What is this equation called ?
  • Thread starter rhz_prog
In summary, the conversation discusses the use of an equation, RTC7683-7, to calculate the Proper Velocity of an object as a function of time. The equation takes into account the object's velocity relative to an inertial reference frame and involves the limit of dt approaching zero. The equation can be found in the URL provided.
rhz_prog
Just got some strange equation from relativistic travel problem :
[tex]{\it PA} \left( t \right) =\lim _{{\it dt}\rightarrow 0} \left( v \left( t \right) -v \left( t-{\it dt} \right) \right) \left( 1-{\frac {v \left( t \right) v \left( t-{\it dt} \right) }{{c}^{2}}} \right) ^{-1}{{\it dt}}^{-1}
[/tex]
I use this equation to calculate the Proper Velocity of an object as a function of time PA(t) given its velocity v(t) as a function of time.
See equation RTC7683-7 in the URL below for more detail :
http://orimath.blogspot.com/2008/08/mathematical-basis-of-rtc7683.html
I want to know what this equation is called in English ?
v(t) in the question above is the velocity of the object relative to an inertial reference frame as a function over time.
What is this equation called?
This is a common question when someone encounters a mathematical or scientific equation for the first time. The name of an equation can often provide insight into its purpose or meaning.
What is the meaning of this equation?
Understanding the meaning of an equation is crucial in using it correctly. The name of the equation can give clues about its intended purpose, but it is important to also understand the variables and symbols used in the equation.
What is the history of this equation?
Many equations have a rich history, with contributions from multiple scientists and mathematicians. Learning about the origins of an equation can give a deeper understanding of its significance and relevance in the scientific community.
What are the applications of this equation?
Knowing the applications of an equation can help in understanding its real-world implications. Many equations have a wide range of uses in various fields of science and technology.
Can you explain each part of this equation?
Some equations may seem daunting at first glance, but breaking them down into smaller parts can make them easier to understand. Asking for an explanation of each part of the equation can help in comprehending its overall meaning and purpose.
