Where did i go wrong in fudingin the temperature of the gold cube?
The discussion revolves around calculating the temperature increase of a gold cube after being connected to a capacitor. The initial calculations involve determining resistance, charge, current, and energy, but the approach is criticized for being overly complex. A simpler method suggested is to directly use the energy stored in the capacitor to find the temperature change in the gold. The energy stored can be calculated using the capacitance and voltage, leading to a more straightforward solution. Ultimately, the focus is on simplifying the calculations to accurately determine the final temperature of the gold cube.
yjk91
A cube of gold (resistivity ?R = 2.44 10-8 O m, density ?D = 1.93 104 kg / m3, and specific heat c = 129 J / kg °C) that is 3.5 mm on a side is connected across the terminals of a 40-µF capacitor that initially has a potential difference of 340.0 V between its plates.
http://www.webassign.net/bauerphys1/26-p-052.gif
(b) When the capacitor is fully discharged, what is the temperature of the gold cube? (Use 20°C for room temperature.
i found R = p L /A
and got 0.69714 * 10^-5 ohm
Q = C *V = 40 *10^-6 * 340 V = 136 * 10^-4 C
I = V/R = 340 / (0.69714 * 10^-5) = 487.7066 * 10^5 A
time t = Q/I = 136*10^-4 / (487.706*10^5) = 0.27885 * 10^-9s
E = V^2t/R = 340^2(0.27885*10e-9) / 0.69714e-5
= 4.6239 J
m = density * volume = 1.93 * 10e4 * 3.5*e-3^3 =82.74875e-5 kg
E = mc delta T
T = E/(mc) = 4.6239 / (82.74875e-5*129) = 43
Tf = 43+20= 63mm where did i go wrong?
You're taking the long way around to calculate the energy deposited in the gold, and there are some assumptions being made that look somewhat dubious.
Why don't you assume that all the energy initially stored in the capacitor will be dumped into the gold (the capacitor will have zero charge, thus zero energy when its fully discharged, so that energy must have gone into heating the gold).
Given the capacitance and voltage, what's the energy stored in the capacitor?
sweet i got it thx
hey Gneli
could you help me with this problem? i just need a place to start and some guidance
thank you
https://www.physicsforums.com/showthread.php?p=3419623#post3419623
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
