Why can positron go unobstructed through lead?
  • Thread starter Thread starter L-I-C
    Lead Positron
Positrons can pass through lead due to the pair-production mechanism, where high-energy gamma rays interact with lead nuclei, creating electron-positron pairs. This process explains why positrons appear to emerge from a lead plate rather than penetrating it. The discussion highlights that unlike the gold foil experiments, which use very thin materials, lead's thickness does not prevent the creation of positrons. The initial assumption that positrons could penetrate lead directly is incorrect; instead, they are generated within the lead itself. Understanding this mechanism clarifies the results observed in Anderson's positron experiment.
L-I-C
Can anyone explain why a positron, in a charged magnetic field, is able to go through a 6mm lead plate, as seen in Anderson's positron experiment?
Initially I thought that it could be quite similar to the gold foil experiments, but one of the features of the gold foil experiments is that it is using a VERY thin sheet of gold.
From what I understand lead, especially lead that thick, has the ability to not easily allow particles through.
Am I taking the wrong approach?
http://en.wikipedia.org/wiki/File:PositronDiscovery.jpg
In trying to understand the results of his experiments, Anderson consulted several other prominent physicists, including Robert Oppenheimer. Anderson's discussions with Oppenheimer proved fruitless; however, other physicists were studying cosmic rays like Anderson at this time. Two of them, P.M.S. Blackett and G.P.S. Occhialini, proposed the pair-production mechanism, where high-energy photons, like the gamma rays found in cosmic radiation, will strike a nucleus and produce an electron-positron pair. These particles will annihilate one another after a brief period, turning back into two gamma rays.
It's not that positrons penetrate lead, but positrons are produced within the plate when high-energy gamma rays strike one of the lead nuclei.
For details on the pair-production mechanism, see this article:
http://en.wikipedia.org/wiki/Pair_production
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
