Undergrad Why a massive body is easier to break than a tiny body?
  • Thread starter Thread starter fxdung
    Body Break
A massive atomic nucleus is easier to break down due to the weak binding forces among nucleons, which are influenced by multipole interactions rather than direct nucleon-nucleon interactions. The strong nuclear force, while attractive, does not exhibit both repulsion and attraction like electric forces, complicating the formation of multipoles in larger nuclei. The Van der Waals forces, which contribute to binding nucleons, become weaker in larger nuclei, leading to increased instability. The discussion clarifies that the initial assumption about larger bodies being easier to break was incorrect when specifically considering atomic nuclei. Understanding these forces is crucial for grasping nuclear stability and interactions.
fxdung
Why a massive body is easier to break than a tiny body despite the force bonding two particle is the same?
  • Sad
Likes weirdoguy and Sangeet Chand
It's not.
Why a massive atomic nucleus is easy to break down?Is one nucleon acted by "multipoles" force but not interaction direct between two nucleons and "multipoles" force is weak with large nucleus?But strong interaction always is attractive force not have both repulsion and attractive force as electric force,then how can we make up a multipoles?
  • Sad
Likes weirdoguy
Now I rethink that with a large nucleus the "Van der Waals" "color" is nearly "white"(QCD) so the van der Waals force binding nucleons with each other is weak.Is that correct?
  • Sad
Likes weirdoguy
I have no idea what you are talking about.
If you are talking specifically about nuclei and not generic "massive bodies", you should say so.
Likes weirdoguy
At the beginning I thought that in general the big thing is easier to break,but by your answer I know that I was wrong.But after that I did not understand about the big nucleus!
Topic about reference frames, center of rotation, postion of origin etc Comoving ref. frame is frame that is attached to moving object, does that mean, in that frame translation and rotation of object is zero, because origin and axes(x,y,z) are fixed to object? Is it same if you place origin of frame at object center of mass or at object tail? What type of comoving frame exist? What is lab frame? If we talk about center of rotation do we always need to specified from what frame we observe?
  • · Replies 26 ·
  • · Replies 50 ·
  • · Replies 64 ·
  • · Replies 30 ·
