What's the rms speed of the molecules?
To calculate the root mean square (rms) speed of molecules in a gas canister, the ideal gas law (PV=nRT) can be utilized without needing the temperature directly. The discussion emphasizes that nm, representing the total mass of the gas, is derived from the number of moles multiplied by the molar mass. The rms speed can be calculated using the formula v = sqrt(3kT/m), where k is Boltzmann's constant and m is the mass of a molecule. Ultimately, the conversation centers on deriving the necessary variables to compute the rms speed effectively. Understanding the relationships between pressure, volume, and mass is crucial for solving this problem.
cdymdcool
1. A canister containing 150kg of an ideal gas has a volume of 8 m^3. If the gas exerts a pressure of 5*10^5 Pa, what's the rms speed of the modecules?
I can't get the temperature of the canister...
You don't need it. You have PV=nRT, so T=PV/nR. Leave it as that and continue solving the problem. Eventually, you should get a "nm" in your solution. What's this equal to?
so nm equals the #of moles times its mass, what isn't the #of moles still unknow?
nm is the #of moles times the molar mass (mass per mole). What's # of moles times the mass per mole?
I use the formula v = square root of(3kT/m), which k stands for boltzmann's constant and m stants for the mass of molecule.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
