High School What is the work function of graphene sheets?
The work function of graphene sheets varies based on factors such as growth method, metallic substrate, and environmental conditions. For applications like ionizers that require high electron generation, precise measurements or references under similar conditions are essential. Graphene's interaction with oxygen is limited, leading to speculation about the potential benefits of using carbon oxide instead. The discussion also touches on the photoelectric effect and its applications in solar energy, suggesting innovative methods for creating low-cost photoelectric cells using graphene. Overall, understanding these variables is crucial for optimizing graphene's performance in electronic applications.
Javier Lopez
I have found different values depending where is read.
I should like have a graphene sheet on copper to be used in a ionizer to generate lots of electrons
It is because it depends on the growth method, the metallic substrate, and the physical environment of the graphene (in vacuum as opposed to exposing it in air), among other things. Either you find a reference that has the graphene sheet in the exact same situation as yours, or you make your own measurement of the work function of your graphene.
Zz.
Likes Javier Lopez
May be. Another think is graphene does not catch oxigen, so perhaps carbon oxide one (I think exist) is better
Not exactly sure what you are talking about here.
Solar cells are PN photodiodes. The current is due to photogeneration. This is not THE standard photoelectric effect, which is the emission of photoelectron into vacuum.
Zz.
I have in general a doubth about different surface related effects: photoelectric, thermal radiation and charge density in capacitors (and perhaps some others): all are proportional to surface area, but there are several surface increasing methods asanodizing or grow nanotubes that does not increases the effect directly proportional to new surface that can be dozens times, but perhaps reduces a few the emission coefficient.
The photoelectric effect is very interesting, because if you place 2 pallalel graphene plates and heat one using sun energy and mirrors to high temperatures you could have a low cost photoelectric cell using almost all the sun spectrum :)
J.L.
Thread 'Unexpected irregular reflection signal from a high-finesse cavity'
I am observing an irregular, aperiodic noise pattern in the reflection signal of a high-finesse optical cavity (finesse ≈ 20,000). The cavity is normally operated using a standard Pound–Drever–Hall (PDH) locking configuration, where an EOM provides phase modulation. The signals shown in the attached figures were recorded with the modulation turned off. Under these conditions, when scanning the laser frequency across a cavity resonance, I expected to observe a simple reflection dip. Instead...
  • · Replies 30 ·
