Why Does i^2 Equal -1? Explained
  • Context: Undergrad
  • Thread starter Thread starter EnlightenedOne
    Imaginary numbers
The discussion revolves around the mathematical concept of the imaginary unit, specifically why \(i^2\) equals -1. Participants explore definitions, properties, and implications of imaginary numbers, addressing misconceptions and providing various explanations. The scope includes theoretical aspects, mathematical reasoning, and conceptual clarifications.
  • Some participants assert that \(i\) is defined as \(\sqrt{-1}\) and thus \(i^2 = -1\) is a fundamental property of complex numbers.
  • Others challenge this by presenting a counterexample, suggesting that \(\sqrt{-1} \times \sqrt{-1} = \sqrt{-1 \times -1} = \sqrt{1} = 1\), questioning the validity of the definition.
  • A few participants clarify that the property \(\sqrt{a} \times \sqrt{b} = \sqrt{ab}\) only holds for non-negative real numbers, which complicates the application in the context of imaginary numbers.
  • Some contributions discuss the discontinuity of the square root function in the complex plane, emphasizing that the rules for square roots do not apply universally.
  • Participants mention that defining \(i\) as \(\sqrt{-1}\) can lead to complications and suggest that more advanced mathematical frameworks define complex numbers as pairs of real numbers.
  • One participant notes that understanding the relationship between complex numbers and trigonometry may provide further insight into the nature of \(i\).
  • Several participants express a desire for deeper explanations or additional resources to clarify the topic.
There is no consensus on the validity of the counterexample presented. While some participants support the definition of \(i\) leading to \(i^2 = -1\), others highlight the complications arising from this definition and the limitations of applying certain mathematical properties. The discussion remains unresolved regarding the implications of these differing viewpoints.
Participants note that the rules for square roots may not apply when dealing with negative numbers, and there are unresolved questions about the implications of defining \(i\) in various mathematical contexts. The discussion reflects a range of mathematical backgrounds among participants, influencing their understanding and explanations.
This discussion may be of interest to students and enthusiasts of mathematics, particularly those exploring complex numbers, imaginary units, and their properties. It may also benefit individuals seeking clarification on foundational concepts in algebra and trigonometry.
EnlightenedOne
I see many people saying that the imaginary number squared is -1, like so:
i = sqrt(-1)
i2 = sqrt(-1)*sqrt(-1) = (sqrt(-1))2 = -1
But, what about this:
i2 = sqrt(-1)*sqrt(-1) = sqrt(-1*-1) = sqrt(1) = 1
Can someone please explain to me why i2 = -1 if the above counter example is correct? If not, can someone explain why my counter example is incorrect? It seems like both are correct, but how can that be so?
Thank you
Mathematics news on Phys.org
You will understand better when you study Trigonometry.
More simply, we can have a solution for x2+1=0.
x2=-1
x=±√(-1)
and a variable is assigned to this solution, number:
i=±√(-1)
i = sqrt(-1)
Because it does. That's how i is defined, it's the complex number defined such that i^2 = -1.
Thank you
In general, the rule of sqrt(a)*sqrt(b) = sqrt(a*b) only works when a and b are both positive reals. That's not the case here.
x2=-1
x=±√(-1)
i=±√(-1)
Actually, I've taken everything up to and including Calc 3, and am currently taking Linear Algebra and ODE. But, we haven't dealt much with complex numbers.
Oh, ok. I didn't know that sqrt(a)*sqrt(b) = sqrt(a*b) only works for positive real values. So does (sqrt(a))^2 = a work for negative a values? That's what the definition is implying.
Yes it does. That follows from the definition of the square root. I would explain in further detail, but I don't have the background knowledge for that myself. Hopefully another member will.
Ok, awesome thank you.
The square root function is discontinuous in nature in the complex plane, so sqrt(x)*sqrt(y) = sqrt(x*y) only applies if x and y are both non-negative and real.
Otherwise you could do this:
-1 = i*i
= sqrt(-1)*sqrt(-1)
= sqrt(-1*-1)
= sqrt(1)
= 1
And now every math guru is feeling a disturbance in the force.
-1 = i*i
= sqrt(-1)*sqrt(-1)
= sqrt(-1*-1)
= sqrt(1)
= 1
Haha, ok. Thanx!
Defining i as "square root of -1" leads to complications just as shown here. That is why more advanced courses will do the following:
Define the complex numbers to be pairs of real numbers (a, b) with addition defined by (a, b)+ (c, d)= (a+ c, b+ d) and multiplication defined by (a, b)(c, d)= (ac- bd, ad+ bc). We can associate any real number, a, with the pair (a, 0). Then we have (a, 0)+ (b, 0)= (a+ b, 0+ 0)= (a+ b, 0) and (a, 0)(b, 0)= (ab- 0(0), a(0)+ 0(b))= (ab, 0), the usual addition and multiplication of real numbers so we can think of the real numbers as being a subset of the complex numbers.
Of course (0, 1)(0, 1)= (0(0)- 1(1), 0(1)+ 1(0))= (-1, 0), the pair we associate with the real number -1. If we call (0, 1) "i", we are saying that [itex]i^2= (i)(i)= -1[/itex]. Then (a, b)= (a, 0)+ (0, b)= (a, 0) + b(0, 1) so a+ bi.
Why i 2 = -1 ?
Becouse mathematicians have a wild imagination!
One method of explanation involves rotation, and can be shown in two-dimensions using a real axis and orthogonal imaginary axis; and this is why I said that Trigonometry can help in understanding. You can try a search on YouTube and expect to find a helpful tutorial lesson on this.
When I asked my high school trig teacher this question 50 years ago, he told me that functions involving imaginary numbers had to be reduced to their lowest terms. Since sqrt (-1) = i, every time sqrt (-1) appears in the equation, "i" must be substituted. Not a satisfactory answer for a 17 year old. I'm glad to see there's actually more involved.
That was for a FIRST explanation. Later, you learn about complex solutions happening in conjugate pair, which then makes sense.
I think this might help the OP: ##\sqrt{x^2}=|x|##
I think this could be explained without any fuss. Let me explain it to you at the most basic level:
See you have learned that: ##\sqrt(a)\sqrt(b)=\sqrt(ab)##. But I bet you might have never seen your text mentioning something like : ##\sqrt(-a)\sqrt(-b)=\sqrt(-a*-b)=\sqrt(ab)##. It's because its just not true.
See basically great minds defined ##i=\sqrt(-1)##. This actually evolved from the dilemma of "what number when squared gives a negative number". So complex numbers were invented. To be precise 'complex numbers' is a set, and strangely enough real numbers are a subset of this set. Every real number can be defined as a complex number. For instance, '2' can be defined as (2+0i) in complex form (unnecessary formalities!).
So ##\sqrt(-a)## is actually defined as ##\sqrt(-1)\sqrt(a)## where ##\sqrt(-1)=i## hence ##\sqrt(-a)=i\sqrt(a)##.
Therefore ##\sqrt(-a)\sqrt(-b)=\sqrt(-1)\sqrt(a)\sqrt(-1)\sqrt(b)=-1\sqrt(ab)=-\sqrt(ab)##
In the above equation the step which lead to your confusion is used: ##\sqrt(-1)\sqrt(-1)=-1##. (Just accept it, its simply a fact like 2+2=4, you can't prove it, I mean 2+2=4 is because 2+2=4 that's how the universe works. Similarly ##\sqrt(-1)\sqrt(-1)=-1## just because it is like that, nothing else.)
Hope this makes the problem a little clear.
I don't know how to quote multiple replies on my iPhone mobile browser, so I selected this one.
This post REALLY helps me understand my question! Thank you!
And thanks to all who have replied, your answers helped me also! :D
Your post is misleading, as you never defined a and b.
GFauxPas - 'a' and 'b' are just variables which define real numbers. I think we often use 'a' and 'b' as common numerical variables in mathematics.
But you never stated them as positive.
GFauxPas - When you say '2', do you take it as a +2 or -2. Of course +2. It's the same here, we often quote a variable 'x','y' or 'z' to represent numerals with the intrinsic direction and 'a','b' and 'c' as positive numerals.
You are expecting people to assume a variable is a positive number. To communicate formally, better precision is to say what is the kind of number.
2 is obviously a positive number, but variables that are represented by letters could be positive or negative. We never assume anything about the sign of a variable such as a or x.
Yes, exactly.
Oh, A possible misconception on my side. Sorry GFauxPas, Mark44 and symbolipoint. :)
  • · Replies 16 ·
  • · Replies 17 ·
