Dividing Infinity by Infinity: What is the Result?
  • Thread starter Thread starter adjacent
Dividing infinity by infinity is considered undefined in standard arithmetic because infinity is not a number that can be manipulated like finite numbers. While some mathematical frameworks may extend the concept of infinity to allow for division, they often yield different results, with some defining infinity divided by infinity as 1. The discussion emphasizes that without a specific context or definition, the quotient remains indeterminate. Examples using limits illustrate that expressions approaching infinity can yield finite values, further complicating the notion of infinity divided by infinity. Ultimately, the consensus is that without a clear definition, infinity divided by infinity cannot be uniquely determined.
adjacent
What would happen if,I divide ∞ by ∞.What would be the answer. Would it be 1?
Mathematics news on Phys.org
If would be undefined.
I don't understand,What do you mean?
Infinity is not a number and you can't calculate with it like you can with usual numbers. Consider the values of quotients \frac{x+1}{2x+1} and \frac{2x+1}{3x+1} when ##x## is let to grow without bound. In both expressions the numerator and denumerator approach infinity when ##x\rightarrow\infty##, but the value of first expression approaches ##1/2## and the value of second expression approaches ##2/3##. You can't define a unique value for the quotient ##\infty/\infty##.
Likes 1 person
What is it about the word "undefined" that you do not understand? It means "would have no definition". Is that not clear?
In terms of "ordinary arithmetic", "infinity" is NOT a number and so there simply is NO definition for "infinity over infinity". There are ways of extending the number systems to give various types of "infinity" some of which then allow you to divide infinity by infinity. Most of those, but possibly not all, define division so that infinity by infinity is 1.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
