Why are light waves from 2 separate light bulbs incoherent?
In summary: Spatial coherence is basically when the waves are in the same place, so it's the coherence of the light waves themselves. You can get interference patterns from white light because the waves are randomly spread out, but if you have spatial coherence, the waves will be in the same place.
fantasizeme
My notes says that this is due to how the wave patterns of both sets of light waves vary with time since the amplitudes vary due to electrons losing energy. But I don't get how this affects the coherence of both sets of light waves since they have the same frequency
Science news on Phys.org
They don't have the same frequencies. Light from a light bulb has a whole spectrum of frequencies and you only need tiny differences in frequencies to have a 180 degree phase difference after a tiny time.
It's not just a question of frequency. It's the phase information that is important for the concept of coherence. No real light source--even a laser--consists of a perfect sine wave that goes on forever. Even if you take light from a single source and split it and recombine it, making the length difference between the two legs more than the http://en.wikipedia.org/wiki/Coherence_length" , there is no definite relationship between the phase of the two beams and this washes out the interference pattern. In other words, even for a monochromatic laser, there is a finite coherence time beyond which the phases at two different times are completely uncorrelated. Similarly when you have two separate light bulbs as in the original question, there is no definite phase relationship between the light from each source and they are therefore incoherent.
You can actually get an interference pattern from white light coming out of a single light bulb (although the coherence length is very short), so it's not really the presence of many frequencies that is the main issue here.
I'm not sure what is the meaning of the statement that varying amplitudes are the reason for incoherence. I'm not an expert on this, but I'm pretty sure amplitudes are completely irrelevant to coherence.
I'd explain it like this: a light bulb actually contains a huge number of little emitters of light, with nothing to make any of them in phase with each other.
It is maybe nitpicking, but from the moment that there is a phase incoherence, by definition you do not have a single frequency in your Fourier transform. The Fourier transform of a single frequency (a Dirac in frequency domain) is exactly a perfect sine wave that goes on for ever. From the phase coherence, you can derive a minimum width in the frequency domain. If that width is zero, that is, if the light is *perfectly* monochromatic, then it is by definition a single sine. The phase jitter corresponds to a tiny width in the frequency domain - although one might call this light still sloppily "monochromatic" because otherwise you never really have monochromatic light.
Exactly, and this is nothing else but a measurement of the width of the spectral "line". The "finite life time" of a "sine wave" is nothing else but the coherence time (which is the time equivalent of the coherence length), and gives you a measure of the width of the spectral line.
It is! And your example illustrates this. "white" light can be seen as a large "line width" and hence a very short coherence length.
Temporal coherence is basically defined by taking the Fourier transform of the spectral power density and define the decay rate of the transform as the coherence time. Accordingly a small spread in frequencies assumes long temporal coherence and vice versa.
The reason why you can also get interference patterns from white light is spatial coherence. If you go far away from the light bulb you just take a small solid angle of the emission into account. This means that the path differences from the different points on the light source to your detector becomes smaller and therefore coherence is increased. This is why there is a pinhole in front of the double slit in the Young interference experiment. The pinhole mimics a point-like light source which offers full spatial coherence.
Accordingly you can make light from a light bulb as coherent as you like. Filter the light through an optical filter with narrow spectral width and go extremely far away from the source (or put a pinhole in front of it) and you can get arbitrarily high temporal and spatial coherence from a light bulb. However, this works for classical first order coherence only, but not for higher order coherences.
1. Why do light waves from 2 separate light bulbs appear to be incoherent?
Light waves from 2 separate light bulbs appear to be incoherent because they are not in phase with each other. This means that the peaks and troughs of the waves do not line up, resulting in a random interference pattern.
2. What causes light waves from 2 separate light bulbs to be incoherent?
The incoherence of light waves from 2 separate light bulbs is caused by a difference in the light source's frequency, phase, or direction. This can be due to variations in the bulbs' construction or the angle at which they emit light.
3. How does incoherent light differ from coherent light?
Incoherent light is light that is composed of multiple waves that are not in phase with each other. Coherent light, on the other hand, is composed of waves that are in phase and have a consistent frequency and direction of propagation.
4. Can light waves from 2 separate light bulbs ever be coherent?
No, light waves from 2 separate light bulbs cannot be coherent because they are produced by independent sources. In order for light waves to be coherent, they must be produced by the same source and have the same frequency, phase, and direction.
5. How does the incoherence of light waves affect their ability to produce interference patterns?
The incoherence of light waves from 2 separate light bulbs makes it difficult for them to produce a clear interference pattern. This is because the waves are not synchronized, and their interference results in a random pattern rather than a distinct pattern of light and dark bands.
  • Optics
  • Classical Physics
12K
