What Kind of Virus is Infecting my USB and How Can I Clean It?
  • Thread starter Thread starter ajri02
    Virus
A USB drive was infected with an undetected virus that compromised a computer and subsequently hacked a web host by inserting malicious code into files. Standard antivirus software like Bitdefender failed to identify the virus. Formatting the USB drive using MS-DOS did not remove the infection because the computer remained compromised. To effectively clean the USB, it is recommended to use a Linux live CD to boot from an uninfected system, scan the USB, and perform a full format without opening the drive on the infected machine. For the infected computer, copying essential files (avoiding executables) to an external drive and performing a system restore is advised to eliminate rootkits and restore system performance. Changing FTP passwords is also crucial for securing the web host. Users are encouraged to upload any suspicious files to VirusTotal for identification and further guidance on removal. The virus may resemble Conficker, but traditional antivirus solutions like Symantec were ineffective in this case.
ajri02
I got an USB and that infected virus that I never seen!
I plug it in mycomputer and it's infected. Bitdefender in my machine can't detect this virus.
When I upload files to host from the infected machine, the host is hacked. It is inserted dangerous code that link to a virus website from chinese, to the index.html, index.php files.
When I Format Usb (from MS DOS), the Usb is not cleaned.
I really don't know what kind of it? And which tools to clean it from my computer, my usb and my host?
Thank for your help!
Computer science news on Phys.org
Hello friends
There are many virus infected your USB drive. You should be try to good antivirus to clean USB drive. You will be downloading the some good Antivirus and remove virus. I think USB drive working properly...
Where did you find MS-DOS ? Unless you are running Windows 98, I doubt that you formatted your USB from MS-DOS. The command line interface that ships with later versions of Windows depends on the windows kernel and several subsystems including drivers being loaded into memory, and if your virus is a rootkit that is designed to work with windows kernel-mode and user-mode processes, formatting from this interface will not be effective. Use a Linux boot disk (also known as a Linux live CD) and boot from this disk on any PC (if possible, do not boot from the infected PC). If you boot from your PC, use a cold boot (do not boot the CD by restarting the computer, boot it from a computer that has been shut down and turned off). You may have to go into your PC's BIOS settings to tell it to try to boot from CD/DVD before the main disk drive. After Linux has loaded, plug in your USB drive, run a virus scanner on it, and then copy any files you want to save to the main disk, then do a full format of the USB drive. You should then be able to copy over the files you need. Do not copy any files you do not recognize, and try not to copy executables.
Unfortunately, the best way to clean your machine of a rootkit type infection quickly is to use Linux to copy files that you wish to save (no executables!) to an external disk, and then do a system restore, which will wipe all data from your drive, reformat your drive, and install a factory image of the operating system and programs that shipped with your computer. Many PCs come with a hidden partition built in that will restore for you (Dell, HP, Compaq, Gateway, Acer, toshiba, etc.).
While there are many effective virus scanners out there that scan for rootkits, your rootkit may not be detected by their scanner, and worse, you may remove some viruses (rarely is a virus ever alone) and leave the main culprit or nonsense like a damaged driver or system file that causes your system to have silly errors afterwards. System restores are also a great way to get back some speed from a bloated registry, unnecessary drivers and little programs, and sprawling filesystem.
Update Bitdefender, and scan your computer after that.
I think you can use another (not infected) computer to delete the dangerous code.
It`s because you clean it while your computer is infected, so everytime you clean it, the virus copies the files again to the USB.
Simply take the USB to another (not infected) computer and format it.
Please note that if you open the USB flash at the another computer, it will also get infected; so be totally sure that you format without opening the USB flash. (you can open it after you are sure it`s clean)
upload any of the virus files to virustotal.com, you`ll get it`s name(s), google the name(s) and you`ll probably find information on how to totally remove it from your computer.
slider142 said:
Where did you find MS-DOS ? Unless you are running Windows 98, I doubt that you formatted your USB from MS-DOS. The command line interface that ships with later versions of Windows depends on the windows kernel and several subsystems including drivers being loaded into memory, and if your virus is a rootkit that is designed to work with windows kernel-mode and user-mode processes, formatting from this interface will not be effective. Use a http://www.vangthegioi.com.vn (also known as a Linux live CD) and boot from this disk on any PC (if possible, do not boot from the infected PC). If you boot from your PC, use a cold boot (do not boot the CD by restarting the computer, boot it from a computer that has been shut down and turned off). You may have to go into your PC's BIOS settings to tell it to try to boot from CD/DVD before the main disk drive. After Linux has loaded, plug in your USB drive, run a virus scanner on it, and then copy any files you want to save to the main disk, then do a full format of the USB drive. You should then be able to copy over the files you need. Do not copy any files you do not recognize, and try not to copy executables.
Dear Friends,
thank for your help, yes I use Linux to clean the USB. And with host, I change the ftp password.
But I really don't know what kind of this virus. It looks like Conficker http://en.wikipedia.org/wiki/Conficker But I can't clean by Symantec
This week, I saw a documentary done by the French called Les sacrifiés de l'IA, which was presented by a Canadian show Enquête. If you understand French I recommend it. Very eye-opening. I found a similar documentary in English called The Human Cost of AI: Data workers in the Global South. There is also an interview with Milagros Miceli (appearing in both documentaries) on Youtube: I also found a powerpoint presentation by the economist Uma Rani (appearing in the French documentary), AI...
