Which phase of matter has a fixed volume and takes the shape of its container?
The discussion revolves around several physics problems, primarily focusing on fluid mechanics and pressure. Key points include the application of Pascal's law to calculate the force needed to lift a car using hydraulic pistons, with the force being inversely proportional to the square of the piston diameters. The height of a mercury column in a barometer at 1 atm is approximately 76 cm, derived from the relationship between pressure, density, and height. The tension in a cable supporting a submerged spherical steel shell can be determined using Archimedes' principle, which accounts for the weight of water displaced. Additionally, the pressure differential over an airplane wing is crucial for flight, as lower pressure on the upper surface generates lift.
Ripple
Here are a couple questions I could use help on, please help.
1. What force must be applied to a small cylinder piston with a diameter of 0.32 m to lift a car weighting 12,000 N that is supported by the piston in a large cylinder that has a diameter of 1.4 m? Assume that there is an enclosed chamber in common between the two pistons and that the chamber is filled with hydraulic oil.m?
2. What is the height in cm of the column of mercury for a mercury barometer when the atmospheric pressure at a certain location is 1 atm? The denisty of mercury is 13.55g/cm^3.
3. A sperical-shaped hollow steel shell, with a radius of 2.5m, containing some instruments, is lowered by a cable into a lake. The shell with itss contents weighs 7.2 X 10^5 N on the dect of the ship from which it is being lowered. What is the tension in the cable when the sphere is completely immersed in the water?
4.During level airplaine flight at a constant velocity, the pressure created by air flowing over the curved upper surface of the wing compared to the pressure created by air flowing along the flat underside of the wing is?
6. Which phase (State) of matter has a fixed volume and takes the shape of its container?
a. plasma
b. gas
c. liquid
d. solid
If someone could please explain and answer these for me, i would be forever in their debt. :zzz: :zzz:
Why be you, when you could be me! |
____________________________________________________________ |
This is the only one that I can address, and I don't know if this is the answer you want. The pressure differential between the top and bottom of an airfoil in level flight is equal to the weight of the aircraft.
Should these questions belong to homework forums?
1. Check the pressure exerted by the car on the 1.4m dia piston. This is the same pressure acting upon the 0.32m piston also. So force to be applied can easily be calculated.(627N)
2. You must be joking.
3. Check the volume of water displaced. Check its weight. Deduct it from sphere weight. This is the net force acting on the cable.
4. Check Bernoulli's theorem?
6. You must be joking again.
100. Google is a great resource. Try your hands on Physics by Resnick and Haliday
Quark
This is for a buddy of mine, he is having a bit of trouble in his physics class.. he is the one doing all the work, he would like some answers to those, so that he can figure out how they were reached. If anyone else knows any more answers please don't hesitate to answer :)
:bugeye: :bugeye: :bugeye: :bugeye: :bugeye: :bugeye: :bugeye: :bugeye: :bugeye: :bugeye: :bugeye: :bugeye: :bugeye: :bugeye: :bugeye: :bugeye: :bugeye:
Ripple,
Did I say Physics by Resnick and Haliday? You should read it as Fluid Mechanics by Steiter.
1. This solution is based on Pascal's law which states that pressure exerted by a fluid in a closed container is same in all directions. Thus a 12000N force creates a pressure of 12000/(3.142x1.4x1.4)/4 N/sq.m pressure on a 1.4 m radius piston. This same pressure acts upon the 0.32m piston also. So force to be applied on 0.32m piston is [(3.142x0.32x0.32)/4]x[12000/(3.142*1.4*1.4/4). Or simply the forces are inversely proportional to the square of the piston diameter.
2. Rise in mercury column at atmospheric pressure is 76cm. Just use the forumla P = rhoxgxh, where rho is the density of the material(more precisely specific weight), g is acceleration due to gravity and h is the liquid column height.
3. You should refer Archimedes Principle to solve this problem. When a body submerges in water, it looses its weight equal to that of the water displaced. So, the spherical steel shell displaces water to a volume of 4x3.142x2.5^3/3. Density of water is 1kg/cu.m. So total weight of water displaced is (4x3.142x2.5^3/3)x9.81 which gives you a value in N. Deduct this value from weight of shell on the deck and you will get the tension in the rope.
4. If the pressure on the lower side of the wing is lower than that of the upperside, the plane can't float in the air. Danger had it right.
6. I still feel you are joking.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
