What is wrong with my thinking?
  • Thread starter Thread starter pivoxa15
    Thinking
pivoxa15
Einstein stated that the laws of physics are the same in all inertial reference frames.
Lets do the old thought experiment
There are a pair of twins each with identical watches. One remains on Earth while the other travels out into space near the speed of light and back again.
The twin on Earth will see the effects of relativity on the traveling twin because they are not in the same inertial reference frames.
To the twin inside the spaceship, his watch ticks at the same rate as his brother because the traveller and his watch are always at rest with respect to each other. The twin on Earth is also at rest with respect to his watch. Hence both twins keep their own time at the same rate (although during the trip, they will see each other differently due to relativity) .
When the traveling twin completes the trip and comes back to Earth thereby reuniting with the reference frame of his brother, the amount of time ticked off by the traveling twin should be identical to the amount ticked off by his brother who was on Earth all that time. This is because they have been keeing time in an inertial frame that is idential with each other. Hence the two twins have aged the same when they finall meet.
The aging difference should only occur when they do not meet in other words, when the are at different inertial references frames with respect to each other.
But experts have stated that I am wrong and the traveling twin will only have aged a small proportion compared to how much it has aged on earth.
Each twin's watch ticks at the normal rate in their own reference frame. However, in each twin's reference frame, the other twin's watch is genuinely ticking slower--it's not just that they see each other differently, even if the twins correct for the light delay each will conclude the other twin's clock is ticking slower than their own.
No, for the other twin to turn around and return to earth, he has to accelerate during the turnaround phase and switch into a different inertial reference frame. "Inertial reference frame" means the frame of an observer who always travels at constant velocity and never accelerates. An inertial observer traveling alongside the twin during the outbound leg would see him at rest, but then when he turns around and heads back towards earth, this inertial observer (who continues to move away from the Earth at the same constant velocity) sees him acquire a large velocity in the direction of the Earth during the inbound leg of the trip.
If you're not afraid of a little math there's an excellent treatment of this problem that I just read up on arXiv: http://arxiv.org/abs/gr-qc/0104077 . I was actually looking for a good k-calculus link to give you when I stumbled across this, it is the best treatment of the problem that I can recall seeing.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
