Why does a voltmeter measure a voltage across inductor?
115 replies · 23K views · last reply
@OnAHyperbola Thank you for the video of post #52. I watched the first 20 minutes of it and it is a very good one. I looked for your comment, (on Youtube), but I think it might need to get approved. (I will check for it again later). editing... Question: Are you "marcandrin"? If so, yes, I see the comments.
@Charles Link Yes it's the conversation between Walter Lewin and marcandrin that I was referencing. It is very illuminating. It was when Lewin said that pulling either voltmeter over to the other side (by 180 degrees) would make it show an entirely different reading (the readings will switch with each other, in fact) that blew my mind and really set it in that geometry matters. I am not marcandrin, by the way :) although I have their curiosity to be grateful for.
The video is very much the problem that was discussed earlier in the thread: (See posts #8,10, 23, 27, 28, etc.). I first saw this puzzle in approximately 1979. I don't know if Professor Lewin is the one who originated the problem back then, but he may have been. And thank you so much for posting the video!
The problem that I have with Dr Lewin's presentation is that it is a scenario which explicitly violates the assumptions of circuit theory. Of course the equations of circuit theory don't work when you violate the assumptions of circuit theory!
It makes no sense to claim that there is anything wrong with KVL in this case. It is like saying that there is something wrong with the conservation of momentum by showing that it doesn't work for a system acted on by an external force.
The problem isn't KVL, the problem is using circuit theory where it doesn't apply.
Why does this example violate the assumptions of circuit theory? Lewin's writeup correctly uses circuit theory to explain the measured result!
Professor Lewin's problem is very much a part of the circuit theory as I know it. I first saw this problem in 1979 when a Mr. Jerry Davis, M.S.E.E. showed it to me when I was a graduate physics student. He didn't know what was causing the dilemma, but I figured it out within a week or so. I later saw it in a college E&M textbook approximately 2002 where a co-worker at my workplace, a B.S. in physics who was getting his M.S. asked me for assistance with his homework problem because he was stuck on it. It seems to have become part of the curriculum. Professor Lewin has evidently helped to make it somewhat well-known. I didn't know he had videos and printed notes of the problem and its solution until this current thread.
Well, I think this thread has been one of the finer learning experiences I have had. Precisely because the solution was so simple, right there in Faraday's law and I kept getting all muddled in complicated reasons to account for that deceptive little voltage drop. (Note to self: Find the loop, find the flux through it, get the induced emf)
Many thanks to all of you! I hope you had as great a time as I did.
One additional comment in regards to Professor Lewin's instruction. Besides being a good lesson in EMF's, it is also a good lesson in stray EMF's. e.g. When measuring an electronic circuit with a voltmeter or oscilloscope, it is always good to run your two wires as closely connected as possible to each other in traveling from the voltmeter to the circuit being measured. Often a coaxial cable is used for these two wires, but a twisted pair can also work quite well. You certainly don't want to run your two wires in such a way that they happen to encircle an active power transformer that is part of your laboratory equipment (such as the ac to dc converter inside a piece of laboratory electronics, etc.). You would wonder where all the stray 60 Hz signal is coming from... :-) :-) Editing... Two things could actually happen here: 1)You observe a false 60 Hz signal on your oscilloscope that isn't in the circuit. 2) You disrupt your circuit by sending in a 60 Hz signal from your measurement probes! :-) :-)
No, it doesn't.
First, one of the three basic explicit assumptions of circuit theory is that there is no magnetic coupling between circuit elements, only within a element. So as soon as he starts talking about an induced EMF he has violated that explicit assumption. The other violations are implicit
Second, there are no fields in circuit theory, as soon as he starts drawing fields he is using Maxwell's equations. Circuit theory uses voltages, currents, and circuit elements, not fields. Think about it, there is no standard circuit element for representing a B field, because it is not part of the theory.
Third, a circuit diagram does not have any sense of spatial position. The loop drawn on the diagram may be a coaxial cable, a twisted pair, or some other configuration with minimal area for flux. Or it could have multiple large loops. There is no way to perform an integral over space within circuit theory because position isn't part of the theory.
Dr Lewin is using classical EM, not circuit theory. This is fine, he is a physics professor, not a EE professor. But I think it is poor form to give students the false impression that there is something wrong with KVL instead of giving them the correct understanding of the assumptions and limitations when circuit theory can and cannot be used.
I think Professor Lewin does a very good job in presenting both the concept of EMF and the solution to this puzzle. The puzzle I had actually seen and solved in 1979. I don't know whether it originated with Professor Lewin, but he does illustrate a couple of concepts extremely well. Professor Lewin's example also helps to illustrate the physics behind how an inductor works. I do think it is a very useful thing to be able to tie circuit theory with classical E&M. In this case, the circuits used are simple ones. For more complex circuits, you generally want to ensure that you don't have stray EMF's interfering with the circuits. And one other item that came out of a careful study of the physics involved here is the concept that the Faraday EMF is virtually indistinguishable from an electrostatic potential by common laboratory apparatus such as an oscilloscope or a voltmeter. I think most of the OP's questions were answered through the course of he discussion, and I found the discussion very worthwhile as well.
I agree.
I just think that he inappropriately maligns KVL. Whenever the assumptions of circuit theory are met KVL is valid.
I had trouble following much of this thread, too much verbiage and too few equations and diagrams for me. But the thigs @Dale said about the assumptions of circuit theory were very interesting. I, along with many others on both the physics and EE sides, have never stopped to think of which explicit assumptions those are.
I looked them up, and found the slides of a lecture on that subject. Starting at slide 18, it becomes very interesting, touching on just the things that @Dale urged us to consider.
http://web.ewu.edu/groups/technology/Claudio/ee209/f09/Lectures/physics.pdf
One can study electricity at the QED level, or Maxwell's equations, or Circuit Theory, or RF propagation levels, and each makes sense as if they were isolated domains. However, spanning the boundaries between the levels I always thought exceedingly difficult. Thank you @Dale for showing me that at least one of those transitions is orderly and approachable.
Dale said:
No, it doesn't.
(1) So you are saying, that it's not allowed to have transformers and even simple coils in your circuits? I'm sure electrical engineers wouldn't buy that.
(2) All you use in ciruit theory are the Maxwell equations in integral form, lumping the geometry (i.e., boundary conditions) of the setup into various constants (resistivities, capacities, self and mutual inductance).
(3) To analyze a circuit you need to specify the sense of the underlying line integrals. The orientation of the corresponding surface integrals is then determined by the right-hand rule, which is used to define the quantities of the theory to begin with. Only then you get the various signs in a problem right, also in cases where this is not so obvious from intuition.
For ciruit theory you need classical electromagnetism, i.e., Maxwell's equations, and the above link is to be taken with great care since the concepts are not always accurate but commits several didactical sins you often find even in textbooks. They are not plain wrong but forget to explain the context and meaning when they are used. Just some examples
On slide 7: They claim there's a "Gauss's Law for magnetic fields". The only Gauss's Law of the magnetic field (there's only one magnetic field in nature!) is explained correctly on the slide before. On slide 7 they discuss Ampere's circuital law, which is valid only for static fields and stationary currents. In SI units it reads in differential form (which always the save starting point for all electromagnetic theory) it reads
$$\vec{\nabla} \times \vec{H}=\vec{j}.$$
Together with the constitutive equation ##\vec{B}=\mu \vec{H}## and in the vacuum (where ##\mu=\mu_0## becomes
$$\vec{\nabla} \times \vec{B}=\mu_0 \vec{j}.$$
First of all this tells you that you must have
$$\vec{\nabla} \cdot \vec{j}=0$$
everywhere. This is nothing else than the equation for charge conservation for stationary currents. This is very important to keep in mind. Thus to get corre t results from the Biot-Savart Law, which is derived by taking the curl of the Ampere law and using the true Gauss's Law for magnetic fields, ##\vec{\nabla} \cdot \vec{B}=0##, you have to integrate along closed circuits. The explanation with "current elements" has thus to be taken with a grain of salt.
On slide 8 they are very sloppy concerning the order of integration and time derivative on the right-hand side. The basic law is again the differential form, which is Faraday's Law. In SI units it reads
$$\vec{\nabla} \times \vec{E}=-\partial_t \vec{B}.$$
Integrating over a surface ##S## with boundary ##\partial S## and using Stokes's Law you get
$$\int_{\partial S} \mathrm{d} \vec{r} \cdot \vec{E}=-\int_S \mathrm{d}^2 \vec{S} \cdot \vec{B}.$$
Note that the time derivative is taken BEFORE the integral here. To get it out for the general case is not so easy. Of course, if the surface including its boundary is at rest in the calculational frame, the equation on slide 8 is correct. Otherwise you get the correct law in integral form as
$$\mathcal{E}=\int_{\partial S} \mathrm{d} \vec{r} \cdot (\vec{E}+\vec{v} \times \vec{B})=-\mathrm{d}{\mathrm{d} t} \int_S \mathrm{d}^2 \vec{S} \cdot \vec{B}=\dot{\Phi}_B.$$
So on the left-hand side you get the FULL EMF, including the magnetic force along the boundary (##\vec{v}=\vec{v}(t,\vec{r})## is the velocity of the boundary of the surface). In any case if the right-hand side (i.e., the time derivative of the magnetic flux through the surface) is not vanishing there's no potential for ##\vec{E}## for the static case, and this is important, also in circuit theory which of course also includes magnetic effects like self inductances and mutual inductances (as well as generators which produce the AC current in our households in the first place) as needed to analyze transformers. Lewin's example is nothing else of an inductively coupled source, i.e., a transformer of an AC current. On page 9 it must read that ##\vec{E}## is the total electric field along the path of the surface boundary (and again that it's valid only for the case of surface and its boundary at rest).
On slide 13 they precisely give handwaving (note that there are no equations!) explanation for the very case that they do not treat correctly in the slides before, namely the case of moving surfaces/boundaries.
One must say that the discussion from slide 19 on is pretty accurate, particularly the discussion on p. 21. Also on page 25 it is correctly stated that there's "a voltage", BECAUSE the magnetic flux is vanishing (negligible) in the case discussed.
@vanhees71 Very good reading=your posts #73 and #74. I agree it is important to include the physics of Maxwell's equations with the circuit theory or some of the finer details can be very ambiguous. One correction on post #74. (Hopefully you concur.) Ampere's law (in complete , non-steady-state) is ## \ ## ## \nabla \times B=\mu_o \, J_{total}+\mu_o \epsilon_o \, dE/dt ## ## \ ## where ## \ ## ## J_{total}=J_{free} +J_m+J_p ##. ## \ ## Now ## \nabla \times M=\mu_o \, J_m ## and ## J_p=dP/dt ## .## \ ## This gives ## \ ## ## \nabla \times H=J_{free}+d D/dt ## ## \ ## where ## \ ## ## B=\mu_o \, H+M ## ## \ ## and ## \ ## ## D=\epsilon_o \, E+P ##. ##\ ## The reason for the extra detail is it is important to include the non-steady state ## dE/dt ## term in analyzing a capacitor in the case where the electric field in the capacitor is non steady state. (Note: One vector identity that is used in analyzing the above is ## \nabla \cdot \nabla \times A =0 ## for any vector ## A ##. Also ## \ ## ## - \nabla \cdot P=\rho_p ## where ## \rho_p ## is polarization charge density. The continuity equation applies ## \nabla \cdot J_p+ \frac{\partial {\rho_p}}{\partial t}=0 ## ) . In order to have consistency, the complete form of Ampere's law (rather than the steady state form) is necessary. (In the case that a capacitor is being charged, ## \nabla \cdot J_{free} ## is not equal to zero) (Besides the inductor, the capacitor is also an interesting circuit element to analyze using Maxwell's equations). ... I'm going to need to study much more carefully your write-up for the Maxwell's equations with the moving surface, but I'm very glad you presented it. I always like seeing the complete details. It is important to know the complete details to be able to assess whether simplified equations that are used in steady-state and/or cases without any moving boundaries will apply in more complex cases.
The transformers and coils are circuit elements in circuit theory as per Dale. It's implied that all fields are confined to the element so it's physical placement in relationship to other circuit elements in the circuit would be the same as moving a resistive element.
If we needed to examine a transformer as a circuit element then a process similar to this would be used.
http://www.electrical4u.com/equivalent-circuit-of-transformer-referred-to-primary-and-secondary/
A transformer is a single circuit element with four terminals. There is no magnetic coupling between circuit elements, only within an element.
No, what you use in circuit theory are KVL and KCL, which deviate from Maxwell's equations outside of circuit theory's domain of applicability. Similarly, Maxwell's equations deviate from QED, and Newtonian gravity deviates from the EFE outside their respective domains of applicability. Every simplified theory is derived from the more complicated theory, but the simplified equations are different and make different predictions outside of their domain of applicability.
The Maxwell equation approach is also very important in things like transformer design and trying to determine if a magnetic material with a given ## \mu ## and other magnetic properties is suitable for a transformer. It is important for a complete physicist to know how these things work, instead of just using a couple of simple formulas that provide an answer for the voltage and current. (Otherwise, you may very well wind up like the wizard in the movie the Wizard of Oz who accidentally takes off in his hot-air balloon, and Dorothy hollers to him "Come back, come back", and he responds "I can't come back-I don't know how it works" !). :-) :-) :-)
Charles Link said:
The Maxwell equation approach is also very important in things like transformer design and trying to determine if a magnetic material with a given μ and other magnetic properties is suitable for a transformer.
Agreed. Circuit theory has a more limited domain of applicability than Maxwell's equations. Similarly, Maxwell's equations have a more limited domain than QED, which is important for lasers and semiconductors and so forth.
And for @OnAHyperbola I think you might also find it of interest how Ampere's law comes into play (besides Coulomb's law), in the charge that builds up in a capacitor. Please see also post #75. The magnetic material terms ## M ## and ## J_m ## are zero for a capacitor. In addition, if the capacitor doesn't contain a dielectric, (for the simplest case), then ## P=0 ## ## \ ## and ## J_p=0 ##. You can take the divergence of both sides of Ampere's equation, and (using ## \nabla \cdot \nabla \times A=0 ## for any and all ## A ##), you get ## 0=\nabla \cdot (\mu_o \, J_{total})+\mu_o \epsilon_o \, \nabla \cdot (dE/dt) ##. Using ## \nabla \cdot E=\rho_{total}/\epsilon_o ##, you get the continuity equation: $$ \nabla \cdot J_{total} +\frac{\partial{\rho_{total}}}{\partial t}=0. $$ This shows how the extra non-steady state (## \mu_o \epsilon_o \, dE/dt ##) term in Ampere's law is necessary in order to have the electrical charge obey the continuity equation. (Note: ## \int \frac{\partial{ \rho_{total}}}{\partial t} dv=dQ/dt ## where ## Q ## is the charge on one face of the capacitor and the volume integral is over one plate). Maxwell's Ampere's law is not needed to solve for the capacitor voltage (that can be done simply with Coulomb's law/Gauss's law), but the capacitor example actually gives the correct non steady state correction to Ampere's law, (the ## \mu_o \epsilon_o \,dE/dt ## term), that is used along with Faraday's law to derive the electromagnetic wave equation.
1) In circuit theory we neglect the displacement current term in Maxwell's-Ampere's law, and this is what makes KCL valid and also makes it easy to express the time varying magnetix flux as a ##LdI/dt## or ##MdI/dt## terms.
2) Also in circuit theory we selectively (depending on occasion) neglect the time varying flux in Maxwell's-Faraday's Law. That's what makes KVL valid, and if we don't neglect the flux we make KVL valid by transferring the ##\frac{d\Phi}{dt}## term in the left hand side of the equation and expressing it as ##LdI/dt## and/or ##MdI/dt## terms. That's what happens in the "internal" treatment of a transformer using circuit theory, or in the simpler case where an inductor is present in a circuit.
Whether we have the right to do 1) and 2) depends on the problem. Usually 1) is valid if the wavelength of the currents is much larger (10x) the dimensions of the circuit, and 2) is valid if the magnetic fields are weak or the circuit loops are too small or a combination of both.
Of course, you are right. The complete Maxwell equations include the "displacement current" in the Ampere-Maxwell Law. Otherwise the equations are inconsistent, and that's how Maxwell introduced the displacement current into Ampere's Law. I also agree to the treatment of "macroscopic electrodynamics" as you describe it.
In the usual circuit theory, however, one assumes that the quasistationary approximation is valid, i.e., the displacement current can be neglected. Roughly speaking that's the case, if the relevant geometrical extent of the entire circuit is small compared to the typical wave length of the involved electromagnetic field. Then you can lump the entire geometry and the constitutive parameters ##\epsilon##, ##\mu##, and ##\sigma## into some constants like ##C##, ##L##, and ##R## of the "compact elements" built into the circuit. Of course, this also includes magnetically coupled sources like transformers or the very illuminating example by Lewin discussed above.
The greatest mess is done with Faraday's Law, if it comes to moving parts as in generators. In the case of homopolar generators you need even relativity although nothing is moving at speeds close to the velocity of light. For a derivation of the complete integral form of Faraday's Law, see the appendix of
http://th.physik.uni-frankfurt.de/~hees/pf-faq/homopolar.pdf
In a transformer, of course you couple two circuits magnetically. In the spirit of circuit theory everything is lumped into a inductance matrix, describing this magnetic coupling. It's derived from Faraday's Law, which is one of Maxwell's equations.
What is KVL and KCL? I guess it's Kirchhoff's Rules, but of course these are nothing than forms of Maxwell's equations applied to a special case (and the assumption that the quasistationary approximation, i.e., the negligence of the displacement current is valid). I guess "KVL" means "Kirchhoff's voltage law", which is nothing else than the integral form of Faraday's Law with the integrals lumped into the constants of the elements in the circuit like ##R##, ##C##, ##L##. Then "KCL" may stand for "Kirchhoff's current law", which is nothing else than the integrated continuity equation for electric charge in the quasistationary approximation in accordance with the use of Ampere's instead of the full Ampere-Maxwell Law.
I think our debate is merely about semantics rather than physics, but in my experience to have a good intuitive understanding of the Maxwell equations and the physics behind them is also very helpful for circuit theory.
Sure! That's why I was surprised by the claim that transformers, i.e., magnetically coupled circuits, are not included in circuit theory. That's for sure wrong. When I was a physics student many of my school mates studied electrical engineering and they liked to ask me about their problem sets. So I know, what electrical engineering students have to struggle with in the first semesters, concerning circuit theory ;-).
More precisely, it can be derived from Faraday's law plus some simplifying assumptions. The simplifying assumptions are every bit as important as the underlying equation because they define the domain of applicability.
The situation is exactly analogous to Newtonian gravity and GR. Newtonian gravity can be derived from GR plus some simplifying assumptions. However, I think that you would be hard pressed to find anyone who would say that a first semester physics student doing their first gravity problem is doing GR.
Also, Maxwell's equations can be derived from QED plus some simplifying assumptions. So if we took your approach and applied it consistently then we would never say that we are using Maxwell's equations either, we would just say that we are doing QED.
This is probably true, but in my opinion Dr Lewin's "KVL is for the birds" semantics is so bad that it deserves to be argued against.
I don't know why your own claim surprised you. It is for sure wrong, but it is your claim and not mine.
My claim is that transformers ARE in circuit theory. Yours was it isn't, but maybe I misunderstood you statement. My original claim was that it is important to stress that some "voltages" are not the same as "potential differences" but EMFs, and there Lewin's example is a good one to demonstrate that, and also Lewin's example is of course fully treatable by circuit theory, which he uses himself to analyze it in his writeup, which I linked in some previous posting in this thread. I'm still not sure what "KVL" means in the usual slang. For me it's one of Kirchhoff's rule, and it's just the integral form of Faraday's Law, and then it includes non-potential EMFs as in Lewin's example. If understood in this (imho usual) sense then KVL is NOT for the birds but can be successfully used to analyse Lewin's demonstration (which is nothing else than a cricuit with a magnetically coupled source EMF).
One of the more interesting parts of the physics to come out of this (at least for me) is the observation that the electric field from the Faraday term, whose voltage is the term ## LdI/dt ## of the KVL theory actually points from minus to plus, unlike the electrostatic E of a capacitor. I had probably observed it previously, but never paid much attention to it... Professor Lewin's claim in the video that KVL is not 100% accurate I think is something he used to get the viewer's attention as well as to show his own interest at a rather fascinating problem. Even the physics student who asked me to help him with his homework of this same problem that appeared in an E&M textbook was very puzzled by it as I was myself when I first saw in in 1979. How could that be that your voltmeter theoretically reads 1/4 volt in one case and then you hook it up the other way (encircling the changing magnetic field) and it theoretically reads 3/4 volt? Perhaps it reads zero all the time was one possibility until the puzzle was finally resolved. It's a very good illustration of EMF concepts. I do think Professor Lewin does a reasonably good job of illustrating the concept. I had mentioned the problem in post #8 (not knowing Professor Lewin to have his famous video solution.) Whether it's R.P. Feynman or Professor Lewin, most of these fellows are a little eccentric. Vanhees71 presented a pdf form of Professor Lewin's solution for which I didn't observe any inaccurate claims. The thing I was focused on was if he have a good solution to the puzzle, which he did. The study of circuit theory is much more complete by having seen this puzzle and having a sound explanation for it. The video made for a much easier way to discuss the solution. Most viewers probably didn't even see Vanhees71 pdf link from Professor Lewin. I do think the video has its merits and I don't think anyone else has made a well-known video of the same solution.
That is not my claim. You misunderstood my statement despite my clarifying it. A transformer is in circuit theory. I never claimed otherwise.
In circuit theory an ideal transformer is modeled as a single circuit element with four terminals. All of the magnetic coupling is inside the transformer, which is within the assumptions of circuit theory.
No, the circuit shown by Dr Lewin, in contrast, shows magnetic induction outside a circuit element, which explicitly violates the assumptions of circuit theory.
KVL is Kirchoff's voltage law, and as discussed repeatedly it is not just the integral form of Faraday's law, it is that plus some simplifying assumptions which you seem to consistently neglect.
Neglecting the assumptions is a huge conceptual error, IMO far worse of a "didactic sin" than anything else that I have seen you complain about from others. You really need to reexamine your approach here.
Well, then tell me which additional assumptions you need for the KVL, and I still don't see, where Lewin's setup needs more than the usual quasistationary approximation to be explained. I guess you only need the full Maxwell theory, if the entire setup becomes larger or of the order of magnitude of the typical wavelength of the applied source, and that's not the case in Lewin's experiment, but as I said, I think this whole discussion is pretty empty since it's pure semantics. E.g., of course in circuit theory you treat also transformers as "compact element", i.e., a "four pole" (I don't know if this is a correct English translation of the German "Vierpol"). In the formalism it's given by the inductance matrix.
BTW Circuit theory is only a special case of the general "transfer approach" for the full Maxwell equations, which has been developed by J. Schwinger to simplify the calculation concerning wave guides.
