2025 Award
- 17,145
- 10,650
No.legyptien21 said:Do we agree ? if not why ?
Where do the equations come from ?
What do the symbols mean ?
Baluncore said:No.
So you are saying that the part of the incident wave that is not reflected, but which passes through the impedance mismatch, is reflected as C.legyptien21 said:C is the amplitude of a wave which is part of the incident wave since we decide Vi = Vr + C.
Baluncore said:So you are saying that the part of the incident wave that is not reflected,
You cannot have a superposition of a standing wave and a propagating wave.legyptien21 said:Then I interpretated the results as a superposition of standing wave and propagating wave.
legyptien21 said:do we agree on the mathematical derivation ?
Baluncore said:No.
That should be Es = Vi * Sin(wt + kx) + Vr * Sin(wt - kx)legyptien21 said:Vr*(sin (wt - kx) + sin (wt + kx)) represent a standing wave if we use the Simpson formula...
If you ever had a 'complete' reflection at the ends of a cavity, the amplitude of the standing wave would build up until it was infinite. A cavity, just like a resonant wire (as in a tuned dipole) will have a resonant frequency but, because of its finite Q factor, it will: 1. have a finite standing energy and 2. a finite bandwidth.legyptien21 said:If we have NOT full reflection on the wall so it means there is no standing wave in the cavity right ? the max and mins are moving ?
You mean a bandwidth different than 0 ? because if we had a full reflection as you said, we would have had a infinite quality factor (with bandwidth = 0) if we suppose a lossless cavity right ?sophiecentaur said:a finite bandwidth.
sophiecentaur said:There will be power entering the cavity at one end and power leaving the cavity at the slots, resulting in a standing wave (when the frequency and dimensions are appropriate) but the (stationary) nodes of the standing wave will not be perfect because of the net power flowing through them.
davenn said:you have already been told that your workings in post # are incorrect
Baluncore corrected them in post # 39
legyptien21 said:to me because his equation have no sense.
If you go back and look you will see that I clearly defined x as a time relative to incidence at the load. That eliminates the velocity factor from the equation.legyptien21 said:If the equations are right then we take the most general case to do a derivation not a case where we add time in sec with X in meters...
Baluncore said:At a point a time x before the load, ...
... At a point back up the line, a time x after reflection from the load, ...
The period T is sufficient. Wave number and angular speed are the same for all.legyptien21 said:Can you guess the wavelength of his equations... ?
Baluncore said:If you go back and look you will see that I clearly defined x as a time relative to incidence at the load. That eliminates the velocity factor from the equation.
I clearly defined the incident wave at the load when I wrote ...legyptien21 said:Ei = Sin(t) this is your incident wave I believe ?
Baluncore said:The incident wave at the load will be Ei = Sin(t).
I clearly defined x as a time. You chose to ignore it.legyptien21 said:if you start to switch all letter and their meaning, noboday will follow easily.
The incident wave will be a sine wave at the load, Ei = Sin(t). Earlier on the line it will have a time shift of x, giving Ei = Sin(t+x).legyptien21 said:in every incident wave there is X which represent the distance. so where is the distance in your equation, where is the propagation.
legyptien21 said:if you start to switch all letter and their meaning, noboday will follow easily. Anyway, I m open to talk about that :
Ei = Sin(t) this is your incident wave I believe ? in every incident wave there is X which represent the distance. so where is the distance in your equation, where is the propagation. there is no point to write it that way and to eliminate the velocity...
If you wanna write your derivation with letters and their meaning as your asked me then I will follow you otherwise no one will be able to...
It s late for me now I will answer tomorrow
