When is Ampere's Law applicable in different scenarios?
  • Context: Undergrad
  • Thread starter Thread starter BlackMelon
    Ampere Loop Solenoid
The discussion revolves around the applicability of Ampere's Law in different scenarios, including a solenoid and a hollow cuboid. Participants explore whether the law can be applied under varying conditions of magnetic fields and the configuration of Amperian loops.
  • One participant questions whether the same Amperian loop used for a solenoid can be applied to an infinitely long hollow cuboid.
  • Another participant suggests that Ampere's Law can always be applied, but the effectiveness depends on the symmetry of the problem and the constancy of the magnetic field along the chosen loop.
  • A participant notes a mismatch between Ampere's Law and the Biot-Savart Law in a specific case due to the non-constant magnetic field along the Amperian loop.
  • There is a discussion about the implications of having constant but unequal magnetic fields on all sides of a loop and whether Ampere's Law can still be applied in such a scenario.
  • One participant emphasizes that while Ampere's Law is always valid, its practical utility may be limited if the spatial variation of the magnetic field is unknown.
Participants express differing views on the applicability of Ampere's Law under various conditions, indicating that multiple competing perspectives remain without a clear consensus.
Participants highlight limitations related to the symmetry of the problem and the constancy of the magnetic field, which may affect the application of Ampere's Law.
BlackMelon
Hi All,
In the attachment, I have 3 scenarios in question.
The first one is just a solenoid from http://hyperphysics.phy-astr.gsu.edu/.
The second one is a hollow cuboid, which is infinitely long. I am using the same analogy as the solenoid. Would I be able to set the same Amperian loop?
For the third one, I do not have the circuits. If the magnetic field of each side of the loop is constant, but all the fields are not equal, would I be able to apply the Ampere's law?
Edited: In the scenario 2, why applying both green and blue loop at the same time (which results in the magnetic field twice of that of the green loop alone) is wrong?
Best Regards
BlackMelon said:
Hi All,
Best Regards
What do you mean by "would I be able to apply the Ampere's law?". My flippant answer is that Ampere's Law is always true and can always be applied*. You can use any loop you choose. Which means that I'm not understanding your question.
*Within the limits of classical physics, of course.
Hi Dave
Please refer to the current loop in the following link:
http://bit.ly/3B5buxz
The Ampere's Law and the Biot Savart Law mismatch in this case. The reason is that the magnetic field along the Amperian loop is not constant.
Yet, we see from Hyperphysics site: bit.ly/4d7PAaj that if the mag field is constant at one side of the rectangular loop and zero at the other sides, we can apply the Ampere's law.
So, I am curious if the field of all sides are constant but not equal, would I be able to apply the Ampere's law.
As @DaveE said, Ampere's law is always valid and you can draw any loop you choose. Sometimes the symmetry of the problem is such that you can draw the loop in a way that makes it easy to solve the problem. But in most cases you draw the loop and you don't know how the magnetic field varies spatially, so Ampere's law really isn't much help.
