What would be the result of this collision?
  • Thread starter Thread starter cshum00
    Collision
In a one-dimensional system with two identical particles moving towards each other, a completely inelastic collision will result in both particles sticking together and coming to a stop, as momentum is conserved. While kinetic energy is not conserved in this type of collision, energy is transformed into other forms, such as phonons. The discussion emphasizes that in a closed system, energy conservation still holds, but it may change forms rather than remaining as kinetic energy. The participants clarify the definitions of inelastic and elastic collisions, highlighting the importance of understanding energy transformations. Ultimately, the outcome of the collision is that both particles cease movement due to momentum conservation.
cshum00
-Let's say that in this system particles are only allowed to move in one dimension.
-There are 2 particles moving towards each other.
-Both particles have same mass and velocity.
What will be the result of the inelastic collision?
a) Both particles will come to a stop and no longer move.
b) They will move to the opposite of their original direction with no change in velocity.
I haven't done the math yet but my intuition tells me from the waves behave is that both velocity vectors would cancel each other. But from my knowledge of inelastic condition tells me that their velocity vectors will exchange.
(I am assuming you mean a completely inelastic collision??)
Even though the kinetic energy is not conserved in an inelastic collision, there is still conservation of momentum. Can you write out the conservation of momentum?
Yes, complete inelastic collision.
And let's add that it is a closed system.
So in a closed system, isn't energy supposed to be conserved?
If it is a completely inelastic collision then the masses would stick together. So the resultant would be that they both stop using conservation of momentum.
If you start calling the "inelastic collision" in a closed system, then you need to define inelastic. Usually it means that any energy transferred to it will sink out into phonons, or some potential somewhere. So really it stays in the system, its just no longer the kinetic energy of the particle. In elastic it would be such that the energy does NOT go into some other form but rather stays as the particles kinetic, and is just transferred.
Absolutely. The conservation of energy is "always" true, otherwise you are putting a lot of us that studied physics back to square one. Fact is that the energy can change from one form to the other. Therefore, in your system, the kinetic energy is not conserved, but has been transofrmed into another for of energy, which phonon production is very likely, this is not the only possible way.
Cheers
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
