Why AM wave is multiplication of carrier and message signal?
AM wave modulation involves multiplying a carrier signal with a message signal, resulting in sidebands that carry the information. While both wave A and wave B are amplitude modulated, wave B lacks sidebands, which are essential for transmitting information effectively. The sidebands contain the actual data, as they represent the frequency components of the modulated signal. Techniques such as single sideband (SSB) transmission utilize wave A to ensure that information is conveyed through the sidebands. Understanding the role of sidebands is crucial for effective communication system design.
Dark_Capacitor
Let A= (sin(x) * sin(100x)) + sin(100x).; modulation index is 1;
Let B= (sin(x) + sin (100x));
Both of these waves have same frequency and both are amplitude modulated.
When passed through an envelope detector, both will give message signal.
And B have an advantage of not having any sideband frequency. Thus allowing bandwidth to be very short.
Then why we use wave A type modulation not B. All the ssb and suppressed carrier wave also use technique A, why not B?
B is not an up-conversion of the signal you want to transmit. In other words, let's say you want to transmit a 100 kHz signal, you do not want to amplify it an send into the antenna... what you want to do is to up-convert it in frequency, and then send an electromagnetic wave of frequency e.g. > 100 MHz. If your high frequency carrier does not have sidebands, you are not transmitting informations with it.
Thank you matteo137 for replying. I'm new to communication systems. Can you tell how exactly side bands carry information? All I know is that the envelope of the carrier wave has the message signal.
The sidebands carry information because they ARE the information.
Think about the Fourier decomposition of the signal (hoping you are familiar with it).
Let's say your "information" is a 1 KHz signal, so the spectrum of this signal is a dirac-delta at that frequency. When you modulate a carrier (e.g. 100 MHz) with this signal, the spectrum of the modulated carrier is a dirac-delta at 100 MHz with two symmetric sidebands at +- 1 KHz (see picture). This shows you that when you use a carrier to transmit information, what you actually care are ONLY the sidebands, and this is true also for FM modulations.
There are even example of transmission techniques which suppress the carrier and one of the two sidebands before transmitting the signal through air, in such a way that you only send one useful sideband. (of course the receiver has to know the frequency of the carrier, and have a stable oscillator)
Picture AM spectrum:
http://en.wikipedia.org/wiki/Amplitude_modulation#mediaviewer/File:AM_spectrum.svg
Thanks man. You cleared up many things. And I familiar with Fourier analysis:oldwink:
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
