What is your take on random vs deterministic reality
In summary, according to the respondent, determinism cannot coexist with chaos/randomness. Randomness is different from arbitrary, because to say that a variable is random means that the variable follows a probability distribution. Chaos is also deterministic, and can be observed in systems.
Chaos/randomness is subset of determinism or vice versa?
  • Determinism is subset/emergent of purely random reality.
    Votes: 0 0.0%
  • Randomness is subset/emergent of purelly deterministic reality.
    Votes: 2 100.0%
  • Total voters
  • #36
Microscopic and Macroscopic Randomness
A common reaction to QM is that it doesn't matter since quantum randomness will never manifest itself at the macroscoic level -- that is, in the world of sticks and stones we can see with the naked eye. An appeal is usually made to the "law of large numbers", according to which random fluctuations at the atomic (or lower level) will cancel each other out in a macrscopic object, so that what is seen is an averaged-out behaviour that is fairly predictable.
Something like this must be happening in some cases, assuming QM is a correct description of the micro-world, or there would not even be an appearance of a determinstic macro-world. Since deterministic classical physics is partially correct, there must be a mechanism that makes the QM micro-world at least approximate to the classical description.
However, it it were the case that all macroscopic objects behaved in a 100% deterministic fashion, there would be no evidence for QM in the first place -- since all scientific apparatus is in the macro-world ! A geiger-counter is able to amplify the impact of a single particle into an audible click. Richard Feynman suggested that if that wasn't macroscopic enough, you could always amplify the signal further and use it to set off a stick of dynamite! It could be objected that these are artificial situations. This is rather desprate, however, because there is a well-known natural mechanism that could do the same job: classical chaos.
A clasically chaotic system is by definition one that is critically sensitive to its initial conditions. "critically" sensitive means that any variation in initial conditions, no matter how slight, can bring about a change in the macroscopic behaviour of the system, no matter how large. Since there is no lower limit to critical sensitivity, it must extend all the way "down" to me microscopic world of quantum phsyics. Thus, hurricans need not be started by butterfly wings, they can be started by electrons!
The term "classical" misleads some people. Chaos can be defined within the framework of classical physics, which is strictly deterministic. This is sometimes taken to mean any chaotic system encountered in nature (such as a weather system) is classical and deterministic. However, when we tall about ordinary, non-chaotic systems being classical, we mean they are *approximately* classical. Classical physics is not entirely wrong; it worked for 100's of years after all. But it is not entirely right either. "Classical" systems are quantum systms that approximate classical behaviour.
Thus any chaotic system that you can actually encounter, such as a weather system, is only approxiamtely classical. It has no underlying determinism. At the most fundamental level it is a quantum system -- because everything is.
So we can have classical system that behave predictably (ordinary Newtonian phsyics), quantum systems that behave predictably on the macroscopic level (through the Law of Large Numbers), classical systems that behave unpredictably (through classical chaos) and quantum systems that unpredictably on the macroscopic as well as microscopic level (chaos and othe "quantum amplifiers").
In fact, this is not just theoretical. Conventional big-bang theories generally require an input of quantum indeterminism to provide the large-scale structure of the universe. A singularity exploding according to classical laws would expand evenly in every direction, leading to a boring universe consisting of an evenly dispersed cloud of gas. So when you look at the night sky, you are seeing evidence for macroscopic randomness!
One last word: Heisenberg's uncertainty principle does include a constant "h", and it is very small. But is is not an upper limit that prevents uncertainty from leaking into the macroscopic world. In fact, the mathematical form of the Uncertainty principle:
delta_x . delta_p >= h_bar
is an inequality. It sets a lower limit on the amount of uncertainty but no upper limit.
  • #37
But how can anyone say this with certainty?
Any scientific theory will always be a compressed model of reality, thus the model may have random events but reality doesn't.
What if you have to go deeper to find the real cause for the seemingly random event.
I see no logical reasoning to explain a truly random event, there is always an explanation. It might include TONS of processing power and tons of math and physical models, but in the end you will find some sort of cause.
If there truly is no cause for something, then I don't know how I will be able to continue with a serious attitude.
edit: to elaborate a little bit..
It seems like people haven't grasped the seriousness of a truly random event, even if we can use statistics to get approximate values..
If there is such a thing as a truly random event, then that event will forever have /no explanation/
We can't find the source, the cause, because it has no such thing, not only does this seem completely illogical and counterintuitive, it also breaks down everything we work for.
  • #38
octelcogopod ,
random does not mean uncaused. Random can be cause as well. Where do you get your reasoning concerning this?
You must explain by which physical law reality is not random. You state it as a fact, while in fact it is not. Your statement implies you know reality. (?)
You are not correct. Only models (our models) or reality can be right or wrong. Reality just is.
  • #39
You have to understand the basis I'm basing this on.
Random has usually meant that one cannot with certainty get a 100% accurate value for something, as such one uses probability and statistics.
This is an error in the model used to describe reality, not reality itself(is my idea.)
Determinism states that everything that has happened since the big bang has happened in a cause and effect scenario, where there are no random things.
This is what I believe MUST be the truth.
Also, if it truly was a random event it wouldn't have a cause, if it did it would be deterministic.
  • #40
Dear octelcogopod,
this is where i feel copeled to remind you to get more information about our current theory on chaos. You work still in linear scenario. (not implying i know enough)
In chaos effects are not proportional to causes.
plus, determinism is about being able to UNIQUELY determine future state from current one. Once you cannot uniquely do just that, you are not deterministic. Therefore, random event can and do have cause!
Random/chaos being unpredictable, not uncaused!
  • #41
But that makes no sense, at least to me.
If a ranom event does not have a cause, it cannot be determined from a previous state, if on the other hand it does have a cause, it CAN be determined, but you keep saying it cannot be determined, but does have a cause?
Hypothetically if there is a cause for an event, it is deterministic,.
How is that possible?
I'm also speaking hypothetically, not literally based on our current work in the labs/etc.
  • #42
Maybe you're expectations of sense are what's complicating the subject for you?
I don't know if you're trying to tie this to human decision making or purely physical occurences, or if you use the assumption that all decisoin making are actually physical processes or what.
I can see where you'd argue that events we call chaos have a chance of having some hidden order to them, but I think there's some clever tests that have been passed. I trust that your doubt and question has been confronted by these theories in the scientific realm and peer review.
Even today, some countries with emporer's don't like the notion that their prophecies can't be true if there's randomness, and so don't allow modern cosmology to be taught if it threatens their political-religion basis for power to keep order.
  • #43
I believe that proving one way or the other is undecidable.
  • Quantum Interpretations and Foundations
  • General Discussion
