Why are QM wave functions complex?
In summary, complex numbers are needed in QM because they allow for the representation of wavefunctions with two independent components of phase space.
IAN 25
49
Hi,
Can anyone explain to me why the wave functions in QM must to be complex, other than to make it work when inserted into the Schrodinger equation?
Because the both the amplitude AND the phase of the wavefunction matters, and the best way to "encode" both amplitude and phase in QM (and in for example electromagnetics) is to use complex quantities.
If the wavefunction was not complex you could e.g. never get interference.
Hi f95toli
Thanks for that and I do understand what you mean. However, it is possible in electromagnetism to describe all the properties of waves, interference included, by superposing sine or cosine waves of different amplitudes - without the need for complex functions. It is true one can represent these EM waves (or any other), by using the relation e^ix = cos x + i sin x but it is for convenience. And the phase can be included in the sine or complex forms. So you do not need a complex wavefunction for interference. There must be an additional reason for complex functions in QM.
IAN 25 said:
Hi,
Actually, real wave functions can be sufficient, at least in some very general and important cases. For example, the scalar wave function can be made real by a gauge transform (at least locally) in the Klein-Gordon equation in electromagnetic field (Schroedinger, Nature, v.169, p.538(1952)). A real wave function can also be sufficient for the Dirac equation in electromagnetic field: three out of four components of the spinor wave function can be algebraically eliminated from the Dirac equation, and the remaining component can be made real by a gauge transform (at least locally) (please see my article in J. Math. Phys.: http://akhmeteli.org/wp-content/uploads/2011/08/JMAPAQ528082303_1.pdf ).
Complex numbers are part of a larger collection of hypercomplex numbers. These include, but not limited to, real numbers, complex numbers, quaternion numbers, and octonion numbers. Each of these types of numbers have their own algebraic properties. They are members of the division algebras. The reals have the algebraic properties of having magnitude, commutativity, and associativity. The complex numbers lose the property of magnitude; which is bigger 1 or i? But the complex numbers are still commutative and associative. Then the quaternions lose the algebraic propertes of magnitude and commutativity, but still have associativity. And the octonions lose magnitude, commutativity, and associativity.
I contend that the only justification for using complex numbers in quantum mechanics is because the wavefunctions have the algebraic property of complex numbers, meaning the wavefunctions lose the ability to be compared in magnitude with each other but are still commutative and associative.
The Schrodinger equation is a formalism that deals with one wavefunction at a time, so no comparison between the magnitude is obvious between many wavefunctions. However, in the formalism of Feynman's path integral, an infinite number of wavefunctions are presented in the construction of the path integral. In this context one can ask which wavefunction is larger than another.
As I understand it, wavefunctions are distributions that are all normalized to one. So how does one compare the magnitude of one distribution with another? In this context it would seem obvious that wavefunctions lose the algebraic property of comparing magnitude and so they can be represented with complex numbers.
Magnitude is really a bad term to use in this case. Both the real and the complex numbers can be normed, so maginute makes sense.
What you mean is that complex numbers are not an ordered field, while the real numbers are.
I don't have a source for this, but I remember reading somewhere that Dirac said complex numbers were need for QM because we reduced the number of independent components of phase space (position and momentum), by being able to write momentum as the derivative w.r.t. position (and visa versa) and hence lost part of the two degrees of freedom. We can get that back by switching to complex numbers which come with two independent components. But this is just a vague memory that I haven't tried to dissect.
The number of parameters needed to describe a mixed state should be the multiple of the parameters to describe each separate state. The goldilocks answer is that with real numbers the left hand side is too big, with quarternions the left hand side is too small, and with complex numbers...it is just right.
That's a very concise way to put it. I was about to drown him in Hilbert spaces :P
with complex numbers, derive exp(iwt) or something like that is just multiplying by iw (i=sqr(-1)). its easy.
you can write the wave function as a sum of exponential terms (fourier t.) so it works for any wave.
Thanks to all who have taken the time to reply. I understand that the complex form of describing a wave makes it easier (sometimes) to manipulate mathematically and that we just take either the Re or I am part when dealing with real waves. However, that doesn't explain why the texts on QM insist that the wavefunction be complex. I am afraid the explanations offered by freind and akhmeteli were in parts, beyond my level of mathematical understanding, which is B.Sc Physics level - not postgraduate. Although I do get what friend was saying about comparing magnitudes but then how can a wavefunction formed from any superposition of other wavefunctions also have unit magnitude?
So, I am still wondering is there an explanation which doesn't require higher level mathematics?
You have a choice. You can either express this as a single complex differential equation, or a coupled set of four real differential equations (the real part, the imaginary part, and the two Cauchy-Riemann conditions). These are mathematically equivalent ways to express the same underlying physics.
As a practical matter, it is much easier to work with the single complex equation.
Actually that question is a very deep one. One answer is suppose you have some kind of measurement apparatus represented by some observable. Rotate or shift the apparatus by an infinitesimal amount and the requirement that the new states that are now the measurement outcomes are still orthogonal and superposition's should still be superposition's means the underlying vector space is transformed by an infinitesimal unitary operator of the form A = 1 +eU where e is an infinitesimal real number. AA(bar) = 1 = 1 + eU + eU(bar) which implies U(bar) = -U so that U is pure imaginary which of course means the underlying vector space must be complex. Other possibilities such as quaternoins have this property but the simplest are complex numbers.
But probably the deepest answer is that a few reasonable assumptions leads to basically two choices - standard probability theory and QM:
http://arxiv.org/pdf/0911.0695v1.pdf
What QM allows is pure states to continuously change to other pure states and entanglement. If you want either of those then you must use QM and complex numbers. Note that continuity is really the basis of the first augment I gave.
Thanks
Bill
From the latest responses, I guess not!
However, using the generic form of the wave function, psi = e^-i(wt - kx) and linking the operators for Energy and Momentum, one automatically gets the Schrodinger equation, including the ih term, which is complex. So, I think my initial comment is valid. The Schroinger equation is complex because we assume a complex form for the wavefunction and vice-versa.
I feel for you - I really do. Trouble is if there was an answer that required less modest mathematical background books at a less advanced level would give it. That's part of the reason its a deep and far from trivial issue. For now simply accept there is a reason and when you know a bit more math you can delve into the detail. After all you need a reason to put yourself through that heavy math stuff.
Thanks
Bill
I think it implies that U is anti-hermitian. However U may still be representable in a suitable basis as a real matrix, e.g. ## U=i\sigma_y## with ##\sigma_y## being a Pauli matrix.
I rather think the reason we use complex vector spaces is to represent time reversal symmetry without sacrificing energy spectrum to be bounded from below. However I don't remember the details.
Anti-Hermitian, Skew-Hermitian, Skew-Adjoint or Pure-Imaginary - same thing.
The terminology comes from being able to break any operator into the form A + iB where A and B are Hermitian. You are correct about the Pauli matrices so I would say suggests rather than proves.
Thanks
Bill
Let me try to rephrase what I said.
In quantum theory, if you start with a (scalar) wave function [itex]\psi[/itex] and electromagnetic four-potential [itex]A_\mu[/itex], you can use gauge invariance to get a physically equivalent solution [itex]\varphi[/itex] and [itex]B_\mu[/itex], if [itex]\varphi(x)=\exp(i\theta(x))\psi(x)[/itex] and [itex]B_\mu(x)=A_\mu(x)-\frac{1}{e}\partial_\mu\theta(x)[/itex], where [itex]\theta(x)[/itex] is an arbitrary real function (I am cutting some corners here). So it is pretty obvious that you can always choose [itex]\theta(x)[/itex] in such a way that [itex]\varphi(x)[/itex] is real. So you can do with real wave functions only.
What about the spin wavefunction for a spin-1/2 particle?
Show me. I'll give you the set up: Let [itex]\psi(x)[/itex] be a complex wave function, use this freedom to make
[tex]
\psi(x)\rightarrow \psi'(x) = e^{i\theta}\psi(x)
[/tex]
real.
One "derivation" of the Schrodinger equation that I think might help you is to start with the de Broglie relation [itex]\lambda=h/p\Rightarrow p=\hbar k[/itex] and the Planck-Einstein relation [itex]E=\hbar\omega[/itex]. The de Broglie relation implies that a "particle" with momentum [itex]p[/itex] has some sort of wave associated with it, and the PE relation implies we can express the total energy in terms of the angular frequency. Classically, we are used to describing waves with trig functions, something like [itex]\Psi=A\,\cos(kx-\omega t)[/itex]. (I'm assuming we've set the phase to zero.)
Now, you can construct a physically relevant quantum wave equation by starting with the expression for the Hamiltonian: [itex]E=T+V[/itex], where E is the total energy, T is the kinetic energy, and V is the potential energy. In order to get the energy out of an expression like [itex]\Psi=A\,\cos(kx-\omega t)[/itex], you'll need to operate on this with a time-derivative:
$$\hbar\frac{\partial}{\partial t}\left(A\,\cos(kx-\omega t)\right)=\hbar\omega\left(A\sin(kn-\omega t)\right).$$ Notice that we've gotten the energy out front, but in doing so we've changed the cosine function to a sine.
Now, if you want to get kinetic energy out of [itex]\Psi[/itex], you're going to have to take a second derivative (with respect to x) on the other side:
$$\frac{\hbar^2}{2m}\frac{\partial^2}{\partial x^2}\left(A\,\cos(kx-\omega t)\right)=-\left(\hbar^2k^2\right)\left(A\cos(kx-\omega t)\right)=-\frac{p^2}{2m}\Psi.$$ Notice the problem we have here: since we took a first derivative with respect to time to get [itex]E[/itex], and a second derivative with respect to x to get [itex]T[/itex], our trig functions don't match and won't cancel out of the final equation. The solution to this issue is to use the complex form of the oscillating wave function, [itex]\Psi=A\,e^{i(kx-\omega t)}[/itex]. Now when we take our derivatives we are always left with the exponential and it will cancel out of the final equation:
$$\eqalign{-\frac{\hbar^2}{2m}\frac{\partial^2\Psi}{\partial x^2}+V\Psi&=i\hbar\frac{\partial\Psi}{\partial t}\cr \frac{\hbar^2k^2}{2m}A\,e^{i(kx-\omega t)}+V\,A\,e^{i(kx-\omega t)}&=\hbar\omega\,A\,e^{i(kx-\omega t)}\cr \frac{p^2}{2m}+V&=E\cr T+V&=E.}$$
So replacing the classical wave function with the complex exponential really does help to construct a sensible wave equation obeying the de Broglie and Planck-Einstein relations. Hope this helps!
[tex]
[/tex]
real.
[itex]\theta(x)=-\frac{1}{2 i}\ln\left(\frac{\psi(x)}{\psi^*(x)}\right)[/itex]
I don't think that prescription preserves expectation values, in general. Consider:
[tex]
\langle \psi | \hat{p} |\psi \rangle =\int dx \; \langle \psi | x \rangle \langle x | \hat{p} |\psi \rangle = \int dx \; \psi^{*}(x) \left( -i \frac{\partial}{\partial x} \right) \psi(x)
[/tex]
then under the transformation
[tex]
\rightarrow \int dx \; \psi'^{*}(x) \left( -i \frac{\partial}{\partial x} \right) \psi'(x) = \int dx \; \psi^{*}(x)e^{-i\theta(x)} \left( -i \frac{\partial}{\partial x} \right) e^{i \theta(x)}\psi(x) \neq \int dx \; \psi^{*}(x) \left( -i \frac{\partial}{\partial x} \right) \psi(x)
[/tex]
How is that accounted for?
Hi Guys
One other reason occurred to me. If for simplicity and to preserve superposition's you want translations, rotations, and transformations between different reference frames to be linear you must invoke Wigners Theorem. My understanding is that theorem is only valid in complex spaces - for transformations depending on a continuous real parameter like displacements that theorem requires them to be linear and hence superposition preserving.
Thanks
Bill
[tex]
[/tex]
[tex]
[/tex]
Mind you, the wave function transform is just one part of the prescription. The other part is the transform of the electromagnetic four-potential. The latter enters into the generalized momentum. Remember, a gauge transform produces a physically equivalent solution. Do you really dispute this statement?
I thought I answered your question, but I cannot find my answer, so please forgive me if the following is a duplicate.
Quite surprisingly, the same procedure is valid for a Dirac spinor function. While you cannot make a Dirac spinor real by a gauge transform, you can algebraically eliminate three out of four components of the Dirac spinor function from the Dirac equation. The remaining component can be made real by a gauge transform. Please see the reference in my post 4 in this thread.
I certainly don't dispute that. What I dispute is that you have just referenced electrodynamics, and I am talking about normal non-relativistic QM, (there need not be any fields!). Under your prescription for transformation of the wave-function, expectation values are not preserved. Again, how do you account for this?
You are certainly free to talk about anything you want, and I am certainly free to talk about anything I want (within the forum rules). I carefully defined what I was going to talk about in my post 4 in this thread. It is my understanding that relativistic QM fully accounts for non-relativistic QM. What can be described without any fields, can also be described using fields, moreover, the latter approach is more fundamental. If you're asking about non-electromagnetic forces, I have little to say about them at the moment. Let me just note that the non-electromagnetic forces (beyond gravity, and I have nothing to say about gravity) can be described by the Standard Model, which also has a gauge-invariant Lagrangian. So maybe what I am saying is valid for the Standard Model as well, maybe not, I just don't know (let me just note that it took 60 years after Schroedinger's 1952 article to find out that his approach is also valid for the Dirac equation. I don't know how much time it'll take to prove or disprove the same for the Standard Model). I am just saying (following Schroedinger) that charged particles do not necessarily require complex representation.
This is definitely not true. Despite the fact that in relativistic quantum theory there is no known consistent physically interpretable scheme for that theory using wave functions in the same sense as the non-relativistic Schrödinger-wave function. The only (very!) successful formulation of relativistic quantum theory is local quantum field theory, because relativistic QT necessarily is a many-body theory with a non-fixed number of particles.
Further, within relativistic QT, particles carrying charge are described by non-hermitean operators in the most convenient way. Within canonical quantization this means to start with complex rather than real fields. The most simple example are spin-0 (scalar) fields, obeying the Klein-Gordon equation. For the complex free field there is one symmetry, namely the multiplication of a phase factor, leading to a conserved charge. For a real scalar field, there is no such charge. The real scalar field thus describes strictly neutral particles, i.e., such particles that are their own antiparticles.
  • #31
In order to make U hermitian a factor of i is inserted i.e. A=1+ieU,so it implies
AA+=1+ieU-ieU+=1,which implies U+=U
  • #32
U is a unitary operator so its not in general Hermitian. I think its Stones Theorem or something like that that says if U is unitary then A = e^iU is Hemitian so defines an observable - its used a lot in defining energy, momentum and other operators. And you are correct - your form is indeed Hermitian being the infinitesimal form of e^iU.
On second thought I think that part of my post is not that convincing - DrDu was correct it doesn't really imply a complex vector space. I like the argument I gave later based on Wigners Theorem better.
Thanks
Bill
  • #33
That's an interesting observation.
However, in the spirit of the original post, i was thinking of the non-relativistic "bog standard QM" formalism in which a single-particle wavefunction just consists of the product of a spatial part and a spin part (or a sum of such products). All i was pointing out in that case was that for a spin-1/2 particle the spin part has to be allowed to be complex because once the basis is fixed (Sz basis, say), there are spin states that require complex coefficients (eigenstates of Sy, say). I think this is a good enough motivation for the introduction of complex numbers to single-particle QM, regardless of what QFT has to say on the matter.
Also, even if the Dirac equation can be rewritten as a higher order equation in a single real component, if you then solve this equation and want to write down the field itself, you're going to presumably need complex numbers for the other components, so I'm not sure how much bearing this algebraic elimination has on the question at hand, but i might have misunderstood your point there.
  • #34
Let me note that all phenomena described by single-particle nonrelativistic QM with spin 1/2 can be correctly described (sometimes much better) by the Dirac equation.
It is not quite clear why I would need "the field itself": I will know the real component and will be able to calculate the current or some average values of observables based just on this component. The component, the current, and the averages of observables are real. What else do I need to describe all the experiments that can be described by the Dirac equation? I do appreciate that complex numbers provide very important simplifications, but the OP asked: why wave functions must be complex? Mind you, "must", not "should".
  • #35
Let me start with the following trivial remark. When you say that something "is definitely not true", it may be advisable to quote that "something", so that readers of your post do not have to guess what you had in mind. I guess that you aimed at "my" phrase "charged particles do not necessarily require complex representation." If my guess is wrong, please let me know.
I would also like to remark that this is not my phrase, but Schroedinger's (the precise quote is as follows: "That the wave function ... can be made real by a change of gauge is but a truism, though it contradicts the widespread belief about 'charged' fields requiring complex representation.") Of course, that does not necessarily mean that this phrase is correct.
First, I think the Dirac equation is also a very successful formulation of relativistic quantum theory, although it is approximate. Second, so far I don't see any proof that charged particles necessarily require complex representation.
"Convenient" does not mean "necessary".
In Nature, there is no such thing as charged free field: as soon as you have charge, you have electromagnetic field.
I respectfully disagree. If you think so, why don't you show me where exactly Schroedinger screwed up in his 1952 article? He showed that the Klein-Gordon-Maxwell equations describing a scalar charged field interacting with electromagnetic field can be re-written in terms of a real field interacting with electromagnetic field, and this real field definitely can have nonzero charge.
<h2>1. Why are quantum mechanics wave functions complex?</h2><p>Quantum mechanics wave functions are complex because they are used to describe the behavior of particles on a microscopic scale. These particles, such as electrons and photons, exhibit behavior that cannot be explained by classical physics. The complex nature of wave functions allows for the inclusion of both real and imaginary components, which is necessary for describing the probabilistic nature of quantum systems.</p><h2>2. What does the imaginary component of a wave function represent?</h2><p>The imaginary component of a wave function represents the phase of the wave. In quantum mechanics, particles are described as waves that can interfere with each other. The imaginary component of the wave function determines the phase difference between these waves, which affects the probability of where the particle will be located.</p><h2>3. Can the complex nature of wave functions be observed in experiments?</h2><p>No, the complex nature of wave functions cannot be directly observed in experiments. This is because wave functions are mathematical constructs used to describe the behavior of quantum systems, rather than physical entities. However, the predictions made by using complex wave functions have been confirmed by numerous experiments, providing evidence for the validity of quantum mechanics.</p><h2>4. How do complex wave functions relate to the uncertainty principle?</h2><p>The uncertainty principle, which states that it is impossible to know both the position and momentum of a particle with absolute certainty, is directly related to the complex nature of wave functions. The real and imaginary components of the wave function represent the position and momentum of the particle, respectively. Therefore, the uncertainty principle is a result of the probabilistic nature of quantum systems described by complex wave functions.</p><h2>5. Are there any alternative theories to explain quantum behavior without using complex wave functions?</h2><p>There have been attempts to develop alternative theories to explain quantum behavior without using complex wave functions, but none have been successful in fully describing the behavior of quantum systems. The complex nature of wave functions is a fundamental aspect of quantum mechanics and has been extensively tested and confirmed through experiments. Therefore, it is currently the most accurate and widely accepted theory for describing the behavior of particles on a microscopic scale.</p>
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
