Why can't logs have a negative base?
  • Level: Undergrad
  • Thread starter Thread starter Rumplestiltskin
    Base Negative
6 replies · 7K views · last reply
Rumplestiltskin
I understand that taking logs of a negative number isn't possible because no number to any power produces a negative number. But why not a negative base?
Say, log-10(100) = 2. Rewritten, -102 = 100, which is accurate.
You could suggest that you may as well just ignore the negative because -x2 = x2, but it's still weird that this shows up as a syntax error on a calculator.
Mathematics news on Phys.org
Try to calculate log-10(50)=x.
Or, alternatively, solve log-10(x)=1.7. What is x=(-10)1.7?
For integers (with the right sign) as logarithm values, it would work, but only for those.
No, it isn't. ##-10^2 = - 100## because the exponent has a higher precedence than the negation sign. What you probably meant was ##(-10)^2##, which is 100.
For the reason given above, ##-x^2 \ne x^2##, unless x happens to be 0. If you want to square a negative number on a calculator, put parentheses around the number, with the exponent outside the parentheses.
Moved from Homework sections, as this is more of a general question than a homework question. @Rumplestiltskin, be advised that if you post in the HW sections, youi need to use the homework template, not delete it as you apparently did.
You should be more careful regarding order of operations.
-102 = -100
and
-x2 = - (x2)
I assume you meant to write
(-10)2 = 100
and
(-x)2 = x2The main problem with having a negative base in a logarithm, is that there is a problem defining a real valued exponential function having a negative base.
Syntax error on calculator. When typed into google, (-10)1.7 = 29.4590465 - 40.5468989 i. Woah. Still at a loss.
Could you elaborate?
Syntax error on calculator. When typed into google, (-10)1.7 = 29.4590465 - 40.5468989 i. Woah. Still at a loss.Could you elaborate?
That's a complex number. Isn't that a problem for a real function?
Try (-10)π .
