What would be the ameter reading?
  • Thread starter Thread starter AlokBehria
    Reading
The discussion revolves around calculating ammeter readings and resistor values in a circuit. Initially, the ammeter reads 0.6 A with a switch open, and participants speculate that closing the switch may increase the reading to 0.9 A, but caution is raised about the implications of shorting the circuit. Two additional questions involve calculating the resistance values of parallel resistors and determining how many 176-ohm resistors are needed to draw 5 amps from a 220-volt supply. Participants emphasize the importance of showing work and understanding the principles behind the calculations rather than simply seeking answers. The conversation highlights the complexities of circuit behavior when switches are manipulated and the need for proper guidance in solving physics problems.
AlokBehria
Hi All,
I have attached a bmp file indicating the diagram. Now, in the diagram shown alongside the cell and the ammeter both have negligible resistence.The resisters are identical with switch K open. the ameter reads 0.6 A . what will be the ammeter reading when the switch is closed?
Few more questions...
Q1 . Two resistence when connected in parellal give resultent value of 2 ohm. calculate the value of each resistence .
Q2 A resister a resistence of 176 ohm. how many of these resisters should be connected in parellal so that their combination draws a current of 5 ampers from a 220 volt supply line.
hare krishna
Alok
Thread moved from General Physics to Homework Help, Intro Physics.
Welcome to the PF, AlokBehria. Homework and coursework questions should go here in the Homework Help forums, and not in the general technical forums. Also, we require that you show us the relevant equations and show us some of your own work, before we can begin to give you tutorial help and advice.
So, how would you approach these questions? Also, I think there is something wrong with the questions. When you close switch K, where will the smoke and fire be seen first?
I will wait for the file to load, but for now I'll help you with your other 2 questions.
Q1.
The total resistance of parallel resistors is:
R_T = \frac{1}{R_1} + \frac{1}{R_2} + ... + \frac{1}{R_n}
A shortcut to finding the total resistance of 2 parallel resistors is:
R_T = \frac{R_1R_2}{R_1 + R_2}
Q2.
Using the first equation above and Ohm's Law, you have:
V = I R_T
V = I (\frac{1}{R_1} + \frac{1}{R_2} + ... + \frac{1}{R_n})
Now, you know your voltage and your current, so you can find R_T. Once you have R_T and you know what value the resistors need to be, you can find how many resistors you need.
Thanks for the help, but I am not able to solve the question as per your suggestion, so would you elaborate more on both the question?
hare krishna
Alok
hare krishna
Alok
Which question can't you solve? 1 or 2?
Q2, please help me.
EugP gave you all the help you need in post #3. Stop trying to have us solve the question for you -- that's not how the PF works. You are *required* to show us your own work in order for us to help you. Please show us some of your work on these questions.
Alright this should be more than enough information to help you solve the problem.
Like I said before:
<< Sorry, I have to delete this as too complete of an answer. Wait for more work by the OP. -berkeman- >>
we used V=IR_t
220 =5 (\frac{1}{R_1} + \frac{1}{R_2} + ... + \frac{1}{R_n})
Now if we solve the equestion, we diden't find the answer.
Remember, that question says that all the resistors are equal and in parallel. What happens to the total resistance when you put two equal-value resistors in parallel? What about 3 in parallel? What about N in parallel?
Like I said before:
No you're right I got a little carried away. Won't happen again.
AlokBehria, why don't you post any work you've done so far, with as many descriptions as possible of your thought process, so we could GUIDE you to how to solve the problem.
have you one through the Q2 ? If yes, then where wud you find individual R_1 , R_2 and Rn
I'm sorry but I don't understand your question.
I woluld again repeat my question.
A resister has a resistence of 176 ohm. how many of these resisters should be connected in parellal so that their combination draws a current of 5 ampers from a 220 volt supply line
One more request, if you can open up that attached file..
Now, the question is ..
In the diagram given in the file, the cell and the ammeter both have negilagable resistence . the resistors are identical with the switch K open,the ammeter reads 0.6 amp. what will be the ammeter reading when the switch is closed. The answer shows the current in ammeter is 0.9 amp.
hare krishna
Alok
Post your work so we can see how far you've gotten.
ammeter reading
when three resistors with identical length connected with switch k open,the ameter reads 0.6 amp. reading
what will be the ammeter reading while the switch is closed.
it is noted that the cell and the ammiter both have negligiable resistence
EUGP, if you can direct me a link so that I can go through the manuals to solve my problem.
hare krishna
Alok
hare krishna
Alok
What manuals? I don't understand what you want, I gave you all the information you need. I'm not going to give you the answer.
When the switch is closed the resistance in the circuit becomes zero, that is the power supply is shorted out. So it is actually not possible to say what the reading will be - each power supply will respond differently by tying to send the maximum possible current throught the wire that is shorting it out.
As far as the parallel combination of similar resistors goes - note that their total resistance needs to be 220/5 ohm.
http://www.circuit-magic.com/series_parallel.htm
http://www.physics.uoguelph.ca/tutorials/ohm/index.html
That would be the smoke that I was alluding to :eek:
