When is an integral infinite help
  • Thread starter Thread starter P3X-018
    Infinite Integral
4 replies · 2K views
P3X-018
The problem is this:
Let f : R^2 -> R be
[tex]f(x,y) = \frac{xy}{(x^2+y^2)^2}\qquad (x,y)\neq(0,0)[/tex]
With [itex]f(0,0) = 0[/itex].
Question:
Is [itex]f[/itex] integrable with respect to the Lebesguemeasure [itex]m_2[/itex] om the set [itex][-1,1]\times[-1,1][/itex]?
Well [itex]f[/itex] is integrable if and only is
[tex]\int_{[-1,1]^2} \vert f\vert\,dm_2(x,y) < \infty[/tex]
The integral is infinite, and so f isn't integrable.
The thing that makes it confusing, is that in the next problem it says,
Show that both the double integrals exist
[tex]\int_{[-1,1]}\left(\int_{[-1,1]} f(x,y)\,dm(x)\right)dm(y)[/tex]
[tex]\int_{[-1,1]}\left(\int_{[-1,1]} f(x,y)\,dm(y)\right)dm(x)[/tex]
But how can they exist if f isn't integrable?
EDIT:
Hmm I had made an error. It did seem kinda wired that the integral of a positive would give me something like [itex]\infty-\infty[/itex]. The integral is infinite though. The expression I had found would only hold for y > 0.
First question : Dont you think that the integral should have two boundaries? its from [-1,1] to what? please try to be more specific so we can help
Actually [-1,1] is not a point it's the interval from -1 to 1. That's just another way of writting the integral of the function f(x,y) from -1 to 1 with respect to x (hence I have writtin m(x), the Lebesgue measure with respect x).
I assume that the notation "[-1,1]2" means [itex]-1\le x\le 1[/itex] and [itex]-1\le y\le 1[/itex]. A function is as long as the set of points on which it is NOT continuous is a measurable set. For what points is this function not continuous?
Yep, that's the square I'm talking about.
HallsofIvy said:
A function is [what?] as long as the set of points on which it is NOT continuous is a measurable set. For what points is this function not continuous?
What is the function if it's not defined on a measurable set? Integrable or measurable?
The function is measurable though, since as f is only discontinuous at the point (0,0), and we just define f(0,0)=0, and make f defined on the whole square.
