Which radius (r or R) should you use? Why?
  • Thread starter Thread starter shimizua
    Radius
The discussion focuses on the relationship between translational velocity and angular velocity for a rolling wheel. It emphasizes using the radius r, as the equations provided specifically reference r rather than R. The equations relate the distance traveled by the wheel's center of mass to its rotation, establishing a clear connection between v and w. Participants agree that dividing the equations will yield the desired expression for w in terms of v. The consensus is that r is the appropriate radius to use in this context.
shimizua
A rolling wheel of radius r has translational velocity v as well as angular velocity w. Here you will relate translational velocity to angular velocity. Since the circumference of a circle of radius r is 2p r, every time the center of mass moves a distance 2p r, the object rotates a full circle (2p radians). If this happens in a time T then
v = Dx/Dt = 2p r / T (1)
and w = Dq/Dt = 2p/T (2)
Combine these equations to find an expression for w in terms of v.
2.When applying equation 1 (in question 1) to our system, which radius (r or R) should you use? Why?
so i figured out the first question, i was just putting it up so you knew what was going on. But as far as equations i don't think there would be any for this question
I think it should be r since in the equation and statement they only refer to r and not R
Just divide the two equations and solve the resulting equation for w.
  • · Replies 30 ·
  • · Replies 81 ·
