Whats a way to determine the range of this complex function?
The discussion revolves around determining the range of the complex function p(z) = -2z^3 within the quarter disk defined by |z| < 1 and 0 < Arg(z) < π/2. Participants express skepticism about the provided answer, which states the range is a circular sector |w| < -2 and -π < Arg(w) < π/2, deeming it incorrect. They suggest using the polar form z = re^(iθ) to analyze the function more accurately. The confusion stems from discrepancies between the textbook answer and the participants' calculations. The conversation emphasizes the need for a correct understanding of the function's behavior in the specified domain.
jdinatale
Describe the range of p(z) = -2z^3 for z in the quarter disk |z| &lt; 1, 0 &lt;Argz &lt; \frac{\pi}{2}.
The answer is the circular sector |w| &lt; -2, -\pi &lt;Argw &lt; \frac{\pi}{2}
What's a good way of seeing why this is true?
You certainly aren't going to get ##|w|<-2## and that argument range isn't correct either. Write ##z = re^{i\theta}## and work with that.
I totally agree with you. The answer in the back of the book (which is what I posted in the OP) seems to be incorrect. That's part of the reason why I was confused.
So what do you get?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
