Why Am I Getting Only Two Eigenvalues for This Matrix?
  • Thread starter Thread starter DanielFaraday
    Eigenvalues Matrix
12 replies · 3K views
DanielFaraday
Find the eigenvalues of the following matrix:
[tex] \left(<br /> \begin{array}{ccc}<br /> 1 & 0 & -3 \\<br /> 1 & 2 & 1 \\<br /> -3 & 0 & 1<br /> \end{array}<br /> \right)[/tex]
I think I'm forgetting a basic algebra rule or something. I know there are supposed to be 3 eigenvalues, but I am only getting 2.
[tex] 0=\det (\lambda I-A)=\left|<br /> \begin{array}{ccc}<br /> \lambda -1 & 0 & 3 \\<br /> -1 & \lambda -2 & -1 \\<br /> 3 & 0 & \lambda -1<br /> \end{array}<br /> \right|[/tex]
[tex] =\frac{(\lambda -1)(\lambda -2)(\lambda -1)-3(3)(\lambda -2)}{(\lambda -2)}[/tex]
[tex] =(\lambda -1)(\lambda -1)-9[/tex]
[tex] =(\lambda -1)^2-9[/tex]
[tex] (\lambda -1)^2=9[/tex]
[tex] \lambda =\pm 3+1[/tex]
Where you cancel the (lambda - 2) term, you lose one solution: lambda = 2.
Remember, you have to factor. By canceling the term (lambda - 2), you're basically saying "lambda cannot under any circumstances equal 2". If you want to do that, you have to consider two separate cases: lambda=2 and lambda!=2.
So the three eigenvalues are 3+1=4, -3+1=-2, and 2.
Why did you divide by (lambda - 2) in the first place?
Thanks for your help.
So let me get this straight. Whenever I divide by a term to cancel it, I count that term as one of my solutions, right? Does this always work? I didn't quite understand what you meant by testing two separate cases.
Because it was much easier to do that than it was to multiply everything out and try to factor a third-degree polynomial.
Why did you divide by lambda-2 in the second line of your equations? Do you remember the formulas for a determinant of a 3x3 matrix?
Oh, duh. Since there are two terms on the RHS and they are constants then the must both be equal to zero separately. Haha.
You can just factor (x-2) to get an easily solvable equation
I was just doing two steps at once. Bad form on my part.
Yes. Think of it this way, let's say you're trying to find the solutions of x for (x-1)(x-2)(x-3)=0. Obviously your solutions are x=1,2, and 3. If you divide out (x-1), you lose a solution and are left with (x-2)(x-3)=0.
Very good point. Thanks!
Your welcome. Also, to clarify AU's point, when you divide by (lambda-2), your left with that (lambda-2) in the denominator of the left hand side (the 0). Now for any number other then 2, it's going to be 0 divided by some finite number which is 0. However, with lambda = 2, you get 0/0 which is undefined, not 0.
Aha. That makes sense now.
