Publishing a Result: Rules of Thumb
  • Thread starter Thread starter center o bass
In academic publishing, particularly in theoretical physics, determining when to publish a result involves several considerations. If a researcher suspects their result is novel, a thorough literature review is essential to ensure it hasn't already been published. The novelty of a result can be defined by its originality or by offering a new perspective on existing findings. The choice of journal is crucial; researchers should aim to submit to journals that are well-regarded in their field and familiar to their peers. The prestige of the journal can influence the acceptance of work that may not be entirely novel but offers new methodologies or variations on known results. High-impact journals like Nature or Science require significant novelty, while lesser-known journals may accept work that is more incremental or in-progress. Consulting with a supervisor is recommended to navigate these decisions effectively.
center o bass
Rules of thumb for when to publish a result.
Being novel to the game of academia I wonder if there are any rules of thumb to follow
when one should publish a result or not.
Suppose one finds a result which one suspects might be new. How should one then proceed?
Should one go about looking around carefully to see of someone else has done it? If so, how carefully should one look? What would qualify as a 'new' result anyway? Is it enough if the result comes with a new twist/perspective, or if one builds on an earlier result?
As a theoretical physicists, in which journals should one ideally wish to publish one's paper? Does it depend on the content of the paper? (If so, which journal should one wish to publish a result in gravity, quantum gravity and unified theories?) Can it count against you if you publish in one of the less recognized journals?
As theoretical physicist, one should already have read dozens, if not hundreds, of papers already. One would expect that such physicist already are aware, based on the papers they read, the journals that these papers are published in and the different tiers and prestige that each journal has.
Zz.
This depends on many factors, and is something you learn gradually if you work in a field. Basically, the rule-of-thumb is to submit the paper to a journal YOU read, you know your collegues/competitors read and that publish results in your field.
This is something best discussed with your supervisor.
Edit: ZZ was faster
If it is a purely theoretical result then yes, you should look very carefully. The last thing you want is for one of the referees to tell you that the result has already been published (this is one of the things a referee looks for). Experimental results also have to be at lest somewhat novel, but experiments are by their very nature rarely exact duplicates of work in other labs (we always get somewhat different results or use other methods).
There are no clear rules and it depends on the journal. Journals with lower "prestige" often publish work that e.g. uses a new method to reach a known result, or perhaps is just another "version" of a known results.
If you want to publish in Nature/Science it has to be entirely novel. if it is a conference proceeding for a minor conference it is much less strict and can also be work in progress.
Bit Britain-specific but I was wondering, what's the best path to take for A-Levels out of the following (I know Y10 seems a bit early to be thinking about A-levels, but my choice will impact what I do this year/ in y11) I (almost) definitely want to do physics at University - so keep that in mind... The subjects that I'm almost definitely going to take are Maths, Further Maths and Physics, and I'm taking a fast track programme which means that I'll be taking AS computer science at the end...
After a year of thought, I decided to adjust my ratio for applying the US/EU(+UK) schools. I mostly focused on the US schools before, but things are getting complex and I found out that Europe is also a good place to study. I found some institutes that have professors with similar interests. But gaining the information is much harder than US schools (like you have to contact professors in advance etc). For your information, I have B.S. in engineering (low GPA: 3.2/4.0) in Asia - one SCI...
I graduated with a BSc in Physics in 2020. Since there were limited opportunities in my country (mostly teaching), I decided to improve my programming skills and began working in IT, first as a software engineer and later as a quality assurance engineer, where I’ve now spent about 3 years. While this career path has provided financial stability, I’ve realized that my excitement and passion aren’t really there, unlike what I felt when studying or doing research in physics. Working in IT...
