Understanding Continuity: When is a Function Continuous?
  • Thread starter Thread starter DespicableMe
    Continuous
A function f(x)/g(x) is continuous when g(x) is defined and does not equal zero. The confusion arises from the interpretation of "defined," which means having a value rather than being non-zero. The key point is that a function is undefined if its denominator equals zero, making option b) the correct choice. Understanding the conditions for continuity is essential for solving related problems. Clarification on these definitions helps in grasping the concept of continuity in functions.
DespicableMe
You're simply given f(x)/g(x) and it asks, when is the function continuous?
There was one that was definitely wrong, so I remember these remaining choices:
a) It is continuous when f(x) and g(x) are defined
b) " " when g(x) cannot equal 0
c) " " when g(x) is defined.
I chose c) but I realized that it could be b) because you can't have a denominator 0. At the time, I was thinking that defined meant having a value that is not 0 because usually when a function has a denominator 0, we call the function "undefined."
Can someone please clarify? :)
The answer is b. "Defined" just means that a function has a value.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
