Why do sparks radiate photons?
  • Thread starter Thread starter Jonsson
    Photons
Electric sparks release more heat than electricity conducted through a wire due to their short lifespan and minimal mass, resulting in extremely high temperatures. The energy radiated from an electric spark varies based on factors beyond just electric current, including the conditions of the gas between electrodes and the efficiency of the components involved. For example, automotive spark plugs endure significant stress and are designed to handle rapid cycles of ignition. Additionally, in processes like welding, energy loss occurs in the supply leads and transformers, contributing to overall heat generation. Understanding these dynamics is crucial for optimizing applications that utilize electric sparks.
Jonsson
Hello there,
I am an undergrad physics student.
Electric sparks are used to ignite fuel. However, why do electric sparks release more heat than electricity conducted through a wire?
And what influences the amount of heat radiated from an electric spark? Why do some sparks radiate a lot of energy, whilst others do not? Is this only proportional to the electric current? Or are there other factors involved?
Thank you for your time.
Kind regards,
Marius
Science news on Phys.org
A spark can have a very short lifetime and there is very little 'mass' involved. This means you get a very high temperature. If you wanted to do the same thing with a 'resistor', it wouldn't last very long - for instance an automotive spark plug has a really tough life and the highly stressed component (the gas between the electrodes) is replaced every time the spark fires.
If you think about the arc that's used in welding, there is also a lot of energy dissipated in the supply leads and transformer, despite the fact that very thick wire is used. (Isquared R losses)
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
After my surgery this year, gas remained in my eye for a while. The light air bubbles appeared to sink to the bottom, and I realized that the brain was processing the information to invert the up/down/left/right image transferred to the retina. I have a question about optics and ophthalmology. Does the inversion of the image transferred to the retina depend on the position of the intraocular focal point of the lens of the eye? For example, in people with farsightedness, the focal point is...
