Why do we need enthalpy when we have internal energy?
  • Level: Undergrad
  • Thread starter Thread starter muslach
    Confusing Enthalpy
50 replies · 8K views · last reply
muslach
Hello , I don’t think enthalpy makes sense, I am here because I want a clear explanation for what it really is.
It has been said it is the internal energy and the volume it takes as in work (W) but why? Why do we even need enthalpy what is the problem with delta U!
It is equal heat and pressure times volume it describes the work it has done to achieve the volume and the heat energy (average kinetic energy) there is no need for anything else to describe the energy change except delta U.
Enthalpy and internal energy are different things. Neither can replace the other.
In particular, whether a process is exothermic or endothermic depends on the change in enthalpy, not the change in internal energy. Internal energy only considers the internal energy and not the work that must be done on the external environment.
The enthalpy is relatively more useful than U when the environment is at P constant, that is why we use it. For example, suppose you want to "create" some system, i don't know, maybe make a cake. You give him the energy necessary to it "be a cake", is that enough? Well, normally the cake will need to increase its volume right? Do you think it will take energy from where? All energy you give it is to make him a "cake", it has no more energy to do anything. You need to give more energy to it expand and become in fact a "cake". So it need to do work on the environment. If it were a gas, the work would be Pdv... Wow, wait. If it were a gas, that is, if you "want" to create a gas, so you would need to give it its internal energy, plus Pdv to its expand, that is H = U + PV. Call it enthalpy and be happy.
An idiot example, but hope you get it.
Dale said:
Internal energy only considers the internal energy...
Do you mind if I put this on a tile and hang it in my toilet? 😋
  • Haha
LCSphysicist said:
The enthalpy is relatively more useful than U when the environment is at P cte
I suppose "P cte" means "constant pressure". I've never seen it used in US English.
It sounds almost French to me.
muslach said:
Summary:: prove to me that enthalpy can replace delta U
So you are saying there is NO difference between a constant volume process and a constant pressure process( or any process that involves a change in volume)?
The properties of state can be combined in a manner to form another property of state.
Enthalpy is one such property that has been found to very useful in thermodynamic calculations.
Just as an example,
Steam tables even give you tabulations of internal energy, enthalpy and entropy for saturated liquid, saturated vapour and the change form one to the other.
http://homepages.wmich.edu/~cho/ME432/Appendix1Udated_metric.pdf
Table A-4, A-5
and you can study and play around with the numbers to get a better feel of enthalpy.
We want to be lazy efficient. Determing the change of internal energy at constant pressure and without non-volumetric work requires the measurement of heat and work but for the change of enthalpy we need to measure the heat only.
PS: At constant volume we would only need the heat for the change of internal energy. However, keeping the pressure constant is easier. Under normal consitions the atmosphere does this job for us.
Hahaha cte is "constante", it is actually portuguese notation. Sometimes i didn't notice i mix both language :P
All the thermodynamical potentials are related by Legendre transformations and each has "natural independent" thermodynamic variables. E.g., one usually starts with the internal energy (for simplicity in the canonical ensemble of a gas, i.e., a fixed number of particles in therma contact with a heat bath at temperature ##T##). Then one has
$$\mathrm{d} U = T \mathrm{d} S - p \mathrm{d} V,$$
i.e., the "natural variables" for ##U## are ##S## and ##V## and you have the relations
$$T=\partial_S U(S,V), \quad p=-\partial_V U(S,V).$$
Sometimes one writes
$$T=(\partial_S U)_{V}, \quad p=-(\partial_V U)_S,$$
with the subscripts indicating which variable has to be kept constant when taking the partial derivative with respect to the other independent variable. It's clear that the internal energy is particularly convenient to use for isochoric processes, i.e., when ##\mathrm{d} V=0##.
The enthalpy is defined as the potential with "natural variables" ##S## and ##p##. It's given by the corresponding Legendre-transform of ##U##, i.e.,
$$H=U+p V.$$
Indeed, then one finds
$$\mathrm{d} H=\mathrm{d} U + V \mathrm{d} p + p \mathrm{d} V=T \mathrm{d} S+ V \mathrm{d} p.$$
Now indeed the "natural independent variables" for ##H## are ##S## and ##p##, ##H=H(p,V)##, and you have the relations
$$T=(\partial_S H)_{p}, \quad V=(\partial_p H)_{S}.$$
It's also clear that ##H## is convenient for isobaric processes, i.e., for ##\mathrm{d} p=0##, and that's why it's particularly often used in chemistry when considering reactions at constant (lab) pressure.
Enthalpy is just a very convenient property to work with in analyzing many kinds of thermodynamic systems. As you get more experience, you will see how it comes into play. Could we get along without enthalpy and just work entirely with internal energy and entropy in analyzing thermodynamic systems? Yes. But, as I said, working with enthalpy is very frequently more concise and convenient.
Table A-4, A-5
I'm still confused. Those Steam TablesA-4 and A-5 quote enthalpy as kJ/kg. Isn't Enthalpy measured in Joules (or kilo Joules), not Joules/kg?
Enthalpy is an extensive property, so if you divide it by the mass of the material you have, you get the enthalpy per unit mass. Since the steam tables don't know how much mass you have, they give the enthalpy per unit mass.. You just multiply this by the amount of mass of material you have to get the enthalpy.
Still trying to get my head around enthalpy. In what way is it relevant to the behaviour of an ideal gas? Can you give a simple example please?
I should have been more specific: Is the consideration of enthalpy relevant in the study of aerodynamics of aircraft wings and yacht sails, i.e. in (dry) air at wind speeds of 0 to 300 kts, in temps of 0 to 25°C in the normal atmosphere below say 10,000 ft? Is enthalpy more relevant to exo/endo-thermic reactions?
Yes.
More relevant than what?
You seem to be coming at this at a very elementary level. Please summarize your background in Thermodynamics study so that we can tailor our answer your questions at the appropriate level.
Chestermiller said:
Yes.
I have a degree in mathematical physics Birmingham UK 1967, and failed thermodynamics! I have re-connected with the topic over the past two years in an attempt, as a racing yachtsman, to understand the source of the aerodynamic force from a sail.
I have done a lot of reading, including Marchaj, Fossati, Gentry and I have studied Eiffel's research report in his book. I am now three weeks into reading Anderson to see if he can provide some answers and have come unstuck at Section 7.2 when for some unexplained reason, he introduces:
"A related quantity is the specific enthalpy, denoted by h and defined as h = e + pv (7.3)"
I have returned to my Physics text (Starling and Woodall) to find enthalpy introduced in Ch 13 "Equations of state" and read that it's involved in the work separating molecules (p284).
Now the aerodynamics of sails is not about state changes: Air is a simple and pretty ideal gas in all stages of sailing (as it also is in domestic flying). No state changes, no molecular attraction to overcome, so I'm confused.
Maybe you can help?
[EDIT] Why is it important? Because I'm trying to understand the "air can be considered incompressible below Mach 0.3" assumption which he "proves" in an incredibly long and complex argument which, inter alia, includes, and thus relies upon, the differentiation of the enthalpy equation at (7.19). [/EDIT]
A very concise book at an introductory level is
R. Becker, Theory of Heat, Springer (1955)
As a mathematical physicist it should be easy for you to understand that behind all the thermodynamic potentials are just Legendre transformations to get from the internal energy, ##U(S,V,N)## to other equivalent descriptions of the system with other "natural independent variables". It's all derived from the differential
$$\mathrm{d} U=T \mathrm{d} S -P \mathrm{d} V+\mu \mathrm{d}N.$$
Here ##T## are the temperature, ##S## the entropy, ##P## the pressure, ##V## the volume, ##\mu## the chemical potential (for the conserved particle number or charge ##N##).
To get a potential with "natural independent variables" ##S##, ##P##, and ##N## you do the Legendre transformation to the enthalpy,
$$H=U+p V,$$
which indeed leads to
$$\mathrm{d} H = \mathrm{d} U + P \mathrm{d} V + V \mathrm{d} P = T \mathrm{d} S + V \mathrm{d} P + \mu \mathrm{d} N.$$
As long as the temperature of the air does not change much due to air compression and viscous frictional heating at the surface of the wing or sail, you can treat the flow as isothermal, and you don't need to address enthalpy. Enthalpy comes in when you need to consider the occurrence of temperature changes (like in re-entry of a space vehicle). So in your cases, you can use the isothermal flow differential equations of fluid mechanics.
At the risk of being accused of being too simplistic in this erudite environment, try this...
Suppose you have a sample of an ideal gas at absolute zero.
You want to raise its temperature to some value T - and introduce this heated gas into a constant-pressure environment with pressure P.
To do this, you have to supply two lots of energy:
1) the internal energy (U) to raise the temperature from 0 to T; this energy is the kinetic energy of the (ideal) gas particles at temperature T;
2) sufficient energy to push the constant-pressure environment outwards (because the gas volume changes from zero to some value V = nRT/P); this requires an amount of work W = PΔV = P(V-0) = PV.
The total energy is the enthalpy: H = U + PV
Changes in the enthalpy during a process reflect not only changes to internal energy but also work done on/by the environment.
[Minor edit made for clarity.]
But the temperature of the air will change due to compression - it doesn't matter if the change large or small, the process (air over a wing or sail) is not isothermal.
I don't want to use isothermal equations.
The aerodynamic process is not exothermic or endothermic and there is no change of state (or phase), between gas, liquid or solid, so what's enthalpy doing in the equations?
I want to understand why Anderson introduced enthalpy.
$$H=U+p V,$$
I have a copy of Becker, Theory of Heat.
It references enthalpy on 9 pages of 370 but nowhere does it provide a definition other than the formula: Free Enthalpy G=E -TS+pV which is not explained.
My question is why Anderson would use of enthalpy in the discussion of the aerodynamics of wings and sails.
No, please don't risk being too simplistic. That's what has led me to this point, but simplicity has to be logically valid.
You can't start even a simplistic explanation with "Suppose you have a sample of an ideal gas at T=0 (i.e. absolute zero)" because at absolute zero theoretically a gas has a volume of zero (in practice of course it would be a solid)
So, I'm afraid your explanation doesn't help answer my question.
I would argue that for a classical ideal gas, it is perfectly reasonable to consider the limiting state where the temperature is zero. The corresponding volume will, of course, also be zero because an ideal gas consists of point particles (each having zero volume).
But if preferred, you could change the argument in Post #20 so that the initial temperature and volume are arbitrarily small - e.g. ##T_i = 10^{-20} K## and ##V_i =10^{-20}m^3##. It doesn't change the explanation.
[Edited]
But if preferred, you could change the argument in Post #20 so that the initial temperature and volume are arbitrarily small - e.g. ##T_i = 10^{-20} K## and ##V_i =10^{-20}m^3##. It doesn't change the explanation.Formation of the solid state requires inter-particle forces. But an ideal gas has no inter-particle forces. But for a real gas, you are correct.
OK, so you get a value for enthalpy, but what do you do with it?
If you add heat to a gas you will increase its enthalpy in both of its terms. U will increase and so will PV will increase.
I can find no "rules" for its use. No-one is saying there is a law of conservation of enthalpy.
What use is it in aerodynamics?
The change will be very small, and you'll be killing yourself to include this for no reason. In any event, you can treat the flow as isothermal and then confirm the small temperature rise (and its predicted small effects) a'postiori.
Enthalpy (per unit mass) is just a very convenient function of temperature, equal to the internal energy per unit mass plus pressure times specific volume. This combination occurs frequently in thermodynamic situations, particularly those involving steady flow. It is present in the energy balance equation (say for steady flow over a wing or sail) to enable you to calculate the temperature distribution. Of course, we don't need to work in terms of enthalpy, and can work in terms of internal energy instead, but, like I said, the combination u + pv frequently occurs in the flow equations and is easier to work with.
The problems come in when we start to try to assign physical interpretation to enthalpy. This invariably causes confusion to beginners for no reason. It is better just to consider enthalpy as a convenient parameter to work with.
You say it is a very convenient function...but convenient for who? I understand the equation H = U +PV, but what use is it? If heat is applied, or work added (i.e. compression) to a quantity of (ideal) gas, there's no phase change, no exo/endothermic reaction, the value of H increase in both of the terms. There's no law of conservation of enthalpy.
Why does enthalpy appear in aerodynamics of sails or wings at subsonic, atmospheric conditions?
Incorrect. What you are saying is that you have no idea how the enthalpy function is applied in practice to solve for the temperature distribution in a fluid flow (and its feedback effect on the flow). So you have some learning to do.
The first step is to get an understanding of how enthalpy comes into play in the derivation of the open system version of the first law of thermodynamics, which considers fluid flow into- and out of a system, in addition to heat and work. You can learn about this in Fundamentals of Engineering Thermodynamics by Moran et al. (Chapter 4) The enthalpy function enters naturally in this derivation in place of internal energy for a closed system.
Your next step should be to read Chapter 11 of Transport Phenomena by Bird, Stewart, and Lightfoot : The Equations of Change for non-Isothermal Systems. This looks at situations where the temperature and other parameters are changing both with spatial position and time using partial differential equations. See in particular Table 11.4 which gives the energy balance equation in terms of enthalpy as well as in terms of CpdT, which is the differential of enthalpy.
After completing the studies I just recommended, you will realize the answer to this question.
Chestermiller said:
Incorrect.
That's a bit blunt!
Could you expand a little please as to which of those statements is incorrect?
1) H = U +PV
2) If heat is applied, or work added (i.e. compression) to a quantity of (ideal) gas, there's no phase change, no exo/endothermic reaction,
3) the value of H increase in both of the terms.
4)There's no law of conservation of enthalpy.
Sailor Al said:
That's a bit blunt!
So what. Just adding heat and doing work (including viscous work) causes enthalpy and temperature to change: dH=CpdT
Yes there is. Just master the material that I recommended for you and you will how this equation is derived.
