Why are separable spaces called "separable"?
  • Context: Graduate
  • Thread starter Thread starter pellman
    Separable
10 replies · 3K views
pellman
What is getting separated from what? I presume there is some historical founding case that involved separating something. Like how the original vector spaces were mental arrows in R^3.
Definition: A metric space X is called separable if it has a subset D which has a countable number of points and which is dense in X, that is, for which the closure of D in X is equal to X.
Thanks, Svein. I know the definition. But what is the significance of the label "separable"? For example, once you see that compactness is a generalization of closed and bounded, you understand why they chose the term "compact". But why "separable"? What is the fundamental metaphor at work here? I feel that if I can understand that, I will understand the concept much better than simply being able to repeat the strict definition.
So the idea is to approximate certain elements by other certain elements. Separable means that any element of the set can be approximated by a limited number of elements.
For example, with ##\mathbb{R}##, we can approximate an arbitrary element (for example ##e##) by their decimal representation. So we can approximate ##e## better and better by
[tex]2. ~2.7, ~ 2.71, ~ 2.718, ...[/tex]
We can do exactly the same with any real number. We can do this in two dimensions too. For example, the couple ##(e,\pi)## can be approximated by
[tex](2,3),~(2.7,3.1),~(2.71, 314),...[/tex]
So separability actually is a very far-reaching generalization of the decimal representation. So basically, we have a countable number of "basis" elements, and then we succeed in approximating any element by the basis elements.
In the theory of Hilbert spaces, the analogy becomes even better with the existence of countably orthonormal bases. But I can only tell this if you know Hilbert spaces.
In a very general sense, you should see separable spaces and spaces which are "not too large" and where countable many terms suffice in many cases. In the same way that rational numbers can be used to describe real numbers.
It turns out that a very large portion of all spaces encountered "in nature" are separable. This is especially true in physics. This is good because it allows us to describe a physical system by countably many terms (like position, momentum, etc.) instead of dealing with uncountabilities.
micromass said:
So the idea is to approximate certain elements by other certain elements. Separable means that any element of the set can be approximated by a limited number of elements...
This is very helpful, micromass. Thank you.
How do you use that analogy in non-metrizable separable spaces?
How do you use the approximation analogy in non-metrizable separable spaces?
