Why Are Sound Waves Invisible to the Human Eye?
The discussion revolves around the question of why sound waves are not visible to the human eye. Participants explore various aspects of this topic, including the conditions under which sound waves might be seen, the nature of sound waves, and the limitations of human perception.
  • Some participants question the expectation of being able to see sound waves at all.
  • It is proposed that sound waves can be seen under specific conditions, such as when they create significant density changes in the air, which can refract light.
  • Techniques like schlieren photography are mentioned as methods to visualize sound waves when they are powerful enough.
  • There is a discussion about the limitations of human perception, with some arguing that our eyes are not designed to detect sound waves directly.
  • Participants note that sound waves are density waves and that visibility depends on the amplitude of the waves.
  • Some express skepticism about the visibility of sound waves, suggesting that only very loud sounds would be visible.
  • The analogy of seeing the movement of speaker cones is used to illustrate the visibility of sound at certain levels.
  • One participant emphasizes the need for clarity in the original question, suggesting that the discussion may have diverged from the intended scope.
Participants do not reach a consensus on the visibility of sound waves. While some agree that sound waves can be seen under certain conditions, others maintain that the expectation to see them is unfounded. The discussion remains unresolved regarding the specifics of visibility and the conditions required.
There are limitations in the discussion regarding assumptions about visibility, the definitions of sound waves, and the conditions under which they might be seen. The scope of the original question is also noted as potentially unclear.
Dremmer
Why can't we see sound waves?
why would you EXPECT to be able to see sound waves ?
We can, to the extent that dense air refracts light. This is visible in the shock waves resulting from exploding bombs.
Low volume sound waves in air move fast, don't refract much and have even less effect when viewed from the direction of either source or receiver, so you cannot expect to see the sound of your own voice with your own naked eyes.
The short answer is you can, but the sound has to be very loud.
Google "schlieren" and you can see even some minute sound waves. If the waves are powerful enough to cause large density gradients we can see them through the light they refract. Slightly weaken and we can use schlieren or shadowgraph techniques to see them.
In a sense we can see sound, we just call it "hearing".
Or do you also wonder why we can't hear light?
phinds had it right though. There is no reason to assume we can.
Yes there is. Sound waves are density waves, and the index of refraction of air changes with density, so you should be able to see the wavefront as an interface between two regions of different density, which you can, if the amplitude is high enough, or if you use the methods boneh3ad posted.
Yeah, I was just assuming he meant voice-level sound waves. I knew really strong density waves would be visible, as you say.
I don't think anything that would not break your eardrums if you were anywhere near it would be strong enough to see.
Have you ever seen a jet break the barrier for the speed of sound?
But we see that second hand, I assumed the OP meant directly.
I think it is because air is fairly transparent.
If you could see air, then you would probably be able to see sound waves, of certain magnitudes and frequencies. Kind of like sitting and staring at your audio speakers. You can see the woofers moving, but the tweeters just sit there, and make your ears hurt.
remember that a wave is only "how energy travels" sound waves are more of a slight amount of energy exerted from initial contact, or an after effect of disruption in the air traveling outward.
you disrupt the water by dropping a stone, you see waves.
you disrupt the air by clapping your hands, you hear a wave.
your only going to see sound waves that are large relatively in comparison to yourself
While the above replies make it clear that we can see sound waves in specific circumstances, I feel they don't really answer the question. I would say that we can't see sound waves because our eyes aren't designed to be able to do so. The eye uses a lens that focuses light onto the retina where special cells that are sensitive to light reside. These cells detect the light and send signals to your brain. The end result is sight.
Sound waves do not activate any part of the visual system and so we cannot see sound waves directly, only when light interacts with a sound wave in a certain way. Instead our ears are designed to detect sound waves.
No, have you? I have HEARD it several times but there has never been anything to see.
Discussions on here have the tendency to stretch things out way outside of the scope of the question. The OP hasn't come back to respond and clarify the question. I suggest we all sit back and be patient till that occurs before tripping all over ourselves on what the question really is asking for (I doubt the OP was thinking about seeing the refraction of light due to variation in air density).
Zz.
https://www.youtube.com/watch?v=gWGLAAYdbbc
  • · Replies 31 ·
9K
  • · Replies 43 ·
