Which branch of topology to study
shounakbhatta
Hello,
I learned that there are 4 types of approach to topology:
(1) General
(2) Algebraic
(3) Differential
(4) Geometrical
To have a rough understanding of General relativity, which branch of topology should I study?
Thanks.
To have a rough understanding you need very little topology. What you need to study is differential geometry.
Oh, dear. You're thinking way too far. General Relativity is mathematically founded on differential geometry and advanced calculus. To study differential geometry at a decent level, you don't need too much topology (certainly not spitted per branches).
The foundational elements of topology are of some interest, Wolfram mathematics calls this "point set topology". This is the part of topology before you split off into branches.
Wolfram said:
Point-Set Topology
The low-level language of topology, which is not really considered a separate "branch" of topology. Point-set topology, also called set-theoretic topology or general topology, is the study of the general abstract nature of continuity or "closeness" on spaces. Basic point-set topological notions are ones like continuity, dimension, compactness, and connectedness.
Wolfram doesn't mention the definition of a manifold as part of point-set topology though that's something you might want to know :-). (I'm think it would be classified as part of point-set topology, but I could be mistaken as my focus is on the physics. Wolfram doesn't mention it.)
Wald, "General Relativity", for instance, has enough point set topology to give you a definition of a manifold in one of his appendices. A full study of it would probably be overkill if you are into the physics rather than the math.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
10K
