AnandM
- 3
Why does electric flux have 'cos θ' in its formula??
Electric flux is defined by the formula that incorporates 'cos θ' to account for the component of the electric field perpendicular to a surface. The cosine function is essential because it allows for the calculation of the field's effective contribution in the direction of the surface normal. To maximize electric flux, the surface must be oriented such that its normal is parallel to the electric field, resulting in θ = 0 and cos θ = 1. This principle is analogous to positioning a bucket upright to collect rain, where any deviation from this orientation reduces the flux to zero.
PREREQUISITESStudents of physics, educators teaching electromagnetism, and professionals in electrical engineering who seek to deepen their understanding of electric flux and its mathematical representation.
To find the flux through a surface you need the component of the field perpendicular to the surface. Taking that component involves the cosine of the angle between the field and the normal to the surface.AnandM said:Why does electric flux have 'cos θ' in its formula??
If you want to maximize the flux through a surface, you want to orient the surface so that its normal is parallel to the field.AnandM said:Why does it have to ve perpendicular? Why not at any other angle?
You use cos θ because you want the component of the field in the direction of the surface normal. Whenever you need a component of a vector in a certain direction, you multiply the magnitude of the vector by the cosine of the angle it makes with that direction.AnandM said:So are we using cos θ because the sin θ component gives 0 flux?
