Which of the following gives the change in altitude of the balloon?
The problem involves determining the change in altitude of a hot air balloon based on a given rate of change function, r(t) = t³ - 4t² + 6, over a specified interval. Participants are asked to identify which integral expression correctly represents the change in altitude during periods of decreasing altitude.
  • Participants discuss the meaning of "rate of change" and its relation to derivatives. There is confusion regarding the interpretation of the function r(t) versus its derivative r'(t) and how to apply integrals to find the change in altitude. Some participants suggest that the integral of r'(t) might simplify the problem, while others question the necessity of graphing r(t) instead of r'(t).
The discussion is ongoing, with participants exploring different interpretations of the problem and questioning the roles of r(t) and r'(t). Some guidance has been offered regarding the implications of the rate of change and the behavior of the balloon based on the sign of r(t).
Participants express uncertainty about the problem setup and the implications of the various answer choices provided. There is a recognition that understanding the relationship between the function and its derivative is crucial for addressing the question.
lude1
The rate of change of the altutide of a hot air balloon is given by r(t)= t3 - 4t2 + 6 for 0 ≤ t ≤ 8. Which of the following expressions gives the change in altitude of the balloon during the time the altitude is decreasing?
a. ∫r(t)dt when t goes from 1.572 to 3.517
b. ∫r(t)dt when t goes from 0 to 8
c. ∫r(t)dt when t goes from 0 to 2.667
d. ∫r'(t)dt when t goes from 1.572 to 3.514
e. ∫r'(t)dt when t goes from 0 to 2.667
All I know is that "the rate of change" means the derivatve and when the altitude is decreasing, the answer should be negative.
But besides not knowing how to start this problem, I'm a little confused with all of the answer choices.
For answer d, the integral and derivative cancel each other out. If that's the case, does that mean the only thing you have to do is plug in the t values into r(t), like so?
r(t) when t goes from 1.572 to 3.514
r(t)= t3 - 4t2 + 6
r(t)= {3.5143 - 43.5142 + 6} - {1.5723 - 41.5722 + 6}?​
r(t)= t3 - 4t2 + 6
Have you graphed r(t) = t3 - 4t2 + 6? As stated r(t) represents the time rate of change of altitude, so where r(t) > 0, the balloon is ascending, and where r(t) < 0, the balloon is descending.
Why would you graph r(t) and not r'(t)?
Let me turn the question around. Why would you want to graph r'(t)? What does it represent in this problem? Why wouldn't you want to graph r(t)? You know what it represents in this problem.
I think why I was confused was, when it said "the rate of change", I instantly thought derivative. When I saw r(t), and not r'(t), I wanted to find r'(t) despite the fact the problem said r(t) WAS the rate of change.
  • · Replies 17 ·
  • · Replies 30 ·
