photon whose world line passes through (t,x,y,z)=(0,0,0,0) relative to a timelike worldline passing through the same event? The answer is c.
(My comments about light traveling different speed than c only apply to a non-local measurement in GR. For the only natural interpretation of your question, as given above, the answer is c, period).
gbfmgbfm said:How is the following statement not meaningful?
"Suppose we define a point (x1=0, x2=0, x3=0, x4=0). What is a photon's velocity relative to that point?"
Where does the simple question err? What law is the question violating?
PAllen said:What is your definition of velocity? When I say it makes no sense as stated I mean that without more qualification it fails to be any of the following:
1) A relative velocity - need two world lines for that, one timelike.
2) A coordinate velocity - well, you could make this apply, but then you 'relative to an event' makes no sense. You could ask for coordinate velocity of a photon passing through an event, at that event . Big surprise - the result is coordinate dependent in GR, and c for any reasonable coordinates for an inertial frame in SR.
3) A 4-velocity: impossible to define for a photon.
gbfmgbfm said:I define velocity as velocity. How do you define velocity?
